1. Press SCAN, then hold down TRUNK until the scanner beeps twice. BANK,
TRUNK and the bank numbers flash.
2. Select the bank where you want to store the preset fleet map by pressing
a number key.
3. Press DATA.
4. Repeatedly press /\ or \/ to select E1 (Type I and hybrid), then press
DATA again.
Note: To select Type II, press E when E2 appears.
5. Repeatedly press /\ or \/ to select the name of the map you want (such
as E1P7), then press E.
The scanner then searches for transmissions using the preset map you chose.
