2019 GMC Sierra ignition sense location
GRC
Canada
Last year i installed my XPR5550e in my new 2019 GMC Sierra Elevation and run the accessory cable to the front fuse/relay box. I just found one spot that is key-powered and find out that since i have the anti-idle feature on my truck, each time it shuts down at a red light the accessory connector i hooked my radio is loosing it's power. For the XPR its no big deal since i set the auto-shut feature to 2 minutes but i want to install a second radio (ICOM ID-5100) and for this one it will be a problem... I didn't find any other sources of auxiliary power in all indoor/outdoor fusebox. The truck is operating on a remote key FOB not a regular key.
OhSixTJ
Maybe the auto-stop eliminator would serve you well? It retains the memory of the auto-stop switch. So you get in after install, start the truck, hit the switch to disable it and it stays like that until you turn it back on.
KK6ZTE
California
The upfitter connections are usually a good place. Maybe something like this:
It shows a run-crank circuit.
