We sell all models of 2015, 2016 and 2017 Specialized, Trek, Cannondale, Gary Fisher, Klein, GT, Scott, Cervélo, Giant, Santa Cruz, Rocky Mountain, Kona, Whyte, Ellsworth, Jamis, Litespeed, De Rosa, Pinarello, Colnalgo, Look, Time, Yeti, Felt, Focus, Fuji, Bianchi and Marin Bikes.
Brand New Original Bicycles. Full Factory Warranty
Buy Direct. Save Big. Free Shipping
Contact Information
Sales Enquiry:
Paymeny method is PAYPAL and Bandk TRANSFER
Open 7 Days a Week (CLOSED Thanksgiving Day and Christmas Day)
E-mail: paulvaughn197@gmail.com
Phone Number : +16617765196
WhatsApp: +1(253)2719138
NOTE: Our prices are in U.S. Dollars!
FRAME
FACT 11m carbon, S3 Geometry, carbon front triangle, full carbon link and rear end, FACT IS construction, BB30, full internal cable routing, 135mm dropouts, lipped and sealed cartridge bearing pivots, replaceable derailleur hanger, 200mm travel
REAR SHOCK
Custom Öhlins, high/low speed compression adjust, rebound adjust, 9.5x3"
FORK
RockShox BoXXer Team 650b, coil spring, S: Extra soft spring , M: Soft spring, L: Medium spring, XL: Firm spring, 200mm travel, charger damper, compression adjust, rebound adjust, alloy steerer, 48mm offset, Maxle Lite DH
HEADSET
1-1/8" upper, 1-1/2" lower, semi-integrated, cartridge bearings
STEM
Specialized P.Series MTB, forged alloy, 4-bolt
HANDLEBARS
S-Works DH, carbon, 8-degree backsweep, 6-degree upsweep, 780mm, 31.8mm
GRIPS
Specialized Sip Grip, light lock-on, half-waffle, S/M: regular thickness, L/XL: XL thickness
FRONT BRAKE
SRAM Guide RS DH, metallic pads, Code caliper, 200m Centerline rotor
REAR BRAKE
SRAM Guide RS DH, metallic pads, Code caliper, 180mm Centerline rotor
BRAKE LEVERS
SRAM Guide RS DH, alloy lever, reach adjust, cartridge bearing lever pivot
REAR DERAILLEUR
SRAM X01 DH Type 2, 7-speed, short cage
SHIFT LEVERS
SRAM X01 DH, 7-speed
CASSETTE
SRAM X01 DH, 7-speed, 10-24t
CHAIN
SRAM PC-1130, 11-speed, w/ PowerLink, nickel finish
CRANKSET
SRAM X0 DH, BB30, carbon arms, triple base, w/ Gamut bashguard
BOTTOM BRACKET
SRAM, BB30, 83mm
PEDALS
Specialized Boomslang, 6061 alloy, sealed cartridge bearings
RIMS
Roval 650b, alloy, 24mm inner width, 32h
FRONT HUB
Specialized, Hi Lo disc, sealed cartridge bearings, 20mm thru-axle, 32h
REAR HUB
Custom DT Swiss, Star Ratchet, 54t quick engagement, XX1 driver body, 12mm thru-axle, 32h
SPOKES
DT Competition, stainless, 2.0mm
FRONT TIRE
Specialized Butcher DH, 60TPI, wire bead, 650bx2.5"
REAR TIRE
Specialized Slaughter DH, 60TPI, wire bead, 650bx2.3"
INNER TUBES
Standard, Presta valve
SADDLE
Body Geometry Phenom Expert, hollow Ti rails, 143mm
SEATPOST
Thomson, alloy, straight, 12-degree clamp
SEAT BINDER
Specialized, 7050 alloy, single bolt, 36.9mm
Contact Information
Sales Enquirer:
Payment method is PAYPAL and Bank TRANSFER
E–mail: paulvaughn197@gmail.com
Contact Information
Sales Enquiry:
FRAME
REAR SHOCK
FORK
HEADSET
STEM
HANDLEBARS
GRIPS
FRONT BRAKE
REAR BRAKE
BRAKE LEVERS
REAR DERAILLEUR
SHIFT LEVERS
CASSETTE
CHAIN
CRANKSET
BOTTOM BRACKET
SRAM, BB30, 83mm
PEDALS
RIMS
FRONT HUB
REAR HUB
SPOKES
FRONT TIRE
REAR TIRE
INNER TUBES
SADDLE
SEATPOST
SEAT BINDER
Contact Information
Sales Enquirer:
