ecps92
I don't recall 31.9600 being a Drive-up Order System frequency.Are these fast food local to you? Thats quite the reception if its skip
You are correct. They are still there. I put 42.860 back in the X9000 and It's weaker since they took down the big Troop A tower with the multielement dipole array but I am hearing them. I'm using a COM201B with L brackets and 8 foot CB whips in place of the telescopic legs and a 3 foot whip extending the active element at about 25 feet.IDK but i heard them today .May just be a temp thing.Angelo
Like the fox stuck in a pool! AngeloCentral Alabama
SDS200 with ST2 Antenna
32.1800 77.0 Taxi, Alajuela, Costa Rica
33.4800 179.9 Fire Dispatch - Tolland CT
33.5600 CSQ Fire/EMS Dispatch - Lancaster Co PA
33.6400 114.8 Fire Dispatch - Bourne MA
33.7800 114.8 EMS Dispatch - Falmouth MA
33.8000 179.9 Fire/EMS Dispatch - Windham Co CT
33.8200 141.3 Fire/EMS - Calvert County MD "Respond for a fox stuck in a pool"
33.8600 82.5 Fire/EMS Dispatch - Licking Co OH
37.0200 146.2 Police Dispatch - West Milford NJ
37.5800 D412 Potomac Electric, Rockville MD w/ Morse ID KGA845
41.0000 150.0 Army National Guard Helos, Ellington Field TX
46.4600 CSQ Fire/EMS Dispatch - Baltimore County MD "Rocky Point Park, between Rocky Park Road and Barrison Point Road"
46.5600 173.8 Fire Dispatch - Jefferson NJ
Reminded me of the mid-1970s when "fox in a pool" would have had a totally different meaning than today.Like the fox stuck in a pool! Angelo
This one?Using a Winegard 68 element beam fm/vhf/uhf up 15 feet pointing north.Ues it for my TV and found works great with my GRE PSR 500! Ihear THP here some times in TN on low band checking to see if the radio still works.. Angelo
Ah no i have the older model HD7084P. The HD8200u replaced it very slight difference.AngeloThis one?
HD8200U Platinum HD Series Antenna
Experience crystal-clear HDTV reception with the Winegard HD8200U Platinum HD Series Antenna. Designed for superior performance and durability, this high-gain antenna delivers exceptional signal strength for capturing free over-the-air broadcast channels. Unlock a wide range of HD programming...winegard.com
Would be interested in how well it works for you on low band.
I guess you'd have to mount it vertically polarized and put a 52 ohm transformer on it.This one?
I could if i wanted to.Works fine could put a rotor on it too.AngeloI guess you'd have to mount it vertically polarized and put a 52 ohm transformer on it.
