2017 Ford Transit radio and antenna locations
radioguy32
We just received a new van and I need to install a XPR-4350 and a laptop. What is a good location for the antennas? The van is already so tall I am not sure on the roof is a good place. Should I put the radio in the overhead console like I do for the trucks? Does Ford make a specific bracket to replace the plastic inserts?
jonwienke
More Info Coming Soon!
VA
RF performance is always best if antennas are on the roof. What band(s) will you be using?
What size Ford Transit is it? I've got a small one at work that has two radios in it. RF decks were mounted behind the rear most bench seat and antennas are on the roof.
radioguy32
It is the full sized transit. The frequencies are 45X MHz and 900 MHz. Another user sent me the locations on the roof where I can put antennas. I talked with the driver and he would like the radio in a console on the floor so I am now shopping for consoles. For power I will connect to the Customer Connection Point on the drivers side. I just need to find an ignition sense source for the radio and I am good to start installing the antennas tomorrow.
