2019 MOSWIN Sites/Talkgroups
RF23
ProScan found on 9/24/19 at about 4:47 PM a New TG - 3955 in Troop E (Poplar Bluff).
I heard no traffic on the two transmissions (11 seconds long total) but it was displayed as "LINK". RSSI was -91.
RR database does not have it.
zzdiesel
Kennett / Dunklin Co, Mo.
Could those be datalinks for the terminals in the patrol cars?
RF23
I had not thought of that, but it very well could be.
That would certainly explain the lack of voice.
Thanks!
stlouisx50
Mountain Grove, MO (Texas County)
Is the 700,mhz simulcast system in St. Charles County in use? I have always used the Weldon Springs site and thought that was the only one. All this time I thought 700mhz was the SLATER system, but they are 800mhz...
kruser
West St Louis County, MO
I've not heard that site 2-004 since before the VHF Moswin sites started lighting up I don't think.
I thought at one time it was called the O'Fallon site but it does not show up as a neighbor site for any Moswin or Slater sites so it appears dead. I guess it could be some kind of a backup but you would think it would be on the air if that were the case or at least showing up as a failed neighbor site in Pro96com.
I still run the listed frequencies once in a while but never hear any activity.
Maybe it will become another fill in site like have been popping up in other areas of the state on Moswin.
That site still shows an active license but it is licensed to St Charles County government and not the state like Moswin sites are so it is an odd one. And your mention of Slater makes me think it could have started out under the Slater system also which may be the reason for the license holder.
As crowded as the 800 band is getting around here, it may be a good set of frequencies to keep in a scan bank as someone will eventually light it up.
scanman1958
St. Louis
O'ffallon, MO PD is listed on MOSWIN under St Charles County. The old 800MHz system they were on was the old St Louis City 800 system. Not sure why they were on it but it seemed to work, I guess. Isn't the police chief of O'ffallon a former high ranking city officer. Assistant chief or something. Maybe he just wanted to keep his roots with the city.
stlouisx50
Yeah I noticed someone put the info in the database wrong too. St. Charles City and ST. Peter's as well if I recall.
wbloss
Human
Joplin MO
Is there a list of VHF MOSWIN Inputs somewhere?
I know SOME sites list them in the notes but wondered if there were a full list, hopefully by site?
kruser
The licenses will list all the frequencies but in most cases you won't be able to tell which inputs and outputs are paired.
A lot of Moswin sites frequencies aren't listed due to being pulled from the VHF paging ranges which are licensed by market area.
Take a look at the callsigns for any of the VHF sites that show 152.xxx MHz frequencies. Hit the FCC site with that call and you will usually not find any of the paging band frequencies listed under the callsign.
They also use other ranges that were allocated for other services but unused in the state.
The paging sites are a bear to find anything as the inputs they assigned are not paired with anything normal.
I'm not sure but maybe the missing info can be found in CAPRAD but it's been a while since I've looked there.
Pro96com can help greatly here but you need to be near the site to decode its CC for that to work.
nd5y
Wichita Falls, TX
The auctioned paging (152/158 MHz) and VPC (161/157 MHz marine) channels are are paired blocks of frequencies. It's easy to find the inputs to those.
The federal frequencies that MOSWIN uses all have FCC licenses, but they are the same as public safety pool VHF licenses in that if there is more than one pair used at a site you usually can't tell which frequencies are paired.
UHF, 700, 800 and 900 MHz don't have that problem because standard offsets are used and the FCC won't allow non-standard offsets in those bands.
CAPRAD doesn't include VHF or UHF.
kruser
I didn't think CAPRAD was any help for the VHF frequencies. It's been a while since I'd visited the site but now recall using it for 700 MHz State Licenses.
Thanks for the reminder about the other two services having paired frequency blocks. I do recall finding that info before now that you mentioned it.
Again, Pro96com can be very handy for figuring this out if you are within range of a sites control channel. That may not answer wbloss's question to his liking but it's probably the best there is for those that may want to add any unlisted data maybe into the wiki for reference.
At least it will show what is paired with what. That's exactly what I ended up using for scanning the inputs for the local sites for nearby traffic.
It's always been spot on.
nd5y
Wichita Falls, TX
Here are the paging and VPC licenses. The base (output) frequencies are listed first.
Code:
Paging (CP)
BEA094 Springfield, MO
WQQC577    Block FE 152.135-152.165 / 158.595-158.625
WPVM796    Block FF 152.165-152.195 / 158.625-158.655
WPVM798    Block FH 152.495-152.525 / 157.755-157.785
WPVM799    Block FJ 152.555-152.585 / 157.815-157.845
WPVM800    Block FK 152.585-152.615 / 157.845-157.875
WPVM801    Block FM 152.645-152.675 / 157.905-157.935
WPVM804    Block FR 152.795-152.825 / 158.055-158.085
BEA096 St. Louis, MO-IL
WPVF232    Block FA 152.015-152.045 / 158.475-158.505
WPVF236    Block FE 152.135-152.165 / 158.595-158.625
WQMW917    Block FF 152.165-152.195 / 158.625-158.655
WPVM814    Block FH 152.495-152.525 / 157.755-157.785
WQAH684    Block FI 152.525-152.555 / 157.785-157.815
WPVF238    Block FJ 152.555-152.585 / 157.815-157.845
WPVF239    Block FK 152.585-152.615 / 157.845-157.875
WPVF240    Block FL 152.615-152.645 / 157.875-157.905
WPVF241    Block FM 152.645-152.675 / 157.905-157.935
WPVF242    Block FO 152.705-152.735 / 157.965-157.995
WPVF243    Block FP 152.735-152.765 / 157.995-158.025
WPVF244    Block FQ 152.765-152.795 / 158.025-158.055
WPVF245    Block FR 152.795-152.825 / 158.055-158.085
BEA097 Springfield, IL-MO
WQQC580    Block FH 152.495-152.525 / 157.755-157.785
WQQC582    Block FI 152.525-152.555 / 157.785-157.815
WQPU482    Block FO 152.705-152.735 / 157.965-157.995
BEA098 Columbia, MO
WQQC578    Block FA 152.015-152.045 / 158.475-158.505
WPVM828    Block FF 152.165-152.195 / 158.625-158.655
WPVM830    Block FH 152.495-152.525 / 157.755-157.785
WPVM831    Block FJ 152.555-152.585 / 157.815-157.845
WPVM832    Block FK 152.585-152.615 / 157.845-157.875
WPVM834    Block FM 152.645-152.675 / 157.905-157.935
WPVM837    Block FR 152.795-152.825 / 158.055-158.085
Marine VHF Public Coast (PC)
VPC004 Mississippi River
WQQQ233
Ch  24 161.78750-161.80625 / 157.18750-157.20625
Ch 224 161.80625-161.81875 / 157.20625-157.21875
Ch  84 161.81875-161.83125 / 157.21875-157.23125
Ch 284 161.83125-161.84375 / 157.23125-157.24375
Ch  25 161.84375-161.85625 / 157.24375-157.25625
Ch 225 161.85625-161.86875 / 157.25625-157.26875
Ch  85 161.86875-161.88125 / 157.26875-157.28125
Ch 285 161.88125-161.89375 / 157.28125-157.29375
Ch  26 161.89375-161.90625 / 157.29375-157.30625
Ch 226 161.90625-161.91875 / 157.30625-157.31875
Ch  86 161.91875-161.93125 / 157.31875-157.33125
Ch 286 161.93125-161.94375 / 157.33125-157.34375
Ch  27 161.94375-161.95625 / 157.34375-157.35625
Ch 227 161.95625-161.96875 / 157.35625-157.36875
Ch  87 161.96875-161.98125 / 157.36875-157.38125
Ch 287 161.98125-161.99375 / 157.38125-157.39375
Ch  28 161.99375-162.00625 / 157.39375-157.40625
Ch 228 162.00625-162.01875 / 157.40625-157.41875
Ch  88 162.01875-162.03750 / 157.41875-157.43750
700 MHz State License (SL)
WPZT785  769.000-775.000 / 799.000-805.000
talkpair
Clinton County, MO
The biggest problem with using Pro96Com for discovery is that there are usually one or two voice channels that are not in rotation and only used when the site is busy. Pro96Com has no way of knowing anything about the voice channels until they are actually used.
wbloss
Human
Joplin MO
If you use Pro96Com, the input frequency associations can be found in the various Tower files inside the System1CE sub directory.
I
I DO use Pro96Com, but not sure where to find what you suggest...on the "site information" tab?
I think I'll make a project of assembling the IPs from the licenses. See you in a few weeks!
