ke6gcv
I'm to hopefully be able to take delivery of my new Dodge Charger GT Plus soon. (So long, Malibu! May you be able to make a lot of lemonade!) With that, I do fully intend to install my radios.
Trunk lip mounts for starters before I punch the holes. (Yeah... Yeah... I know... just drill the hole! But for reasons I don't want to get into at the moment, lip mounts will have to suffice.)
Anyway, I've been advised that the new Chargers don't like two-way radios all that much. (Apparently this person works on Dodge products a lot!) To paraphrase, they mentioned something to the effect of RFI getting into the computer and creating havoc. Again, this is what I was told. Take it for what it's worth. Has anyone experienced this with their personal or fleet Charger?
I can understand that if the install wasn't properly done, there can be RFI. For example: Using the wrong locations for power. Using an inferior coax cable and/or improperly installed PL-259. Using unshielded Cat5 cable for remote mounts (if your radio can support it). Things like that makes perfect sense to me that there'd be RFI.
When I had my 2010 Charger, I mounted everything in the trunk. That was far enough away from the computer as I was going to get! (Short of not installing radios at all! Hi-Hi!) I would think that if I repeat that style of install, there would be almost no RFI. If any at all! Wouldn't you?
I used to professionally install two-way radios, so I do know a thing or two. Granted that was some twenty-plus years ago now and technology has changed considerably since, but still. I only mention this to spark conversation into what your thoughts are. Your experience. Please let me know! Thank you!
