Could those be datalinks for the terminals in the patrol cars?ProScan found on 9/24/19 at about 4:47 PM a New TG - 3955 in Troop E (Poplar Bluff).
I heard no traffic on the two transmissions (11 seconds long total) but it was displayed as "LINK". RSSI was -91.
RR database does not have it.
Is the 700,mhz simulcast system in St. Charles County in use? I have always used the Weldon Springs site and thought that was the only one. All this time I thought 700mhz was the SLATER system, but they are 800mhz...
Yeah I noticed someone put the info in the database wrong too. St. Charles City and ST. Peter's as well if I recall.O'ffallon, MO PD is listed on MOSWIN under St Charles County. The old 800MHz system they were on was the old St Louis City 800 system. Not sure why they were on it but it seemed to work, I guess. Isn't the police chief of O'ffallon a former high ranking city officer. Assistant chief or something. Maybe he just wanted to keep his roots with the city.
The licenses will list all the frequencies but in most cases you won't be able to tell which inputs and outputs are paired.Should be able to look at the FCC licenses.
A lot of Moswin sites frequencies aren't listed due to being pulled from the VHF paging ranges which are licensed by market area.The licenses will list all the frequencies but in most cases you won't be able to tell which inputs and outputs are paired.
CAPRAD doesn't include VHF or UHF.
Paging (CP)
BEA094 Springfield, MO
WQQC577 Block FE 152.135-152.165 / 158.595-158.625
WPVM796 Block FF 152.165-152.195 / 158.625-158.655
WPVM798 Block FH 152.495-152.525 / 157.755-157.785
WPVM799 Block FJ 152.555-152.585 / 157.815-157.845
WPVM800 Block FK 152.585-152.615 / 157.845-157.875
WPVM801 Block FM 152.645-152.675 / 157.905-157.935
WPVM804 Block FR 152.795-152.825 / 158.055-158.085
BEA096 St. Louis, MO-IL
WPVF232 Block FA 152.015-152.045 / 158.475-158.505
WPVF236 Block FE 152.135-152.165 / 158.595-158.625
WQMW917 Block FF 152.165-152.195 / 158.625-158.655
WPVM814 Block FH 152.495-152.525 / 157.755-157.785
WQAH684 Block FI 152.525-152.555 / 157.785-157.815
WPVF238 Block FJ 152.555-152.585 / 157.815-157.845
WPVF239 Block FK 152.585-152.615 / 157.845-157.875
WPVF240 Block FL 152.615-152.645 / 157.875-157.905
WPVF241 Block FM 152.645-152.675 / 157.905-157.935
WPVF242 Block FO 152.705-152.735 / 157.965-157.995
WPVF243 Block FP 152.735-152.765 / 157.995-158.025
WPVF244 Block FQ 152.765-152.795 / 158.025-158.055
WPVF245 Block FR 152.795-152.825 / 158.055-158.085
BEA097 Springfield, IL-MO
WQQC580 Block FH 152.495-152.525 / 157.755-157.785
WQQC582 Block FI 152.525-152.555 / 157.785-157.815
WQPU482 Block FO 152.705-152.735 / 157.965-157.995
BEA098 Columbia, MO
WQQC578 Block FA 152.015-152.045 / 158.475-158.505
WPVM828 Block FF 152.165-152.195 / 158.625-158.655
WPVM830 Block FH 152.495-152.525 / 157.755-157.785
WPVM831 Block FJ 152.555-152.585 / 157.815-157.845
WPVM832 Block FK 152.585-152.615 / 157.845-157.875
WPVM834 Block FM 152.645-152.675 / 157.905-157.935
WPVM837 Block FR 152.795-152.825 / 158.055-158.085
Marine VHF Public Coast (PC)
VPC004 Mississippi River
WQQQ233
Ch 24 161.78750-161.80625 / 157.18750-157.20625
Ch 224 161.80625-161.81875 / 157.20625-157.21875
Ch 84 161.81875-161.83125 / 157.21875-157.23125
Ch 284 161.83125-161.84375 / 157.23125-157.24375
Ch 25 161.84375-161.85625 / 157.24375-157.25625
Ch 225 161.85625-161.86875 / 157.25625-157.26875
Ch 85 161.86875-161.88125 / 157.26875-157.28125
Ch 285 161.88125-161.89375 / 157.28125-157.29375
Ch 26 161.89375-161.90625 / 157.29375-157.30625
Ch 226 161.90625-161.91875 / 157.30625-157.31875
Ch 86 161.91875-161.93125 / 157.31875-157.33125
Ch 286 161.93125-161.94375 / 157.33125-157.34375
Ch 27 161.94375-161.95625 / 157.34375-157.35625
Ch 227 161.95625-161.96875 / 157.35625-157.36875
Ch 87 161.96875-161.98125 / 157.36875-157.38125
Ch 287 161.98125-161.99375 / 157.38125-157.39375
Ch 28 161.99375-162.00625 / 157.39375-157.40625
Ch 228 162.00625-162.01875 / 157.40625-157.41875
Ch 88 162.01875-162.03750 / 157.41875-157.43750
700 MHz State License (SL)
WPZT785 769.000-775.000 / 799.000-805.000
IIf you use Pro96Com, the input frequency associations can be found in the various Tower files inside the System1CE sub directory.
