2021 GMC Sierra Elevation (Duramax) install
N7iOS
Dispatcher & Ham Radio guy!
Hubbard, OR
Setup for now is a Kenwood NX-5700 and a Motorola XPR4550 (mounted under passenger seat).
Long term plan will be for a Havis console or similar with the NX-5700 and will eventually ditch the Motorola and do a Kenwood advanced remote head with a NX-5800 and 700/800 NX-5900 as a tri-deck system.
Also running a ram mount system with their quick detach hardware in case my passenger needs more room. If I remove the ram mount, I attach a tablet mount to my dash mounted proclip usa system.
PACNWDude
Looks like a nice layout. Do you have any vibration from the pedestal mount for the keyboard/monitor stand?
N7iOS
Hubbard, OR
not really much vibration. The setup is fairly heavy duty so I think that helps. The quick release assembly adds some overall play to the whole setup but it’s more manageable than I was expecting. Overall, i am pretty happy with it vs/a permanent solution that I use to have in my Nissan Xterra.
N7iOS
Hubbard, OR
Excellent! And the antennas?
It’s temporary and nothing fancy. Two mag mounts with a Larsen 1/4 wave and a Larsen dual band. I have the coax tight toward the rear and then tucked into a trim peice by the third tail light which then runs over to rear passenger door and squished in the seal and tucked away running to the radios.
Expecting my canopy to be delivered in a week or so at which point I may relocate antennas to NMO mounts on a roof rack on the canopy, or drill holes in cab for permanent mounting. Not sure which I’ll do yet!
03msc
RF is RF
Arkansas
OK cool. I would highly recommend drilling the NMO mounts in the roof. Clean and the best performance by far. But the other option is certainly better than the temporary mag mounts.
N7iOS
Hubbard, OR
That’s honestly what will end up happening. However, working in public safety.... summer is hectic and that part of the install will have to wait.
I had a quick transition from my previous two vehicles over to this truck, so I didn’t have much time to make it look better than it is now haha.
03msc
RF is RF
Arkansas
Looks fine! You have a plan with a good goal in mind so that's good. You'll get there!
N7iOS
Hubbard, OR
I’m considering adding a tablet to my truck. I’m curious, what applications you use on the tablet when mobile?
When in urban environment…work programs if necessary & Google Maps for larger navigation if necessary. When off road/forest I primarily use Avenza Maps with all of our local state forestry maps and USFS district ranger maps downloaded for offline use. Perfect setup IMO
K7MFC
WRAA720
Phx, AZ
Yes, +1 for Avenza Maps. I also rely heavily on this app for off-roading around Arizona, especially when you're well out of mobile network coverage. It varies from forest to forest, but the USFS publishes some really high quality maps which can be loaded in the Avenza Maps app. Here's an example of the detail found in the Coconino National Forest map:
