ke6gcv
My Charger is no more. The issues that started cropping up were too much in relation to its value. So, I purchased a 2017 Malibu LT and will be putting my radios in it and would like to get as many ideas as I can, please?
What pictures do you have of your install that you'd like to share? I would like for this to be as clean of an install as possible so I welcome your comments, suggestions, recommendations, ideas, and everything in between. (Can you hear my wife begging for a clean install?!)
I will do my best to give you specifics but since I'm not 100% familiar with the car yet, I may not have the answer to your questions. I am also digging around the Interwebs for as much info as possible on this car. So, here are the two radios I'd like to install.
I have a Kenwood TM-V71A and a Connect Systems CS800D. I also have all the accessories that go with both radios - external speakers, cables, remote mounts, extra zip cord and ties, split loom, etc. I will be looking at GM Upfitter's website for information as well.
My intentions are to install the control heads in the center, just below the stereo and HVAC controls. I will be putting the RF decks in the trunk. I know putting the decks in the trunk isn't ideal to the location of the battery, but it's all I've got for as much of a clean install as possible. I know the option for under the armrest is available but I don't want to do that. I use that area for other stuff.
I have a Comet SBB-2NMO and a CA-2X4SRNMO. Both are obviously dual bands but will consider changing them if necessary. There will be no roof mounts. I don't want to mess with the airbags and other things that are up there, including the shark fin. The antennas will be on the trunk provided I can get enough spacing. I'm considering 'L' brackets but will save that as a last resort. I prefer to punch holes.
This is what I'd like to know:
Thank you, everyone, for your input! It's appreciated!
- How difficult is it to run from the trunk to the battery?
- How easy is the center console to (somewhat) take apart to run the appropriate cables?
- Will the cables interfere with the operation of the vehicle? IE: shielded versus unshielded. I don't think it will, but want to be sure as this car is very hi-tech for me! (I'm very out of date with installing radios. Though I did get lucky with my Charger! Ha-ha!)
