First of all. Thank you, thank you to mmckenna on here for all of the guidance and patience. I owe you a beer.
I'm a 2m/70cm guy. My truck is a 2020 Ford Super Duty Diesel which is essentially the same as the 17-19 when it comes to radio installs. Although I did not use the pass through wires or upfitter switches for this radio, note that for 2020 it is all on the passenger side now. Here is my primary equipment list:
The mic is located in my center console and connected by a bulkhead ethernet connector that I bought off of Amazon. When in use I can close the console lid and put the mic in one of the cup holders. Cabling to this is the Kenwood stuff (not offbrand) that runs down the passenger side door sill and cuts across as the front passenger door. I did not need to remove the entire center console. Just the cup holder/trim assembly. Don't mind the black/white USB.
I don't use the cubby charging pad feature so I put the head there with double sided tape. Not seen in the pic is a .4" hole in the cubby to the right side of the power button. I routed the control cable down the passenger door sill, up under the dash and around to the hole. I did this as the same time the trim piece was out for the mic install. I can close the lid and it is out of sight.
Regarding power, I was going back and forth on an upfitter switch connection but opted not to. The radio's APO feature ensures that it powers off after 30 mins. The red cable is connected straight to the passenger side battery with a 15 amp fuse. Even on 50w you are still around 13 amps with this rig. To get the cable into the cab, I cut a small slit in the firewall boot as seen here which is in plain view on the firewall behind the passenger battery and fished it through with one of my rifle cleaning rods. Go slow but firm and you'll be through in seconds. The cable then travels down the door sill to the Kenwood. Don't mind the blue wire.
These speakers are mounted to the underside of the passenger seat's metal frame. One is for the Kenwood and the other is for the Uniden. They came with brackets and small screws are so shallow that you can't damage the seat. The wire runs from the main Kenwood chassis down the door sill and cuts across at the seat under the carpet. Audio is great and I have bad ears. Don't mind the cables in the bottom right of the pic.
At the last minute I accidentally found this rack by Built Right Industries. USA Made and installs behind the passenger rear seat or my crew cab. I mounted the Kenwood chassis on it and it's perfect. I used some basic 50 cent rubber insulators from Ace to mount the radio to the rack to keep vibration down. You can see the red 10 gauge power cable in the bottom of the pic. The ground is attached to the big seat bolt on the right. The antenna cable is in view with a 90 degree connector on it. The head unit cable is on the left with a label on it. The chassis is mounted with the heats sinks out for (potentially) better cooling.
Final Notes:
- Kenwood TM-V71A
- Bulletproof Diesel Dual NMO 3rd Brake Light Mount
- Road Pro RPSP-15 speaker
- Stinger SK46101 10 Gauge 4000 Series Power and Signal Amplifier Installation Kit
- Diamond NR770 Dual Band Antenna
- Kenwood PG-5F Extension Cable Kit
- Built Right Industries Rear Seat Back Storage Panel
This antenna mount is real nice. Sandwiches between the OEM brake light and the body. Remember that these trucks are aluminum. Also, I have the panorama roof so drilling was not viable or desired. Cables run into the cab through the brake light opening and down the side panels. Clean and solid. I have 2 NMOs as I also run a Uniden BCD996P2 scanner in my center console. I have caps on them in this pic.
Final Notes:
- SWR: I'm sitting at 1.01 across 2m and 1.03 on 70cm regardless of power level. I was nervous that the brake light mount might make for issues but it is engineered for this. I was driving through Central CA and into Los Angeles the past couple days and was getting compliments on my signal.
- Label ALL your cables for you and the next guy. The Kenwood head unit and mic cables look identical and a small label at the radio chassis and every few feet along the routing makes a big difference on knowing (and remembering in a few years) what is what.
- Keep generous slack in all of your cables during final install. You may want to adjust something by an inch or a foot. That's why they created zip ties.
- Buy a $10.00 trim piece removal kit that has a BRIGHT COLORED cable snake in it. This made running cables under carpet and up into consoles a breeze. Bright coloring helps you see the snake under the dash etc.
- Use the Kenwood brand extension cables because you will know they are wired properly to their connectors. I could have saved 50 bucks and bought eBay or Amazon stuff but I didn't want to have to undo all of my work if something wasn't working right.
- I used Anderson power connectors from Powerwerx instead of the T-connector at the back of the radio. I cut off the T-connector altogether. The main reason I did this was because I have 10 ga power and ground cables which would not reliably seat into a replacement T-connector. In the end I would do it again with the Anderson connectors.
