2021 MOSWIN Sites/Talkgroups
drbeede
Gatewood,Missouri
Hope someone can shed some light on this for me, in my scanner I was listening to troop E which is based out of Poplar Bluff, normally when I am listening to them the site Id and location shows the MOSWIN tower site as Poplar Bluff, but today twice so far the scanner has showed sites in Milan and in Grandy City. Anyone got a clue to why this is happening? Both of those sites are way out of physical receiving range for my scanner and location.
KA0KDW
Polk County, Mo
Do you have all the sites loaded on your scanner? Or are you running on full database?
nd5y
Wichita Falls, TX
Trunked system sites can reuse the same frequencies throught the state.
The scanner finds an active control channel.
Depending on how you programmed it the scanner may or may not display the correct site.
drbeede
Gatewood,Missouri
ok I'll buy that, but what about hearing Talkgroups and agencies you know for a fact are on the other side of the state like 300 or 400 miles away?
KA0KDW
Polk County, Mo
I have all the sites loaded on my scanner.
As mentioned in the post by @nd5y frequencies are reused across the state so you may see other site names. One way to combat this (if your scanner isn’t able to ise NAC) is to only have the control channels listed for each site. In the scanners there is no need to have the voice channels listed.
mgolden2
Kansas City area
Isnt MOSWIN set up like this - If there is another radio in your area or that is affiliating with your tower and that radio is listening to 3101, then your tower will rebroadcast 3101 and you will hear it?
KA0KDW
Polk County, Mo
3101 is Forestry Service, someone said it is in or near the Arch in St. Louis I hear it just fine from my location.
3101 is US Parks service in the Ozark National Scenic River ways. Throughout Shannon and Oregon Counties. Their dispatch is at the Arch.
drbeede
Gatewood,Missouri
3101 is US Parks service in the Ozark National Scenic River ways. Throughout Shannon ajd Oregon Counties. Their dispatch is at the Arch.
yep well they come in perfect here at my location, their dispatch and park rangers.
KA0KDW
Polk County, Mo
That’s only if the talk group is allowed to affiliate to the site. I believe 3101 is a talk group that can be used anywhere in the state.
mgolden2
Kansas City area
That explains why you're hearing agencies that are 300-400 miles away on your tower; there is a radio listening to that agency nearby your location that is affiliating with your tower and bringing that radio traffic with it.
KA0KDW
Polk County, Mo
P
some sites cover exceptionally well. There may be some areas that they cover through out the parks where poplar bluff is where their radio affiliates. There’s a spot near eminence in Shannon county where their radios affiliate to the Willow Springs site. So in reality the user may be 25 miles or less (line of site) from the tower they’re using
drbeede
Gatewood,Missouri
P
So one final question, is it better to have all the tower sites programmed in to the scanner or just the ones that are nearby?
KA0KDW
Polk County, Mo
I use the sites that are near by. And I only have control channels for each site. I don’t list the voice channels to help prevent random sites from coming in during band openings. I do have a favorites list that has all sites and talk groups on MOSWIN but that is a location based list.
drbeede
Gatewood,Missouri
ok thanks for the help.
llzel
So if you're in the St Louis Area, which MOSWIN tower would you program to hear the park service? St Louis South 2 005?
