2042-2035 side by side
737mech
Clark County, NV.
I just got the 2035 and I can side by side with my 2042. Mostly the same green vs yellow display. Black vs gray buttons. As you can see in pic my 536 is missing out for repair. I really like these rs scanners, the 2035 and 2042 are quite nice on milair uhf 225-400. My plan is to box the 2035 for remote site ops. I will post pics of that setup later.
CanesFan95
Was Homeboys-Scanna
Banned
FL
I miss those Hyperscan machines. Man, those things were fast!
iMONITOR
Silent Key
S.E. Michigan
Very nice scanners! I've owned both, but at separate time during my scanner years. I could never tell any difference in performance. They're built very well.
What are you mounting your other scanner in? It's hard to tell from the picture. It almost looks like a (wide) computer tower? Nice setup!
737mech
Clark County, NV.
My setup
The hole you see below my bct-15 is for the 536hp. The box holds a Pro-2051/Bct-15 /BCD536HP and power supply. It's a repurposed Motorola repeater box that used to have two cdm 750's and a repeater controller. I also replaced the fan for a nice quiet blue led version. The 2035 is heading to a ammo can type setup for when I go remote. It should be cool. I'll post pics of that when it's done.
737mech
Clark County, NV.
Tap mod 2042
Actually the 2042 was used when I bought it and I quickly discovered the previous owner had turned the front headset port into a tap. So that's good to go. Carrier light? Not sure if I need that?
N1SQB
Somewhere On Earth
It depends on how many scanners you run at one time. I have 7. The 2042 is used for military and civil air monitoring. I like the Carrier On Indicator light because it lets me keep the 2042 on low volume until the squelch breaks and I see the light go on indicating activity. A visual signal indicator.
Manny
rbm
Upstate New York
At one time, I had six PRO-2035's and two PRO-2042's.
They worked very well.
I still have two of them in use, but gave away the others when I started using Uniden DMA scanners.
I upgraded all of them with European processor chips I bought from the UK.
That gave me full coverage back again..
Rich
737mech
Clark County, NV.
LED mod
Carrier LED? What's needed is it simple to do? I looked it up and the results I find are for a different model scanner? Any specific 2035/2042 pics out there? Anyone willing to pull the top off and take a pic to show me?
N1SQB
Somewhere On Earth
737mech
Clark County, NV.
Pin 4/13?
I opened the scanner, the diagram is easy to understand. Thanks! One question, I see the IC chip TK10420 and other posts about the mod call out using pin 13? Your diagram says pin 4. Which is correct?
ipfd320
Banned
W.Babylon N.Y. 11704
Manny---All the Links and Videos Are No Longer Avaible From The Link You Posted in Post 11---I Myself Would Like to Do The Mod with Light Also---Just Thought I,d Let You Know---Thanx
N1SQB
Somewhere On Earth
Ok Here we go....
Its been quite a few years since I did this mod and this is only the second time I've ever popped the hood on my baby...
Pic#1. Shows pin #13. (The reference to pin 4 was for Uniden scanners.)
Pic#2. Shows how I mounted the perf board to the scanner.
Pic#3.Shows the back side of the LED, mounted where the headphone jack once was.
N1SQB
Somewhere On Earth
Yeah, I saw that. That's why I took these pics. Those links were from 2011 Thanks for the heads up...
Manny
737mech
Clark County, NV.
Thanks!
I went to Fry’s got the parts and it works great fun project for today!
737mech
Clark County, NV.
Part numbers
OBTW Fry's carries the product line "NTE" and the 2n3904 cross references to NTE123AP. That's what I used.
N1SQB
Somewhere On Earth
Nice job.
Looks nice! I almost went with that same style light but the bulb sticks out a little too much for my taste. I was afraid it would get bumped by something and break. That's why I used one that is recessed with a metal housing.
Manny
