2024 FIRESCOPE Radio Communications Guide
mcjones2013
Radio Communications Enthusiast
Sacramento, CA
I don't think I've seen it posted this year, but here's the 2024 FIRESCOPE Radio Communications Guide.
Some changes include OES 1A, 1B, 2A, 2B being renamed to OES V1-V4, and the individual USFS service nets appear to be consolidated/shared between different forests. Some local channels added in including some P25 stuff (note the guide says the P25 entries are only required in P25-capable radios, meaning if the agency has analog-only radio the channels are not required).
KK6ZTE
California
Mandatory 400 channels? Looks like all of the volly departments with TK-790s are out of providing mutual aid....
Also defining P25 channels without defining modulation (C4FM vs CQPSK)... lovely.
officer_415
SF Bay Area
I don't think the TK-790 has been approved for interagency use for some time now...
Isn't CQPSK only used for P25 trunked simulcast systems? C4FM is the standard for conventional.
KK6ZTE
California
That doesn't mean there aren't plenty of apparatus out there with them still.
Not at all. CQPSK (LSM) can be used for conventional as well and it helps solve some of the delay spread issues in simulcasting C4FM. Motorola APX radios and Harris XL radios need to be accurately defined or they won't receive properly. Kenwood seems to be fine either way. I have even configured a single site LSM repeater on UHF to help with multipath due to the delay spread resistance.
This is a conventional UHF system in APX CPS R32:
A P25 conventional frequency set in Harris RPM2. I can confirm both radios will not work on my LSM system if modulation is set to C4FM, even though it's supposed to be "compatible".
Here's some info:
Of course, I did get some comments via text after my first post that the standard is C4FM unless otherwise specified (you never know who's watching this board!). However, being that some radios will not receive if the modulation type isn't set right, we need explicit direction somewhere in the document.
norcalscan
Interoperating Spurious Emissions
The real northern california
I think at that point the dept might just have their type 6 or type 3 be the MA resource and then they just get the one KNG instead of outfitting the entire dept.
officer_415
SF Bay Area
I meant to say P25 simulcast (not necessarily trunked). But I don't think there are many conventional P25 simulcast systems in CA, at least not that would be used for fire mutual aid.
ke6gcv
Somewhere, Northern CA
I saw this last year and again this year. What is the reason for the channels to be alphabetized?
To me, it would make a lot more sense to put the command channels at the top of the list, then break them down from there.
I do know that at an actual incident, the radios are "field" programmed by the ICP.
norcalscan
There's no set standard for sorting resources on an IC-217, but I think in this particular case with California/Firescope, it's become a necessity to assist with visually finding the referenced channel. This is also starting to become the new "statewide" group/zone in everyone's radios outside of CalFire. They'll have a Group or Zone programmed with the entire MACS-441 in it, and when responding mutual aid, they'll build their command group/dynamic zone pulling channels out of this list. I've seen some loads where it's more the old-school CalFire sorting by unit number (placing MEU first past the command nets), and recently starting to see it alphabetized instead, which makes more sense in quickly navigating to the right channels instead of guessing somebody's idea of organizing by function or agency etc.
ke6gcv
Thank you for the explanation @norcalscan ! That does make total sense when you're building the command group.
es93546
A Member Twice
Right Side of CA on maps
The "new" one: 35 pages, dated May 11, changed May 15, 1034051 bytes
The "old" one: 33 pages, dated April 4, changed April 13, 618958 bytes
Comparison is left as an exercise for the reader :)
The difference between the two versions is pretty easy to find. All the pages in the new version are printed in landscape, as opposed to the portrait orientation of the first version. That makes a difference of about a page additional. I did not examine line for line, but I believe both versions are the same, but the landscape version has larger type, which makes it easier to read. The biggest difference is the April 4th version did not include 700 & 800 MHz information, which is included in the May 11th version. This adds 4 pages to the document. Nothing really earth shattering here!
