2067 and low-pass discriminator
blantonl
Founder and CEO
Staff member
Super Moderator
Dallas, TX
Anyone know if the 2067 has a low-pass discriminator like the 780? I'd like to start using some of the LTRtrunk utilities, but don't have a 780, or a 296/796 etc - only bearcat for me is a 245.
-Lb
pro92b
Mutated Member
Update: I did a bit more work to determine if the signal at pin 21 of the MX805 is useful for subaudible decoding. The signal is a pulse train with amplitude of 0 to 5 volts but it needs a MAX232 to drive a serial port. To activate the MX805 the channel must be set to PL, DPL, LT, or MOT. In the other modes the chip is disabled. The signal looked clean on the scope and will probably be suitable for use with the LTR analysis/tracking programs.
To get to the tap point the logic board must be removed and a wire soldered to R367. With apologies for the size of the file and the poor photography, the attached picture shows where to connect the tap.
blantonl
Founder and CEO
Staff member
Super Moderator
Dallas, TX
Could I possibly drive this with a TL082 op-amp hamcom interface (my legacy 2-level interface for trunker), vs the MAX level-convertor solution?
Also, is it the red wire in the center of the pic?
pro92b
Mutated Member
The tap point is the red wire in the center of the picture.
Your slicer should provide a quick way to get started. If the decoding accuracy is low you might try raising the 100K resistor at the input to 470K. This will reduce the loading on the radio and improve the low frequency response of the slicer which is important for LTR.
I'd be interested to hear if this set-up works well for you.
blantonl
Founder and CEO
Staff member
Super Moderator
Dallas, TX
I'll try to tackle this sometime this week.
Thanks for taking the initial step with the scope to see if this is feasible... I'll report back this week with updates.
-LB
blantonl
Founder and CEO
Staff member
Super Moderator
Dallas, TX
-LB
Right out of the box, with my existing TL slicer... this is working perfectly with 100% decode rates.
Outstanding!!!!
EricCottrell
Boston, Ma
Hello,
I was thinking of getting a MX05 or two for a standalone decoder.
You are going to find the LTR scene around San Antonio interesting.
http://www.radioreference.com/modules.php?name=Forums&file=viewtopic&t=10074
http://www.radioreference.com/modules.php?name=Forums&file=viewtopic&t=10461
Industrial Communications has a multi-site Passport system that may be a mixed Passport/Regular LTR system. Only some of the Regular LTR sites are in the TRSDB.
Hope your harmonic is doing well.
73 Eric
blantonl
Founder and CEO
Staff member
Super Moderator
Dallas, TX
I can confirm that Industrial indeed has a mixed Passport/Regular LTR system. It is crazy...!
Plus, we've got one system that "seems" to be a passport, yet, doesn't display anything on the 'ole trunker screen -- the spinner spins, yet nothing seems to be decoded.
More details to follow, I'm just now trying to get to the bottom of this. There are a number of networks here that we are trying to get a handle on.
EricCottrell
Boston, Ma
Hello,
On the system that is just spinning see what the ltrdump.txt log says when you run LTRDump on it. I tend to use LTRDump to figure stuff out first because I am still in "capture the data so I can figure this stuff out" mode.
Some of the check stuff are guesses so if the system uses a Digital Color Code (like the area bit) of 2 or 3 it may not work right. I also found LTRDump will not display the group 65535 which is used for CW ID. You may also find some Multinet packets mixed in which are not valid. I am fixing the problems and trying to make the type detection better.
I would be interested in some logs of mixed passport/regular LTR activity because this would be the first known system. I am wondering if the Passport and Regular LTR packets are interleaved. If so I can add some additional code to the program to handle it. The LTRDump display would be confusing if it was interleaved.
The Passport system in CT is all passport but it could be I am not listening on the right frequencies.
If someone could find Passport outside of 450 to 470 band that would be a plus as well. I need to see if the frequency band information is encoded in the data from the system.
Still alot of stuff to figure out.
73 Eric
pro92b
Mutated Member
The stuff off to the right connects to a board that forces the radio to power up in scan mode. There is a zip file on my webpage that shows all the details.
grant
Sydney, Australia
Eric
Have your managed to get LTRtrunk working OK - I tried running it when it first came out but it was "buggy" and I didn't perserve with it.
I am already running Opus' Ltrunk.exe programme with no problems on the low-pass discriminator on my 780 (with help from Opus).
Grant
DaveIN
Founders Curmudgen
West Michigan
Regular LTR with the Optocom
I have been somewhat successfull with LTRTrunk on a local 8 frequency Regular LTR multi-user system. Using the Optocom's stand alone memory operation I loaded all 8 frequencies and set it up for scan. After a few days I have over 300 talkgroups listed in the GRP file, but no radio id's file is created. Do I have it set up correctly? As it looks, Regular LTR systems have only home repeaters that are assigned to a LCN, so data bursts come from each home repeater and not one controller/frequency.
Shouldn't I see individual radio id's as well? The talkgroups also range above and below the home repeater number. The Area code is 0, Sys info:
Any thoughts :?: :roll:
MAP=55555555
OPTIONS=nVDF
PLAN=0
DESCR=LTR Regular
THRESHOLD=50
DISPOSITION=fvlxsr
v860.0125,2,ffff,28d
v854.6375,5,ffff,74
v859.0125,6,ffff,490
v858.0125,a,ffff,380c
v852.6625,d,ffff,1fe5
v857.0125,e,ffff,7465
v851.3875,f,ffff,d0
v856.0125,12,ffff,58d
;VER=3
;ID_hex,COLOR_dec,PRIO_dec,TITLE_str,LASTNOTED_hex,HITS_hex,USAGE_hex,ID_dec,ID_str,LASTNOTED_mm/dd/yyyy,LASTNOTED_hh:mm
000d,7,0,"?",410618ca,1,0,13, 0-013 000D,07/27/2004,04:56
0011,7,0,"?",41029de8,1,0,17, 0-017 0011,07/24/2004,13:35
0013,7,0,"?",4106978e,1,0,19, 0-019 0013,07/27/2004,13:57
0019,7,0,"?",4100953f,1,0,25, 0-025 0019,07/23/2004,00:34
0020,7,0,"?",41059396,2,0,32, 0-032 0020,07/26/2004,19:28
0024,7,0,"?",40fe6362,1,0,36, 0-036 0024,07/21/2004,08:36
0025,7,0,"?",410693fb,1,0,37, 0-037 0025,07/27/2004,13:42
0028,7,0,"?",4105c970,1,0,40, 0-040 0028,07/26/2004,23:18
0029,7,0,"?",41067d84,1,0,41, 0-041 0029,07/27/2004,12:06
002c,7,0,"?",40ff4a49,1,0,44, 0-044 002C,07/22/2004,01:02
0032,7,0,"?",41001db4,1,0,50, 0-050 0032,07/22/2004,16:04
0033,7,0,"?",41011ea6,1,0,51, 0-051 0033,07/23/2004,10:20
003d,7,0,"?",40fe8a8f,1,0,61, 0-061 003D,07/21/2004,11:23
0045,7,0,"?",410897b6,1,0,69, 0-069 0045,07/29/2004,02:22
0046,7,0,"?",4107f145,1,0,70, 0-070 0046,07/28/2004,14:32
0053,7,0,"?",4102420b,1,0,83, 0-083 0053,07/24/2004,07:03
0055,7,0,"?",4101b91e,2,0,85, 0-085 0055,07/23/2004,21:19
0058,7,0,"?",4106da1a,2,0,88, 0-088 0058,07/27/2004,18:41
005e,7,0,"?",41013679,1,0,94, 0-094 005E,07/23/2004,12:02
0060,7,0,"?",40fe7742,1,0,96, 0-096 0060,07/21/2004,10:01
0066,7,0,"?",41000b36,1,0,102, 0-102 0066,07/22/2004,14:45
0068,7,0,"?",410737a6,1,0,104, 0-104 0068,07/28/2004,01:20
007a,7,0,"?",4102fbf9,1,0,122, 0-122 007A,07/24/2004,20:16
007e,7,0,"?",40fe6098,1,0,126, 0-126 007E,07/21/2004,08:24
008a,7,0,"?",4100b91f,1,0,138, 0-138 008A,07/23/2004,03:07
008c,7,0,"?",41065d87,2,0,140, 0-140 008C,07/27/2004,09:49
0092,7,0,"?",40fea5fc,1,0,146, 0-146 0092,07/21/2004,13:21
0095,7,0,"?",41089d6c,1,0,149, 0-149 0095,07/29/2004,02:47
0099,7,0,"?",41086e09,1,0,153, 0-153 0099,07/28/2004,23:24
00a0,7,0,"?",40fe3f86,1,0,160, 0-160 00A0,07/21/2004,06:03
00ad,7,0,"?",4101f7d5,1,0,173, 0-173 00AD,07/24/2004,01:47
00b0,7,0,"?",4108b840,1,0,176, 0-176 00B0,07/29/2004,04:41
00c0,7,0,"?",410136f6,1,0,192, 0-192 00C0,07/23/2004,12:04
00c1,7,0,"?",41022316,1,0,193, 0-193 00C1,07/24/2004,04:51
00c2,7,0,"?",4106ff4f,1,0,194, 0-194 00C2,07/27/2004,21:20
00e0,7,0,"?",4101b7ef,1,0,224, 0-224 00E0,07/23/2004,21:14
00e5,7,0,"?",4105e17c,1,0,229, 0-229 00E5,07/27/2004,01:00
0100,7,0,"?",4107f4b3,1,0,256, 1-000 0100,07/28/2004,14:47
0102,7,0,"?",4101f940,1,0,258, 1-002 0102,07/24/2004,01:53
0105,7,0,"?",4105e8c1,1,0,261, 1-005 0105,07/27/2004,01:31
0106,7,0,"?",40fe4d23,1,0,262, 1-006 0106,07/21/2004,07:01
0109,7,0,"?",410125b8,1,0,265, 1-009 0109,07/23/2004,10:50
010d,7,0,"?",4106b028,1,0,269, 1-013 010D,07/27/2004,15:42
0112,7,0,"?",410054a4,1,0,274, 1-018 0112,07/22/2004,19:58
0114,7,0,"?",4107c838,1,0,276, 1-020 0114,07/28/2004,11:37
0117,7,0,"?",4108a3a8,1,0,279, 1-023 0117,07/29/2004,03:13
011b,7,0,"?",41087feb,1,0,283, 1-027 011B,07/29/2004,00:41
0123,7,0,"?",4105e339,1,0,291, 1-035 0123,07/27/2004,01:08
0128,7,0,"?",410842e6,1,0,296, 1-040 0128,07/28/2004,20:20
012a,7,0,"?",41069808,1,0,298, 1-042 012A,07/27/2004,13:59
012c,7,0,"?",40ff672a,1,0,300, 1-044 012C,07/22/2004,03:05
0141,7,0,"?",41034e32,1,0,321, 1-065 0141,07/25/2004,02:07
0142,7,0,"?",41019eee,1,0,322, 1-066 0142,07/23/2004,19:27
0144,7,0,"?",4100ea89,1,0,324, 1-068 0144,07/23/2004,06:38
0155,7,0,"?",4102050a,1,0,341, 1-085 0155,07/24/2004,02:43
0158,7,0,"?",41010053,1,0,344, 1-088 0158,07/23/2004,08:10
015e,7,0,"?",40fea904,1,0,350, 1-094 015E,07/21/2004,13:33
0165,7,0,"?",40ff63f6,1,0,357, 1-101 0165,07/22/2004,02:51
0174,7,0,"?",40ff57dc,1,0,372, 1-116 0174,07/22/2004,01:59
017e,7,0,"?",41064cd2,1,0,382, 1-126 017E,07/27/2004,08:38
0188,7,0,"?",4106fdbe,1,0,392, 1-136 0188,07/27/2004,21:13
0190,7,0,"?",410822c4,1,0,400, 1-144 0190,07/28/2004,18:03
01a4,7,0,"?",4100b3b9,2,0,420, 1-164 01A4,07/23/2004,02:44
01aa,7,0,"?",410616b3,1,0,426, 1-170 01AA,07/27/2004,04:47
01b5,7,0,"?",4100aae1,1,0,437, 1-181 01B5,07/23/2004,02:06
01c4,7,0,"?",41087e18,1,0,452, 1-196 01C4,07/29/2004,00:33
01ce,7,0,"?",4107c566,1,0,462, 1-206 01CE,07/28/2004,11:25
01eb,7,0,"?",410188ba,1,0,491, 1-235 01EB,07/23/2004,17:52
01f0,7,0,"?",410598d2,1,0,496, 1-240 01F0,07/26/2004,19:50
0201,7,0,"?",41088e0a,1,0,513, 2-001 0201,07/29/2004,01:41
0204,7,0,"?",410803b9,1,0,516, 2-004 0204,07/28/2004,15:51
0205,7,0,"?",4107bc0a,1,0,517, 2-005 0205,07/28/2004,10:45
0207,7,0,"?",4108b43d,1,0,519, 2-007 0207,07/29/2004,04:24
0208,7,0,"?",4106ac0f,1,0,520, 2-008 0208,07/27/2004,15:25
020a,7,0,"?",4101bf1e,1,0,522, 2-010 020A,07/23/2004,21:45
0210,7,0,"?",41035a67,2,0,528, 2-016 0210,07/25/2004,02:59
0222,7,0,"?",40ff9b67,1,0,546, 2-034 0222,07/22/2004,06:48
0224,7,0,"?",41031d55,1,0,548, 2-036 0224,07/24/2004,22:39
0225,7,0,"?",41067b7a,1,0,549, 2-037 0225,07/27/2004,11:57
0227,7,0,"?",4107b39e,1,0,551, 2-039 0227,07/28/2004,10:09
022d,7,0,"?",40ffd14a,1,0,557, 2-045 022D,07/22/2004,10:38
0231,7,0,"?",41013962,2,0,561, 2-049 0231,07/23/2004,12:14
0235,7,0,"?",4108263b,2,0,565, 2-053 0235,07/28/2004,18:18
0238,7,0,"?",40ffbd82,1,0,568, 2-056 0238,07/22/2004,09:13
0239,7,0,"?",41001aec,3,0,569, 2-057 0239,07/22/2004,15:52
023a,7,0,"?",410852da,1,0,570, 2-058 023A,07/28/2004,21:28
0249,7,0,"?",40fdf663,1,0,585, 2-073 0249,07/21/2004,00:51
0254,7,0,"?",410278ae,1,0,596, 2-084 0254,07/24/2004,10:56
025e,7,0,"?",4107e8b0,3,0,606, 2-094 025E,07/28/2004,13:56
0263,7,0,"?",410217ed,1,0,611, 2-099 0263,07/24/2004,04:03
0265,7,0,"?",40fea780,2,0,613, 2-101 0265,07/21/2004,13:27
026b,7,0,"?",40ff03b7,1,0,619, 2-107 026B,07/21/2004,20:00
026d,7,0,"?",40fea7ec,1,0,621, 2-109 026D,07/21/2004,13:29
0282,7,0,"?",4106359e,1,0,642, 2-130 0282,07/27/2004,06:59
0294,7,0,"?",40ff9b93,1,0,660, 2-148 0294,07/22/2004,06:48
02a5,7,0,"?",40ffd30d,1,0,677, 2-165 02A5,07/22/2004,10:45
02a6,7,0,"?",4100309d,1,0,678, 2-166 02A6,07/22/2004,17:24
02ac,7,0,"?",4101f528,1,0,684, 2-172 02AC,07/24/2004,01:35
02ad,7,0,"?",4100f580,1,0,685, 2-173 02AD,07/23/2004,07:24
02b3,7,0,"?",4108261f,2,0,691, 2-179 02B3,07/28/2004,18:18
02b7,7,0,"?",410320ab,1,0,695, 2-183 02B7,07/24/2004,22:53
02bc,7,0,"?",41066e7c,1,0,700, 2-188 02BC,07/27/2004,11:02
02c1,7,0,"?",41083efb,1,0,705, 2-193 02C1,07/28/2004,20:04
02d2,7,0,"?",4106917a,1,0,722, 2-210 02D2,07/27/2004,13:31
02d6,7,0,"?",410269a7,1,0,726, 2-214 02D6,07/24/2004,09:52
02da,7,0,"?",40fe6f2e,1,0,730, 2-218 02DA,07/21/2004,09:27
02db,7,0,"?",4102a413,1,0,731, 2-219 02DB,07/24/2004,14:01
02dc,7,0,"?",40ffc815,1,0,732, 2-220 02DC,07/22/2004,09:58
02e2,7,0,"?",41075a7c,1,0,738, 2-226 02E2,07/28/2004,03:49
02f0,7,0,"?",40ff0f75,1,0,752, 2-240 02F0,07/21/2004,20:51
0301,7,0,"?",4100782e,1,0,769, 3-001 0301,07/22/2004,22:30
0308,7,0,"?",410062e4,1,0,776, 3-008 0308,07/22/2004,20:59
030b,7,0,"?",4106e04f,2,0,779, 3-011 030B,07/27/2004,19:07
0310,7,0,"?",410899e6,2,0,784, 3-016 0310,07/29/2004,02:32
0313,7,0,"?",41074160,1,0,787, 3-019 0313,07/28/2004,02:02
0314,7,0,"?",41083925,1,0,788, 3-020 0314,07/28/2004,19:39
0316,7,0,"?",40ff461f,1,0,790, 3-022 0316,07/22/2004,00:44
0319,7,0,"?",40ff1419,1,0,793, 3-025 0319,07/21/2004,21:10
0321,7,0,"?",410264c4,1,0,801, 3-033 0321,07/24/2004,09:31
032c,7,0,"?",410361bc,2,0,812, 3-044 032C,07/25/2004,03:31
032e,7,0,"?",4101371f,1,0,814, 3-046 032E,07/23/2004,12:04
0339,7,0,"?",40fe7e25,1,0,825, 3-057 0339,07/21/2004,10:31
033e,7,0,"?",410786f7,2,0,830, 3-062 033E,07/28/2004,06:59
034c,7,0,"?",41083e2f,1,0,844, 3-076 034C,07/28/2004,20:00
0350,7,0,"?",4107b335,1,0,848, 3-080 0350,07/28/2004,10:07
0351,7,0,"?",4106630b,1,0,849, 3-081 0351,07/27/2004,10:13
0354,7,0,"?",4100d316,1,0,852, 3-084 0354,07/23/2004,04:57
0383,7,0,"?",41072021,1,0,899, 3-131 0383,07/27/2004,23:40
03a1,7,0,"?",41077f9f,1,0,929, 3-161 03A1,07/28/2004,06:27
03b4,7,0,"?",40fec8a2,1,0,948, 3-180 03B4,07/21/2004,15:48
03ef,7,0,"?",40fdf470,1,0,1007, 3-239 03EF,07/21/2004,00:43
03f0,7,0,"?",4100afcc,1,0,1008, 3-240 03F0,07/23/2004,02:27
040f,7,0,"?",41034992,1,0,1039, 4-015 040F,07/25/2004,01:48
0422,7,0,"?",4100098d,1,0,1058, 4-034 0422,07/22/2004,14:38
0426,7,0,"?",4105f6af,1,0,1062, 4-038 0426,07/27/2004,02:31
042b,7,0,"?",41072383,1,0,1067, 4-043 042B,07/27/2004,23:54
0430,7,0,"?",40ffd239,1,0,1072, 4-048 0430,07/22/2004,10:42
0435,7,0,"?",4108cad7,1,0,1077, 4-053 0435,07/29/2004,06:00
0444,7,0,"?",41017fb7,1,0,1092, 4-068 0444,07/23/2004,17:14
045a,7,0,"?",4103b004,2,0,1114, 4-090 045A,07/25/2004,09:05
045e,7,0,"?",40feb3ae,1,0,1118, 4-094 045E,07/21/2004,14:19
0461,7,0,"?",410260d0,1,0,1121, 4-097 0461,07/24/2004,09:14
0468,7,0,"?",41006438,1,0,1128, 4-104 0468,07/22/2004,21:04
046c,7,0,"?",4107cdf0,1,0,1132, 4-108 046C,07/28/2004,12:01
046e,7,0,"?",41019fff,1,0,1134, 4-110 046E,07/23/2004,19:32
0479,7,0,"?",4105c25c,1,0,1145, 4-121 0479,07/26/2004,22:47
047c,7,0,"?",4106e548,1,0,1148, 4-124 047C,07/27/2004,19:29
0480,7,0,"?",410195ef,1,0,1152, 4-128 0480,07/23/2004,18:49
0481,7,0,"?",41023cf4,1,0,1153, 4-129 0481,07/24/2004,06:41
0488,7,0,"?",4105efb1,2,0,1160, 4-136 0488,07/27/2004,02:01
04a2,7,0,"?",4106ebe9,1,0,1186, 4-162 04A2,07/27/2004,19:57
04ac,7,0,"?",4103b0b7,1,0,1196, 4-172 04AC,07/25/2004,09:08
04ae,7,0,"?",40feb1b2,1,0,1198, 4-174 04AE,07/21/2004,14:10
04ba,7,0,"?",40ff6fd2,1,0,1210, 4-186 04BA,07/22/2004,03:42
04c0,7,0,"?",41078369,1,0,1216, 4-192 04C0,07/28/2004,06:43
04c5,7,0,"?",4100ff21,1,0,1221, 4-197 04C5,07/23/2004,08:05
04c6,7,0,"?",4103b24e,1,0,1222, 4-198 04C6,07/25/2004,09:14
04d5,7,0,"?",41003ddb,1,0,1237, 4-213 04D5,07/22/2004,18:21
04d8,7,0,"?",4101789a,1,0,1240, 4-216 04D8,07/23/2004,16:44
04df,7,0,"?",41068df2,1,0,1247, 4-223 04DF,07/27/2004,13:16
04e9,7,0,"?",410623a5,1,0,1257, 4-233 04E9,07/27/2004,05:43
04f5,7,0,"?",4100fb72,1,0,1269, 4-245 04F5,07/23/2004,07:50
04fb,7,0,"?",41059bae,1,0,1275, 4-251 04FB,07/26/2004,20:02
0502,7,0,"?",4101274e,1,0,1282, 5-002 0502,07/23/2004,10:57
0505,7,0,"?",4100c0f9,1,0,1285, 5-005 0505,07/23/2004,03:40
0508,7,0,"?",4103bb4e,1,0,1288, 5-008 0508,07/25/2004,09:53
0518,7,0,"?",410195e0,4,0,1304, 5-024 0518,07/23/2004,18:49
0524,7,0,"?",4105c3ac,2,0,1316, 5-036 0524,07/26/2004,22:53
0528,7,0,"?",40ffb118,1,0,1320, 5-040 0528,07/22/2004,08:20
052b,7,0,"?",4108d5f2,1,0,1323, 5-043 052B,07/29/2004,06:48
052e,7,0,"?",41014a53,1,0,1326, 5-046 052E,07/23/2004,13:26
0532,7,0,"?",40ffc596,1,0,1330, 5-050 0532,07/22/2004,09:48
0539,7,0,"?",4101dfad,1,0,1337, 5-057 0539,07/24/2004,00:03
0544,7,0,"?",41066332,2,0,1348, 5-068 0544,07/27/2004,10:14
0550,7,0,"?",4100f21f,1,0,1360, 5-080 0550,07/23/2004,07:10
0552,7,0,"?",4100b63c,1,0,1362, 5-082 0552,07/23/2004,02:54
0554,7,0,"?",41029ef0,2,0,1364, 5-084 0554,07/24/2004,13:40
0558,7,0,"?",41028466,1,0,1368, 5-088 0558,07/24/2004,11:46
0559,7,0,"?",4103590a,1,0,1369, 5-089 0559,07/25/2004,02:54
0560,7,0,"?",41087087,1,0,1376, 5-096 0560,07/28/2004,23:35
0563,7,0,"?",4102177d,1,0,1379, 5-099 0563,07/24/2004,04:02
0564,7,0,"?",41063ecc,1,0,1380, 5-100 0564,07/27/2004,07:38
056b,7,0,"?",41065f7b,1,0,1387, 5-107 056B,07/27/2004,09:58
0583,7,0,"?",4107180c,1,0,1411, 5-131 0583,07/27/2004,23:05
0596,7,0,"?",41070f10,1,0,1430, 5-150 0596,07/27/2004,22:27
059b,7,0,"?",4107879e,1,0,1435, 5-155 059B,07/28/2004,07:01
05da,7,0,"?",4101e575,1,0,1498, 5-218 05DA,07/24/2004,00:28
05e4,7,0,"?",41037e7c,1,0,1508, 5-228 05E4,07/25/2004,05:33
05f4,7,0,"?",41088844,1,0,1524, 5-244 05F4,07/29/2004,01:16
0600,7,0,"?",4107e368,1,0,1536, 6-000 0600,07/28/2004,13:33
0603,7,0,"?",4107c13e,1,0,1539, 6-003 0603,07/28/2004,11:07
0610,7,0,"?",4107d63d,1,0,1552, 6-016 0610,07/28/2004,12:37
0614,7,0,"?",41013772,1,0,1556, 6-020 0614,07/23/2004,12:06
061c,7,0,"?",40feb52d,1,0,1564, 6-028 061C,07/21/2004,14:25
0623,7,0,"?",41065182,1,0,1571, 6-035 0623,07/27/2004,08:58
0624,7,0,"?",4107f388,1,0,1572, 6-036 0624,07/28/2004,14:42
0625,7,0,"?",4106c785,3,0,1573, 6-037 0625,07/27/2004,17:22
062b,7,0,"?",4102ee14,1,0,1579, 6-043 062B,07/24/2004,19:17
062d,7,0,"?",40ffb410,1,0,1581, 6-045 062D,07/22/2004,08:33
062f,7,0,"?",410116ce,1,0,1583, 6-047 062F,07/23/2004,09:46
0638,7,0,"?",4102cf55,1,0,1592, 6-056 0638,07/24/2004,17:06
0639,7,0,"?",410263d1,2,0,1593, 6-057 0639,07/24/2004,09:27
063b,7,0,"?",4107c3be,1,0,1595, 6-059 063B,07/28/2004,11:18
0644,7,0,"?",41000ace,1,0,1604, 6-068 0644,07/22/2004,14:43
0650,7,0,"?",40ff5edb,1,0,1616, 6-080 0650,07/22/2004,02:29
0656,7,0,"?",4107e859,1,0,1622, 6-086 0656,07/28/2004,13:54
0658,7,0,"?",41017660,1,0,1624, 6-088 0658,07/23/2004,16:34
065a,7,0,"?",4106b424,2,0,1626, 6-090 065A,07/27/2004,15:59
065e,7,0,"?",4106aaa9,3,0,1630, 6-094 065E,07/27/2004,15:19
0662,7,0,"?",410330a9,1,0,1634, 6-098 0662,07/25/2004,00:01
0663,7,0,"?",4102b003,1,0,1635, 6-099 0663,07/24/2004,14:52
066a,7,0,"?",41007814,1,0,1642, 6-106 066A,07/22/2004,22:29
066b,7,0,"?",4105ceb3,1,0,1643, 6-107 066B,07/26/2004,23:40
066e,7,0,"?",40ffbd1c,1,0,1646, 6-110 066E,07/22/2004,09:11
067d,7,0,"?",40fe67f7,1,0,1661, 6-125 067D,07/21/2004,08:56
0681,7,0,"?",4106f613,1,0,1665, 6-129 0681,07/27/2004,20:40
0683,7,0,"?",4108812d,1,0,1667, 6-131 0683,07/29/2004,00:46
0689,7,0,"?",4102b2f4,1,0,1673, 6-137 0689,07/24/2004,15:05
068d,7,0,"?",410159ed,1,0,1677, 6-141 068D,07/23/2004,14:33
068e,7,0,"?",41035fa6,1,0,1678, 6-142 068E,07/25/2004,03:22
0690,7,0,"?",4106620a,1,0,1680, 6-144 0690,07/27/2004,10:09
0698,7,0,"?",4102ce89,1,0,1688, 6-152 0698,07/24/2004,17:03
06a6,7,0,"?",410375d5,1,0,1702, 6-166 06A6,07/25/2004,04:56
06b8,7,0,"?",40fe92cf,1,0,1720, 6-184 06B8,07/21/2004,11:59
06bc,7,0,"?",40ff112e,1,0,1724, 6-188 06BC,07/21/2004,20:58
06be,7,0,"?",41080d54,1,0,1726, 6-190 06BE,07/28/2004,16:32
06c8,7,0,"?",4101a187,1,0,1736, 6-200 06C8,07/23/2004,19:38
06c9,7,0,"?",41031750,1,0,1737, 6-201 06C9,07/24/2004,22:13
06cb,7,0,"?",41066859,1,0,1739, 6-203 06CB,07/27/2004,10:36
06da,7,0,"?",40feb9c9,1,0,1754, 6-218 06DA,07/21/2004,14:45
0702,7,0,"?",40fffd90,1,0,1794, 7-002 0702,07/22/2004,13:46
0705,7,0,"?",40fecc8f,1,0,1797, 7-005 0705,07/21/2004,16:05
0712,7,0,"?",4107fb53,1,0,1810, 7-018 0712,07/28/2004,15:15
0716,7,0,"?",410640d2,1,0,1814, 7-022 0716,07/27/2004,07:47
0718,7,0,"?",41014be3,1,0,1816, 7-024 0718,07/23/2004,13:33
0719,7,0,"?",41014a67,1,0,1817, 7-025 0719,07/23/2004,13:27
071b,7,0,"?",41060223,1,0,1819, 7-027 071B,07/27/2004,03:20
0720,7,0,"?",4106b407,1,0,1824, 7-032 0720,07/27/2004,15:59
0721,7,0,"?",410030a9,1,0,1825, 7-033 0721,07/22/2004,17:24
0729,7,0,"?",40fe882a,1,0,1833, 7-041 0729,07/21/2004,11:13
072b,7,0,"?",4101bb6e,1,0,1835, 7-043 072B,07/23/2004,21:29
072e,7,0,"?",4107c413,1,0,1838, 7-046 072E,07/28/2004,11:19
072f,7,0,"?",4107c437,1,0,1839, 7-047 072F,07/28/2004,11:20
073a,7,0,"?",410664dd,1,0,1850, 7-058 073A,07/27/2004,10:21
0740,7,0,"?",4105abad,1,0,1856, 7-064 0740,07/26/2004,21:11
0751,7,0,"?",4106304b,1,0,1873, 7-081 0751,07/27/2004,06:36
075a,7,0,"?",4101421b,1,0,1882, 7-090 075A,07/23/2004,12:51
0760,7,0,"?",4100b478,1,0,1888, 7-096 0760,07/23/2004,02:47
0768,7,0,"?",41008ac7,1,0,1896, 7-104 0768,07/22/2004,23:49
077e,7,0,"?",40ff5a95,1,0,1918, 7-126 077E,07/22/2004,02:11
07b4,7,0,"?",4102b140,1,0,1972, 7-180 07B4,07/24/2004,14:58
07d3,7,0,"?",41089b3f,1,0,2003, 7-211 07D3,07/29/2004,02:37
07de,7,0,"?",4103498f,1,0,2014, 7-222 07DE,07/25/2004,01:47
07e7,7,0,"?",4107c293,1,0,2023, 7-231 07E7,07/28/2004,11:13
07ec,7,0,"?",40fe5d49,1,0,2028, 7-236 07EC,07/21/2004,08:10
0804,7,0,"?",4105e437,1,0,2052, 8-004 0804,07/27/2004,01:12
080a,7,0,"?",40febc5b,1,0,2058, 8-010 080A,07/21/2004,14:56
0810,7,0,"?",4108badd,1,0,2064, 8-016 0810,07/29/2004,04:52
0816,7,0,"?",410348a5,1,0,2070, 8-022 0816,07/25/2004,01:44
0820,7,0,"?",410210e7,1,0,2080, 8-032 0820,07/24/2004,03:33
0822,7,0,"?",41077cb9,2,0,2082, 8-034 0822,07/28/2004,06:15
0823,7,0,"?",4105d88a,1,0,2083, 8-035 0823,07/27/2004,00:22
0829,7,0,"?",40feb847,1,0,2089, 8-041 0829,07/21/2004,14:39
082b,7,0,"?",40ff9e93,1,0,2091, 8-043 082B,07/22/2004,07:01
0834,7,0,"?",4102b58f,1,0,2100, 8-052 0834,07/24/2004,15:16
083d,7,0,"?",4107e914,1,0,2109, 8-061 083D,07/28/2004,13:57
0841,7,0,"?",410659ac,1,0,2113, 8-065 0841,07/27/2004,09:33
084d,7,0,"?",410720f2,1,0,2125, 8-077 084D,07/27/2004,23:43
0859,7,0,"?",4100a946,1,0,2137, 8-089 0859,07/23/2004,01:59
085e,7,0,"?",4106995f,2,0,2142, 8-094 085E,07/27/2004,14:05
086f,7,0,"?",410123b6,1,0,2159, 8-111 086F,07/23/2004,10:41
0880,7,0,"?",4106d0bd,2,0,2176, 8-128 0880,07/27/2004,18:01
0882,7,0,"?",4105ed65,1,0,2178, 8-130 0882,07/27/2004,01:51
0894,7,0,"?",4105ddc0,1,0,2196, 8-148 0894,07/27/2004,00:44
0898,7,0,"?",4100f8f2,1,0,2200, 8-152 0898,07/23/2004,07:39
0899,7,0,"?",41071b49,1,0,2201, 8-153 0899,07/27/2004,23:19
089b,7,0,"?",40fff687,1,0,2203, 8-155 089B,07/22/2004,13:16
08a0,7,0,"?",4100cf49,1,0,2208, 8-160 08A0,07/23/2004,04:41
08aa,7,0,"?",41011950,2,0,2218, 8-170 08AA,07/23/2004,09:57
08b0,7,0,"?",41063309,1,0,2224, 8-176 08B0,07/27/2004,06:48
08c8,7,0,"?",40ffd437,1,0,2248, 8-200 08C8,07/22/2004,10:50
08de,7,0,"?",40fe6ef7,1,0,2270, 8-222 08DE,07/21/2004,09:26
08ed,7,0,"?",41075de4,1,0,2285, 8-237 08ED,07/28/2004,04:03
0901,7,0,"?",410678e8,1,0,2305, 9-001 0901,07/27/2004,11:46
0904,7,0,"?",410166b5,1,0,2308, 9-004 0904,07/23/2004,15:27
0909,7,0,"?",40ff692d,1,0,2313, 9-009 0909,07/22/2004,03:13
090c,7,0,"?",41000bed,1,0,2316, 9-012 090C,07/22/2004,14:48
0911,7,0,"?",41019656,1,0,2321, 9-017 0911,07/23/2004,18:51
0926,7,0,"?",4107a467,1,0,2342, 9-038 0926,07/28/2004,09:04
092a,7,0,"?",4105fec4,2,0,2346, 9-042 092A,07/27/2004,03:05
0932,7,0,"?",4100718d,1,0,2354, 9-050 0932,07/22/2004,22:01
0945,7,0,"?",40fe2ddb,1,0,2373, 9-069 0945,07/21/2004,04:48
094d,7,0,"?",41006767,1,0,2381, 9-077 094D,07/22/2004,21:18
0955,7,0,"?",4108d082,1,0,2389, 9-085 0955,07/29/2004,06:25
0960,7,0,"?",41076932,1,0,2400, 9-096 0960,07/28/2004,04:52
0966,7,0,"?",41063127,1,0,2406, 9-102 0966,07/27/2004,06:40
096a,7,0,"?",4102992b,2,0,2410, 9-106 096A,07/24/2004,13:15
0971,7,0,"?",40fe558b,1,0,2417, 9-113 0971,07/21/2004,07:37
0980,7,0,"?",4108276d,1,0,2432, 9-128 0980,07/28/2004,18:23
0983,7,0,"?",410263bf,1,0,2435, 9-131 0983,07/24/2004,09:27
0988,7,0,"?",41084403,1,0,2440, 9-136 0988,07/28/2004,20:25
098a,7,0,"?",4102d484,2,0,2442, 9-138 098A,07/24/2004,17:28
0994,7,0,"?",4107464c,1,0,2452, 9-148 0994,07/28/2004,02:23
09ab,7,0,"?",4105ac6d,2,0,2475, 9-171 09AB,07/26/2004,21:14
09b0,7,0,"?",4102b554,1,0,2480, 9-176 09B0,07/24/2004,15:15
09b8,7,0,"?",40fefd9f,1,0,2488, 9-184 09B8,07/21/2004,19:34
09bf,7,0,"?",40fe9a5c,1,0,2495, 9-191 09BF,07/21/2004,12:31
09e1,7,0,"?",410666ae,1,0,2529, 9-225 09E1,07/27/2004,10:29
0a00,7,0,"?",4106979b,1,0,2560,10-000 0A00,07/27/2004,13:57
0a01,7,0,"?",41082555,6,0,2561,10-001 0A01,07/28/2004,18:14
0a03,7,0,"?",41002955,1,0,2563,10-003 0A03,07/22/2004,16:53
0a05,7,0,"?",410285b7,3,0,2565,10-005 0A05,07/24/2004,11:52
0a06,7,0,"?",4102c635,1,0,2566,10-006 0A06,07/24/2004,16:27
0a07,7,0,"?",40ffe40b,1,0,2567,10-007 0A07,07/22/2004,11:58
0a0a,7,0,"?",41079b55,1,0,2570,10-010 0A0A,07/28/2004,08:25
0a0b,7,0,"?",4102348d,1,0,2571,10-011 0A0B,07/24/2004,06:06
0a11,7,0,"?",41019898,2,0,2577,10-017 0A11,07/23/2004,19:00
0a15,7,0,"?",4102c5ef,1,0,2581,10-021 0A15,07/24/2004,16:26
0a1e,7,0,"?",4107e824,1,0,2590,10-030 0A1E,07/28/2004,13:53
0a1f,7,0,"?",410803b5,1,0,2591,10-031 0A1F,07/28/2004,15:51
0a20,7,0,"?",4100b449,1,0,2592,10-032 0A20,07/23/2004,02:46
0a23,7,0,"?",40fe6479,1,0,2595,10-035 0A23,07/21/2004,08:41
0a25,7,0,"?",410650d3,4,0,2597,10-037 0A25,07/27/2004,08:55
0a26,7,0,"?",4101551f,1,0,2598,10-038 0A26,07/23/2004,14:12
0a27,7,0,"?",41015d7b,1,0,2599,10-039 0A27,07/23/2004,14:48
0a28,7,0,"?",4106b0da,1,0,2600,10-040 0A28,07/27/2004,15:45
0a29,7,0,"?",41082655,2,0,2601,10-041 0A29,07/28/2004,18:19
0a2d,7,0,"?",41016ad2,1,0,2605,10-045 0A2D,07/23/2004,15:45
0a2e,7,0,"?",4107f65b,2a,0,2606,10-046 0A2E,07/28/2004,14:54
0a2f,7,0,"?",4102f36c,1,0,2607,10-047 0A2F,07/24/2004,19:40
0a31,7,0,"?",41082848,2bf,0,2609,10-049 0A31,07/28/2004,18:27
0a32,7,0,"?",4107f0a4,3,0,2610,10-050 0A32,07/28/2004,14:29
0a35,7,0,"?",41019656,1,0,2613,10-053 0A35,07/23/2004,18:51
0a38,7,0,"?",4101795a,1,0,2616,10-056 0A38,07/23/2004,16:47
0a39,7,0,"?",41001f5d,3,0,2617,10-057 0A39,07/22/2004,16:11
0a3b,7,0,"?",4108071e,1,0,2619,10-059 0A3B,07/28/2004,16:05
0a3f,7,0,"?",41013734,1,0,2623,10-063 0A3F,07/23/2004,12:05
0a40,7,0,"?",41028455,1,0,2624,10-064 0A40,07/24/2004,11:46
0a41,7,0,"?",41020d0f,1,0,2625,10-065 0A41,07/24/2004,03:17
0a43,7,0,"?",410803e2,53,0,2627,10-067 0A43,07/28/2004,15:52
0a45,7,0,"?",41002e84,1,0,2629,10-069 0A45,07/22/2004,17:15
0a51,7,0,"?",40ffdd50,1,0,2641,10-081 0A51,07/22/2004,11:29
0a53,7,0,"?",410803e1,1,0,2643,10-083 0A53,07/28/2004,15:52
0a54,7,0,"?",41001bdf,1,0,2644,10-084 0A54,07/22/2004,15:56
0a55,7,0,"?",41015c47,3,0,2645,10-085 0A55,07/23/2004,14:43
0a56,7,0,"?",41080f1c,40,0,2646,10-086 0A56,07/28/2004,16:39
0a58,7,0,"?",41080c2e,2,0,2648,10-088 0A58,07/28/2004,16:27
0a59,7,0,"?",410737c8,1,0,2649,10-089 0A59,07/28/2004,01:21
0a5a,7,0,"?",41067494,1,0,2650,10-090 0A5A,07/27/2004,11:28
0a5c,7,0,"?",4100217e,2,0,2652,10-092 0A5C,07/22/2004,16:20
0a5e,7,0,"?",4107c9f5,1,0,2654,10-094 0A5E,07/28/2004,11:44
0a61,7,0,"?",41066f6c,2,0,2657,10-097 0A61,07/27/2004,11:06
0a64,7,0,"?",41001e7d,1,0,2660,10-100 0A64,07/22/2004,16:07
0a65,7,0,"?",4108d3a5,d2,0,2661,10-101 0A65,07/29/2004,06:38
0a66,7,0,"?",410171fc,1,0,2662,10-102 0A66,07/23/2004,16:15
0a6c,7,0,"?",41080dc1,1,0,2668,10-108 0A6C,07/28/2004,16:34
0a6d,7,0,"?",410650df,1,0,2669,10-109 0A6D,07/27/2004,08:55
0a72,7,0,"?",40fe83d0,1,0,2674,10-114 0A72,07/21/2004,10:55
0a73,7,0,"?",410825c8,1,0,2675,10-115 0A73,07/28/2004,18:16
0a74,7,0,"?",4102d31b,1,0,2676,10-116 0A74,07/24/2004,17:22
0a77,7,0,"?",41061a81,1,0,2679,10-119 0A77,07/27/2004,05:04
0a78,7,0,"?",41067c4f,1,0,2680,10-120 0A78,07/27/2004,12:01
0a79,7,0,"?",41014a92,2,0,2681,10-121 0A79,07/23/2004,13:27
0a7a,7,0,"?",40fffefe,1,0,2682,10-122 0A7A,07/22/2004,13:53
0a7b,7,0,"?",41080513,1,0,2683,10-123 0A7B,07/28/2004,15:57
0a7d,7,0,"?",4107aa14,1,0,2685,10-125 0A7D,07/28/2004,09:28
0a85,7,0,"?",410176c5,1,0,2693,10-133 0A85,07/23/2004,16:36
0a9c,7,0,"?",4101a871,1,0,2716,10-156 0A9C,07/23/2004,20:08
0aa0,7,0,"?",410159bf,2,0,2720,10-160 0AA0,07/23/2004,14:32
0aa5,7,0,"?",40ffc91c,1,0,2725,10-165 0AA5,07/22/2004,10:03
0aa7,7,0,"?",4107fbd0,1,0,2727,10-167 0AA7,07/28/2004,15:17
0aa8,7,0,"?",40fe6cb0,1,0,2728,10-168 0AA8,07/21/2004,09:16
0aaa,7,0,"?",4108215b,4a,0,2730,10-170 0AAA,07/28/2004,17:57
0ab3,7,0,"?",41078c99,1,0,2739,10-179 0AB3,07/28/2004,07:23
0ab7,7,0,"?",41080381,2,0,2743,10-183 0AB7,07/28/2004,15:50
0ad3,7,0,"?",41063dd0,1,0,2771,10-211 0AD3,07/27/2004,07:34
0ada,7,0,"?",40fffed0,1,0,2778,10-218 0ADA,07/22/2004,13:52
0ae3,7,0,"?",4107aa7a,1,0,2787,10-227 0AE3,07/28/2004,09:30
0ae5,7,0,"?",41074a50,1,0,2789,10-229 0AE5,07/28/2004,02:40
0aec,7,0,"?",410803fc,1,0,2796,10-236 0AEC,07/28/2004,15:52
0af0,7,0,"?",41069d1a,1,0,2800,10-240 0AF0,07/27/2004,14:21
0af1,7,0,"?",41081181,1,0,2801,10-241 0AF1,07/28/2004,16:50
0af9,7,0,"?",410811b9,60,0,2809,10-249 0AF9,07/28/2004,16:51
0afa,7,0,"?",41067c84,c,0,2810,10-250 0AFA,07/27/2004,12:02
0afb,7,0,"?",40ffc802,1,0,2811,10-251 0AFB,07/22/2004,09:58
0b01,7,0,"?",40fe6c87,1,0,2817,11-001 0B01,07/21/2004,09:15
0b07,7,0,"?",41011a88,2,0,2823,11-007 0B07,07/23/2004,10:02
0b12,7,0,"?",41012203,1,0,2834,11-018 0B12,07/23/2004,10:34
0b13,7,0,"?",41068fc2,2,0,2835,11-019 0B13,07/27/2004,13:24
0b18,7,0,"?",4101f86c,1,0,2840,11-024 0B18,07/24/2004,01:49
0b29,7,0,"?",41070c71,1,0,2857,11-041 0B29,07/27/2004,22:16
0b2c,7,0,"?",41026632,1,0,2860,11-044 0B2C,07/24/2004,09:37
0b31,7,0,"?",410025fb,1,0,2865,11-049 0B31,07/22/2004,16:39
0b32,7,0,"?",41082839,1,0,2866,11-050 0B32,07/28/2004,18:27
0b34,7,0,"?",40fff181,1,0,2868,11-052 0B34,07/22/2004,12:55
0b35,7,0,"?",41024acb,1,0,2869,11-053 0B35,07/24/2004,07:40
0b3d,7,0,"?",4101dc94,1,0,2877,11-061 0B3D,07/23/2004,23:50
0b40,7,0,"?",4102f5c1,1,0,2880,11-064 0B40,07/24/2004,19:50
0b42,7,0,"?",40feca2d,1,0,2882,11-066 0B42,07/21/2004,15:55
0b43,7,0,"?",4106cc0a,1,0,2883,11-067 0B43,07/27/2004,17:41
0b46,7,0,"?",40fed2e9,1,0,2886,11-070 0B46,07/21/2004,16:32
0b53,7,0,"?",4107e668,1,0,2899,11-083 0B53,07/28/2004,13:46
0b59,7,0,"?",4108037b,1,0,2905,11-089 0B59,07/28/2004,15:50
0b64,7,0,"?",41032ead,1,0,2916,11-100 0B64,07/24/2004,23:53
0b65,7,0,"?",40ffe22b,1,0,2917,11-101 0B65,07/22/2004,11:50
0ba1,7,0,"?",4102522c,1,0,2977,11-161 0BA1,07/24/2004,08:12
0bae,7,0,"?",4100f994,1,0,2990,11-174 0BAE,07/23/2004,07:42
0bc6,7,0,"?",410652ee,1,0,3014,11-198 0BC6,07/27/2004,09:04
0bd0,7,0,"?",4103561f,1,0,3024,11-208 0BD0,07/25/2004,02:41
0be6,7,0,"?",4107b46b,1,0,3046,11-230 0BE6,07/28/2004,10:12
0bf1,7,0,"?",41010bc9,2,0,3057,11-241 0BF1,07/23/2004,08:59
0bf7,7,0,"?",410000a6,1,0,3063,11-247 0BF7,07/22/2004,14:00
0c06,7,0,"?",41015e6b,1,0,3078,12-006 0C06,07/23/2004,14:52
0c08,7,0,"?",410776ff,1,0,3080,12-008 0C08,07/28/2004,05:50
0c0c,7,0,"?",41065f65,1,0,3084,12-012 0C0C,07/27/2004,09:57
0c0d,7,0,"?",40feccbd,1,0,3085,12-013 0C0D,07/21/2004,16:06
0c12,7,0,"?",410672b0,1,0,3090,12-018 0C12,07/27/2004,11:20
0c16,7,0,"?",4106cbed,1,0,3094,12-022 0C16,07/27/2004,17:41
0c2a,7,0,"?",4107a182,1,0,3114,12-042 0C2A,07/28/2004,08:52
0c2c,7,0,"?",4107b190,1,0,3116,12-044 0C2C,07/28/2004,10:00
0c2d,7,0,"?",40feb502,1,0,3117,12-045 0C2D,07/21/2004,14:25
0c2e,7,0,"?",40fe5f2b,1,0,3118,12-046 0C2E,07/21/2004,08:18
0c31,7,0,"?",40fe9adb,1,0,3121,12-049 0C31,07/21/2004,12:33
0c38,7,0,"?",4106b44a,1,0,3128,12-056 0C38,07/27/2004,16:00
0c3a,7,0,"?",4100cf0f,1,0,3130,12-058 0C3A,07/23/2004,04:40
0c40,7,0,"?",4108d620,1,0,3136,12-064 0C40,07/29/2004,06:49
0c44,7,0,"?",41014ada,1,0,3140,12-068 0C44,07/23/2004,13:28
0c48,7,0,"?",40ff4865,1,0,3144,12-072 0C48,07/22/2004,00:53
0c51,7,0,"?",4101679f,1,0,3153,12-081 0C51,07/23/2004,15:31
0c56,7,0,"?",41015104,1,0,3158,12-086 0C56,07/23/2004,13:55
0c57,7,0,"?",41011743,1,0,3159,12-087 0C57,07/23/2004,09:48
0c5e,7,0,"?",4107b3a7,5,0,3166,12-094 0C5E,07/28/2004,10:09
0c5f,7,0,"?",41069979,2,0,3167,12-095 0C5F,07/27/2004,14:05
0c92,7,0,"?",4106161d,1,0,3218,12-146 0C92,07/27/2004,04:45
0c9f,7,0,"?",40ffa32d,1,0,3231,12-159 0C9F,07/22/2004,07:21
0cac,7,0,"?",4108ab6c,3,0,3244,12-172 0CAC,07/29/2004,03:46
0cad,7,0,"?",40ffbccc,1,0,3245,12-173 0CAD,07/22/2004,09:10
0cb4,7,0,"?",40fe7e61,1,0,3252,12-180 0CB4,07/21/2004,10:32
0cb9,7,0,"?",410601de,1,0,3257,12-185 0CB9,07/27/2004,03:18
0cc8,7,0,"?",40ffce09,1,0,3272,12-200 0CC8,07/22/2004,10:24
0ccd,7,0,"?",40ffe030,1,0,3277,12-205 0CCD,07/22/2004,11:41
0cce,7,0,"?",40fdd148,1,0,3278,12-206 0CCE,07/20/2004,22:13
0cde,7,0,"?",40fe66e1,2,0,3294,12-222 0CDE,07/21/2004,08:51
0cea,7,0,"?",40ffa439,1,0,3306,12-234 0CEA,07/22/2004,07:25
0d09,7,0,"?",4105de3a,1,0,3337,13-009 0D09,07/27/2004,00:46
0d0b,7,0,"?",40fe07c9,1,0,3339,13-011 0D0B,07/21/2004,02:06
0d11,7,0,"?",40ffb1f8,1,0,3345,13-017 0D11,07/22/2004,08:24
0d12,7,0,"?",41018d23,1,0,3346,13-018 0D12,07/23/2004,18:11
0d18,7,0,"?",4101ffc5,1,0,3352,13-024 0D18,07/24/2004,02:20
0d1d,7,0,"?",4102f4c3,1,0,3357,13-029 0D1D,07/24/2004,19:46
0d20,7,0,"?",410279ab,1,0,3360,13-032 0D20,07/24/2004,11:00
0d26,7,0,"?",40fed059,1,0,3366,13-038 0D26,07/21/2004,16:21
0d2b,7,0,"?",4105e62a,1,0,3371,13-043 0D2B,07/27/2004,01:20
0d41,7,0,"?",4102e2a7,1,0,3393,13-065 0D41,07/24/2004,18:28
0d42,7,0,"?",41039706,1,0,3394,13-066 0D42,07/25/2004,07:18
0d44,7,0,"?",4108a625,1,0,3396,13-068 0D44,07/29/2004,03:24
0d4c,7,0,"?",41039aea,1,0,3404,13-076 0D4C,07/25/2004,07:35
0d50,7,0,"?",4108ab51,24f,0,3408,13-080 0D50,07/29/2004,03:46
0d51,7,0,"?",4101577d,3,0,3409,13-081 0D51,07/23/2004,14:22
0d52,7,0,"?",4106a6ae,3,0,3410,13-082 0D52,07/27/2004,15:02
0d53,7,0,"?",41065f22,1,0,3411,13-083 0D53,07/27/2004,09:56
0d54,7,0,"?",410389bc,1,0,3412,13-084 0D54,07/25/2004,06:21
0d55,7,0,"?",4106f8b0,1,0,3413,13-085 0D55,07/27/2004,20:52
0d56,7,0,"?",41063bb0,1,0,3414,13-086 0D56,07/27/2004,07:25
0d58,7,0,"?",4100f21a,1,0,3416,13-088 0D58,07/23/2004,07:10
0d5c,7,0,"?",41010e1d,1,0,3420,13-092 0D5C,07/23/2004,09:09
0d60,7,0,"?",4105c15c,2,0,3424,13-096 0D60,07/26/2004,22:43
0d64,7,0,"?",4107d153,103,0,3428,13-100 0D64,07/28/2004,12:16
0d65,7,0,"?",41063f0f,1,0,3429,13-101 0D65,07/27/2004,07:39
0d69,7,0,"?",40feaecc,1,0,3433,13-105 0D69,07/21/2004,13:58
0d6c,7,0,"?",4107d153,1,0,3436,13-108 0D6C,07/28/2004,12:16
0d75,7,0,"?",4108003f,1,0,3445,13-117 0D75,07/28/2004,15:36
0d76,7,0,"?",4106d2ef,3,0,3446,13-118 0D76,07/27/2004,18:10
0d7d,7,0,"?",40ffd4dd,1,0,3453,13-125 0D7D,07/22/2004,10:53
0d82,7,0,"?",4100222c,1,0,3458,13-130 0D82,07/22/2004,16:23
0d93,7,0,"?",40ff262c,1,0,3475,13-147 0D93,07/21/2004,22:27
0da4,7,0,"?",410044d0,1,0,3492,13-164 0DA4,07/22/2004,18:50
0da9,7,0,"?",40ffe01f,2,0,3497,13-169 0DA9,07/22/2004,11:41
0dc5,7,0,"?",4107eb46,1,0,3525,13-197 0DC5,07/28/2004,14:07
0dec,7,0,"?",4102ea3f,1,0,3564,13-236 0DEC,07/24/2004,19:01
0df2,7,0,"?",41011672,1,0,3570,13-242 0DF2,07/23/2004,09:45
0e00,7,0,"?",40ffb7a4,1,0,3584,14-000 0E00,07/22/2004,08:48
0e03,7,0,"?",41069fce,2,0,3587,14-003 0E03,07/27/2004,14:32
0e04,7,0,"?",4107e930,2,0,3588,14-004 0E04,07/28/2004,13:58
0e05,7,0,"?",40fe72f4,1,0,3589,14-005 0E05,07/21/2004,09:43
0e06,7,0,"?",4107a0be,1,0,3590,14-006 0E06,07/28/2004,08:49
0e0a,7,0,"?",4107a0ba,1,0,3594,14-010 0E0A,07/28/2004,08:48
0e0c,7,0,"?",4106a374,1,0,3596,14-012 0E0C,07/27/2004,14:48
0e15,7,0,"?",410173a4,2,0,3605,14-021 0E15,07/23/2004,16:23
0e1e,7,0,"?",410675c9,2,0,3614,14-030 0E1E,07/27/2004,11:33
0e21,7,0,"?",41064276,2,0,3617,14-033 0E21,07/27/2004,07:54
0e23,7,0,"?",4108096f,108,0,3619,14-035 0E23,07/28/2004,16:15
0e24,7,0,"?",4106a3e9,9,0,3620,14-036 0E24,07/27/2004,14:50
0e25,7,0,"?",4108124f,2bf,0,3621,14-037 0E25,07/28/2004,16:53
0e27,7,0,"?",4107c75c,4,0,3623,14-039 0E27,07/28/2004,11:33
0e29,7,0,"?",410787d5,e,0,3625,14-041 0E29,07/28/2004,07:02
0e2b,7,0,"?",41012f8d,2,0,3627,14-043 0E2B,07/23/2004,11:32
0e2c,7,0,"?",4107f827,2,0,3628,14-044 0E2C,07/28/2004,15:01
0e2d,7,0,"?",4108367e,1fd,0,3629,14-045 0E2D,07/28/2004,19:27
0e30,7,0,"?",41023d5a,2,0,3632,14-048 0E30,07/24/2004,06:43
0e31,7,0,"?",4107f1ed,6,0,3633,14-049 0E31,07/28/2004,14:35
0e33,7,0,"?",4107ffb6,b1,0,3635,14-051 0E33,07/28/2004,15:34
0e35,7,0,"?",41013782,2,0,3637,14-053 0E35,07/23/2004,12:06
0e3b,7,0,"?",4106b6a0,2,0,3643,14-059 0E3B,07/27/2004,16:10
0e3d,7,0,"?",4107ed64,3,0,3645,14-061 0E3D,07/28/2004,14:16
0e40,7,0,"?",410802c9,e,0,3648,14-064 0E40,07/28/2004,15:47
0e44,7,0,"?",41080b4d,a9,0,3652,14-068 0E44,07/28/2004,16:23
0e45,7,0,"?",4101405f,1,0,3653,14-069 0E45,07/23/2004,12:44
0e48,7,0,"?",4107f9ce,1c,0,3656,14-072 0E48,07/28/2004,15:09
0e4a,7,0,"?",41068a53,2,0,3658,14-074 0E4A,07/27/2004,13:01
0e4c,7,0,"?",41000041,1,0,3660,14-076 0E4C,07/22/2004,13:58
0e4f,7,0,"?",4106a982,2,0,3663,14-079 0E4F,07/27/2004,15:14
0e53,7,0,"?",4107aac3,1,0,3667,14-083 0E53,07/28/2004,09:31
0e54,7,0,"?",4106950c,1,0,3668,14-084 0E54,07/27/2004,13:46
0e56,7,0,"?",41067957,5,0,3670,14-086 0E56,07/27/2004,11:48
0e57,7,0,"?",41068006,1,0,3671,14-087 0E57,07/27/2004,12:17
0e58,7,0,"?",4106b473,5,0,3672,14-088 0E58,07/27/2004,16:00
0e5a,7,0,"?",41064cd6,1,0,3674,14-090 0E5A,07/27/2004,08:38
0e5b,7,0,"?",40ffbd21,1,0,3675,14-091 0E5B,07/22/2004,09:12
0e5c,7,0,"?",4106b44b,2,0,3676,14-092 0E5C,07/27/2004,16:00
0e5e,7,0,"?",41080e1b,34b,0,3678,14-094 0E5E,07/28/2004,16:35
0e5f,7,0,"?",41080c84,2,0,3679,14-095 0E5F,07/28/2004,16:28
0e60,7,0,"?",4101248c,2,0,3680,14-096 0E60,07/23/2004,10:45
0e61,7,0,"?",4107d1f8,1,0,3681,14-097 0E61,07/28/2004,12:19
0e63,7,0,"?",40fe93c7,1,0,3683,14-099 0E63,07/21/2004,12:03
0e64,7,0,"?",41080f50,1,0,3684,14-100 0E64,07/28/2004,16:40
0e6d,7,0,"?",41068e67,2,0,3693,14-109 0E6D,07/27/2004,13:18
0e6e,7,0,"?",4107f8e8,2,0,3694,14-110 0E6E,07/28/2004,15:05
0e71,7,0,"?",40fff76f,1,0,3697,14-113 0E71,07/22/2004,13:20
0e73,7,0,"?",410017af,1,0,3699,14-115 0E73,07/22/2004,15:38
0e76,7,0,"?",41034008,1,0,3702,14-118 0E76,07/25/2004,01:07
0e77,7,0,"?",40ffe07e,1,0,3703,14-119 0E77,07/22/2004,11:42
0e7e,7,0,"?",40fe712c,1,0,3710,14-126 0E7E,07/21/2004,09:35
0e80,7,0,"?",40fe9175,1,0,3712,14-128 0E80,07/21/2004,11:53
0e85,7,0,"?",41080491,1,0,3717,14-133 0E85,07/28/2004,15:54
0e8a,7,0,"?",40fea4bf,1,0,3722,14-138 0E8A,07/21/2004,13:15
0e8e,7,0,"?",4101018c,1,0,3726,14-142 0E8E,07/23/2004,08:16
0e93,7,0,"?",4107ce96,1,0,3731,14-147 0E93,07/28/2004,12:04
0e97,7,0,"?",4100118e,1,0,3735,14-151 0E97,07/22/2004,15:12
0e9a,7,0,"?",40fe587d,1,0,3738,14-154 0E9A,07/21/2004,07:50
0ea3,7,0,"?",4107fa1a,1,0,3747,14-163 0EA3,07/28/2004,15:10
0ea4,7,0,"?",41018953,1,0,3748,14-164 0EA4,07/23/2004,17:55
0ea5,7,0,"?",410143b7,3,0,3749,14-165 0EA5,07/23/2004,12:58
0ea9,7,0,"?",410195f1,1,0,3753,14-169 0EA9,07/23/2004,18:49
0eac,7,0,"?",410893e0,1,0,3756,14-172 0EAC,07/29/2004,02:06
0ead,7,0,"?",41078cf2,3,0,3757,14-173 0EAD,07/28/2004,07:24
0eb1,7,0,"?",41019800,1,0,3761,14-177 0EB1,07/23/2004,18:58
0eb9,7,0,"?",41016cc8,1,0,3769,14-185 0EB9,07/23/2004,15:53
0ec4,7,0,"?",40fe5eb1,1,0,3780,14-196 0EC4,07/21/2004,08:16
0ec5,7,0,"?",40fe7c98,1,0,3781,14-197 0EC5,07/21/2004,10:24
0eca,7,0,"?",410140ce,1,0,3786,14-202 0ECA,07/23/2004,12:46
0ed2,7,0,"?",41062241,2,0,3794,14-210 0ED2,07/27/2004,05:37
0ed8,7,0,"?",4107f358,1,0,3800,14-216 0ED8,07/28/2004,14:41
0eda,7,0,"?",4107e853,1,0,3802,14-218 0EDA,07/28/2004,13:54
0ede,7,0,"?",4107f8db,3,0,3806,14-222 0EDE,07/28/2004,15:04
0ee2,7,0,"?",410801be,1,0,3810,14-226 0EE2,07/28/2004,15:42
0ee9,7,0,"?",4107ed67,1,0,3817,14-233 0EE9,07/28/2004,14:16
0eec,7,0,"?",4100f7c5,1,0,3820,14-236 0EEC,07/23/2004,07:34
0eed,7,0,"?",40fe7eaf,1,0,3821,14-237 0EED,07/21/2004,10:33
0ef2,7,0,"?",40feaaa8,1,0,3826,14-242 0EF2,07/21/2004,13:40
0ef3,7,0,"?",410792d0,1,0,3827,14-243 0EF3,07/28/2004,07:49
0ef9,7,0,"?",41069df4,1,0,3833,14-249 0EF9,07/27/2004,14:24
0efb,7,0,"?",41080566,1,0,3835,14-251 0EFB,07/28/2004,15:58
0f00,7,0,"?",4108adcb,3,0,3840,15-000 0F00,07/29/2004,03:56
0f0f,7,0,"?",40ffc6b4,1,0,3855,15-015 0F0F,07/22/2004,09:52
0f10,7,0,"?",410804ab,1,0,3856,15-016 0F10,07/28/2004,15:55
0f12,7,0,"?",4108391f,3,0,3858,15-018 0F12,07/28/2004,19:39
0f16,7,0,"?",4107c79b,1,0,3862,15-022 0F16,07/28/2004,11:34
0f22,7,0,"?",41001d59,1,0,3874,15-034 0F22,07/22/2004,16:02
0f27,7,0,"?",41067ea5,1,0,3879,15-039 0F27,07/27/2004,12:11
0f2d,7,0,"?",4107c57c,3,0,3885,15-045 0F2D,07/28/2004,11:25
0f33,7,0,"?",41065f7f,2,0,3891,15-051 0F33,07/27/2004,09:58
0f40,7,0,"?",4105f3ac,1,0,3904,15-064 0F40,07/27/2004,02:18
0f4a,7,0,"?",41016a9b,1,0,3914,15-074 0F4A,07/23/2004,15:44
0f4e,7,0,"?",4107f6a8,1,0,3918,15-078 0F4E,07/28/2004,14:55
0f51,7,0,"?",4102b9ff,1,0,3921,15-081 0F51,07/24/2004,15:35
0f56,7,0,"?",41017677,1,0,3926,15-086 0F56,07/23/2004,16:35
0f5c,7,0,"?",40fe46bd,1,0,3932,15-092 0F5C,07/21/2004,06:34
0f5e,7,0,"?",4106b3f9,2,0,3934,15-094 0F5E,07/27/2004,15:58
0f91,7,0,"?",4107cfe8,1,0,3985,15-145 0F91,07/28/2004,12:10
0f9a,7,0,"?",4107f6c2,1,0,3994,15-154 0F9A,07/28/2004,14:56
0fd3,7,0,"?",40fe9af3,1,0,4051,15-211 0FD3,07/21/2004,12:33
0fd4,7,0,"?",40ffa338,1,0,4052,15-212 0FD4,07/22/2004,07:21
0fe5,7,0,"?",4106a3f5,2,0,4069,15-229 0FE5,07/27/2004,14:50
0fed,7,0,"?",4106bb91,1,0,4077,15-237 0FED,07/27/2004,16:31
1000,7,0,"?",41089a18,8,0,4096,16-000 1000,07/29/2004,02:32
1005,7,0,"?",4100106b,1,0,4101,16-005 1005,07/22/2004,15:07
1006,7,0,"?",40fed8ac,1,0,4102,16-006 1006,07/21/2004,16:57
1010,7,0,"?",40fe4d5c,1,0,4112,16-016 1010,07/21/2004,07:02
1012,7,0,"?",4102ebbc,1,0,4114,16-018 1012,07/24/2004,19:07
1022,7,0,"?",40fecc4d,1,0,4130,16-034 1022,07/21/2004,16:04
1025,7,0,"?",410693b9,1,0,4133,16-037 1025,07/27/2004,13:41
1027,7,0,"?",4102abca,1,0,4135,16-039 1027,07/24/2004,14:34
102c,7,0,"?",41036daf,1,0,4140,16-044 102C,07/25/2004,04:22
1041,7,0,"?",40feff3a,1,0,4161,16-065 1041,07/21/2004,19:41
104b,7,0,"?",4101542b,1,0,4171,16-075 104B,07/23/2004,14:08
104c,7,0,"?",410842d7,1,0,4172,16-076 104C,07/28/2004,20:20
1060,7,0,"?",40ff27a0,1,0,4192,16-096 1060,07/21/2004,22:34
1064,7,0,"?",410835ec,1,0,4196,16-100 1064,07/28/2004,19:25
1067,7,0,"?",41073a26,1,0,4199,16-103 1067,07/28/2004,01:31
1077,7,0,"?",41018bc4,2,0,4215,16-119 1077,07/23/2004,18:05
1083,7,0,"?",4105d103,1,0,4227,16-131 1083,07/26/2004,23:50
1088,7,0,"?",410202b1,1,0,4232,16-136 1088,07/24/2004,02:33
108c,7,0,"?",40fdec74,1,0,4236,16-140 108C,07/21/2004,00:09
10a6,7,0,"?",41006287,1,0,4262,16-166 10A6,07/22/2004,20:57
10a9,7,0,"?",4103c1ea,1,0,4265,16-169 10A9,07/25/2004,10:21
10ac,7,0,"?",41013592,1,0,4268,16-172 10AC,07/23/2004,11:58
10ad,7,0,"?",41078161,1,0,4269,16-173 10AD,07/28/2004,06:35
10b0,7,0,"?",410011af,1,0,4272,16-176 10B0,07/22/2004,15:12
10bc,7,0,"?",41060d14,1,0,4284,16-188 10BC,07/27/2004,04:06
10d1,7,0,"?",4103457d,1,0,4305,16-209 10D1,07/25/2004,01:30
10df,7,0,"?",410742fc,1,0,4319,16-223 10DF,07/28/2004,02:09
10e0,7,0,"?",410373fb,1,0,4320,16-224 10E0,07/25/2004,04:48
10e2,7,0,"?",40fe65b3,1,0,4322,16-226 10E2,07/21/2004,08:46
110c,7,0,"?",4107a237,1,0,4364,17-012 110C,07/28/2004,08:55
111d,7,0,"?",410804eb,1,0,4381,17-029 111D,07/28/2004,15:56
1124,7,0,"?",41083335,1,0,4388,17-036 1124,07/28/2004,19:13
1128,7,0,"?",410783b7,1,0,4392,17-040 1128,07/28/2004,06:45
1135,7,0,"?",410054e4,1,0,4405,17-053 1135,07/22/2004,19:59
1140,7,0,"?",410740a0,2,0,4416,17-064 1140,07/28/2004,01:58
1147,7,0,"?",41074167,1,0,4423,17-071 1147,07/28/2004,02:02
1163,7,0,"?",40fe7666,1,0,4451,17-099 1163,07/21/2004,09:57
1169,7,0,"?",41017579,1,0,4457,17-105 1169,07/23/2004,16:30
1188,7,0,"?",4102c2df,1,0,4488,17-136 1188,07/24/2004,16:13
11b7,7,0,"?",4107e6f6,1,0,4535,17-183 11B7,07/28/2004,13:48
11cd,7,0,"?",40fde78d,1,0,4557,17-205 11CD,07/20/2004,23:48
11d0,7,0,"?",4107cc60,1,0,4560,17-208 11D0,07/28/2004,11:55
11d1,7,0,"?",40fded9e,1,0,4561,17-209 11D1,07/21/2004,00:14
11df,7,0,"?",41072cd8,1,0,4575,17-223 11DF,07/28/2004,00:34
1210,7,0,"?",4107d79b,1,0,4624,18-016 1210,07/28/2004,12:43
1215,7,0,"?",40ffefbe,1,0,4629,18-021 1215,07/22/2004,12:47
121e,7,0,"?",40fdcd02,1,0,4638,18-030 121E,07/20/2004,21:55
1227,7,0,"?",4100b098,1,0,4647,18-039 1227,07/23/2004,02:30
122b,7,0,"?",41010054,1,0,4651,18-043 122B,07/23/2004,08:11
122e,7,0,"?",40fe67d4,1,0,4654,18-046 122E,07/21/2004,08:55
1248,7,0,"?",4107721c,1,0,4680,18-072 1248,07/28/2004,05:30
1251,7,0,"?",41003b46,2,0,4689,18-081 1251,07/22/2004,18:10
1259,7,0,"?",40fe8dff,1,0,4697,18-089 1259,07/21/2004,11:38
1262,7,0,"?",4106ed52,1,0,4706,18-098 1262,07/27/2004,20:03
1269,7,0,"?",41024112,1,0,4713,18-105 1269,07/24/2004,06:59
126d,7,0,"?",410247c9,1,0,4717,18-109 126D,07/24/2004,07:28
126e,7,0,"?",410642b0,1,0,4718,18-110 126E,07/27/2004,07:55
1277,7,0,"?",410331e2,1,0,4727,18-119 1277,07/25/2004,00:06
127f,7,0,"?",41079b89,2,0,4735,18-127 127F,07/28/2004,08:26
1296,7,0,"?",41059ed2,1,0,4758,18-150 1296,07/26/2004,20:16
1298,7,0,"?",4107633e,1,0,4760,18-152 1298,07/28/2004,04:26
129b,7,0,"?",41039653,3,0,4763,18-155 129B,07/25/2004,07:15
12a2,7,0,"?",40ff8217,1,0,4770,18-162 12A2,07/22/2004,05:00
12aa,7,0,"?",4100d4f5,1,0,4778,18-170 12AA,07/23/2004,05:05
12b3,7,0,"?",410649fb,1,0,4787,18-179 12B3,07/27/2004,08:26
12bc,7,0,"?",410742f8,1,0,4796,18-188 12BC,07/28/2004,02:08
12bf,7,0,"?",41073d70,1,0,4799,18-191 12BF,07/28/2004,01:45
12c0,7,0,"?",40ffa856,1,0,4800,18-192 12C0,07/22/2004,07:43
12c4,7,0,"?",410211e1,1,0,4804,18-196 12C4,07/24/2004,03:38
12c7,7,0,"?",4101ec4c,1,0,4807,18-199 12C7,07/24/2004,00:57
12cb,7,0,"?",40fef5c3,1,0,4811,18-203 12CB,07/21/2004,19:01
12d8,7,0,"?",4101b795,1,0,4824,18-216 12D8,07/23/2004,21:12
12db,7,0,"?",4105fb77,1,0,4827,18-219 12DB,07/27/2004,02:51
12df,7,0,"?",41034e66,1,0,4831,18-223 12DF,07/25/2004,02:08
12e7,7,0,"?",410721c6,3,0,4839,18-231 12E7,07/27/2004,23:47
12f3,7,0,"?",4105db44,1,0,4851,18-243 12F3,07/27/2004,00:34
12f5,7,0,"?",410628bd,1,0,4853,18-245 12F5,07/27/2004,06:04
12f6,7,0,"?",41007996,2,0,4854,18-246 12F6,07/22/2004,22:36
12f7,7,0,"?",41070bac,4,0,4855,18-247 12F7,07/27/2004,22:13
12f8,7,0,"?",410803b0,1,0,4856,18-248 12F8,07/28/2004,15:51
12fb,7,0,"?",4107bccf,6,0,4859,18-251 12FB,07/28/2004,10:48
1301,7,0,"?",410203fd,1,0,4865,19-001 1301,07/24/2004,02:38
130c,7,0,"?",40fde15a,1,0,4876,19-012 130C,07/20/2004,23:22
1324,7,0,"?",4100d2db,1,0,4900,19-036 1324,07/23/2004,04:56
132d,7,0,"?",41074ed7,1,0,4909,19-045 132D,07/28/2004,02:59
1333,7,0,"?",4100e6a5,1,0,4915,19-051 1333,07/23/2004,06:21
136f,7,0,"?",4105f165,1,0,4975,19-111 136F,07/27/2004,02:08
1389,7,0,"?",40feb097,1,0,5001,19-137 1389,07/21/2004,14:06
1397,7,0,"?",41086549,1,0,5015,19-151 1397,07/28/2004,22:47
13a8,7,0,"?",40ff91f4,1,0,5032,19-168 13A8,07/22/2004,06:07
13b2,7,0,"?",41032871,1,0,5042,19-178 13B2,07/24/2004,23:26
13b5,7,0,"?",4103aeb4,1,0,5045,19-181 13B5,07/25/2004,08:59
13c5,7,0,"?",4107d262,1,0,5061,19-197 13C5,07/28/2004,12:20
13cb,7,0,"?",40fe0f11,1,0,5067,19-203 13CB,07/21/2004,02:37
1404,7,0,"?",41037e65,1,0,5124,20-004 1404,07/25/2004,05:33
1413,7,0,"?",40fe5c58,1,0,5139,20-019 1413,07/21/2004,08:06
1421,7,0,"?",41001b02,1,0,5153,20-033 1421,07/22/2004,15:52
1425,7,0,"?",41000bfb,1,0,5157,20-037 1425,07/22/2004,14:48
1428,7,0,"?",40ff8e1e,1,0,5160,20-040 1428,07/22/2004,05:51
1429,7,0,"?",41008e56,1,0,5161,20-041 1429,07/23/2004,00:04
142b,7,0,"?",40ffb6ef,1,0,5163,20-043 142B,07/22/2004,08:45
142f,7,0,"?",41062060,1,0,5167,20-047 142F,07/27/2004,05:29
143c,7,0,"?",4107363d,1,0,5180,20-060 143C,07/28/2004,01:14
1441,7,0,"?",4101708e,1,0,5185,20-065 1441,07/23/2004,16:09
1442,7,0,"?",40ff318f,1,0,5186,20-066 1442,07/21/2004,23:16
1459,7,0,"?",4107d16f,1,0,5209,20-089 1459,07/28/2004,12:16
145c,7,0,"?",4107bdc4,1,0,5212,20-092 145C,07/28/2004,10:52
1462,7,0,"?",41019922,1,0,5218,20-098 1462,07/23/2004,19:02
1465,7,0,"?",40ffe0a0,1,0,5221,20-101 1465,07/22/2004,11:43
146f,7,0,"?",41078f55,1,0,5231,20-111 146F,07/28/2004,07:34
1478,7,0,"?",41022ee7,1,0,5240,20-120 1478,07/24/2004,05:41
1480,7,0,"?",4102aa29,1,0,5248,20-128 1480,07/24/2004,14:27
1484,7,0,"?",4103c1f2,1,0,5252,20-132 1484,07/25/2004,10:21
1485,7,0,"?",410327d1,1,0,5253,20-133 1485,07/24/2004,23:24
1489,7,0,"?",410391c7,1,0,5257,20-137 1489,07/25/2004,06:56
14a8,7,0,"?",41029fa6,1,0,5288,20-168 14A8,07/24/2004,13:43
14b4,7,0,"?",4105f003,2,0,5300,20-180 14B4,07/27/2004,02:02
14be,7,0,"?",4108cf65,1,0,5310,20-190 14BE,07/29/2004,06:20
14e7,7,0,"?",4106673a,1,0,5351,20-231 14E7,07/27/2004,10:31
14ee,7,0,"?",40ff35c9,1,0,5358,20-238 14EE,07/21/2004,23:34
1504,7,0,"?",41067c36,1,0,5380,21-004 1504,07/27/2004,12:00
1505,7,0,"?",4103301c,1,0,5381,21-005 1505,07/24/2004,23:59
1517,7,0,"?",4100c721,1,0,5399,21-023 1517,07/23/2004,04:06
1523,7,0,"?",4106e665,1,0,5411,21-035 1523,07/27/2004,19:33
1524,7,0,"?",41062715,1,0,5412,21-036 1524,07/27/2004,05:57
1552,7,0,"?",410136bf,1,0,5458,21-082 1552,07/23/2004,12:03
1562,7,0,"?",41060b4f,1,0,5474,21-098 1562,07/27/2004,03:59
1565,7,0,"?",41063e95,1,0,5477,21-101 1565,07/27/2004,07:37
156a,7,0,"?",41008360,1,0,5482,21-106 156A,07/22/2004,23:17
159a,7,0,"?",40fe7bac,1,0,5530,21-154 159A,07/21/2004,10:20
15c0,7,0,"?",41072c7a,1,0,5568,21-192 15C0,07/28/2004,00:32
15e6,7,0,"?",41069cdc,1,0,5606,21-230 15E6,07/27/2004,14:20
160e,7,0,"?",41084b49,1,0,5646,22-014 160E,07/28/2004,20:56
1622,7,0,"?",40febf97,1,0,5666,22-034 1622,07/21/2004,15:10
1627,7,0,"?",4101d609,1,0,5671,22-039 1627,07/23/2004,23:22
162d,7,0,"?",4106422e,1,0,5677,22-045 162D,07/27/2004,07:53
1638,7,0,"?",4107f8f3,1,0,5688,22-056 1638,07/28/2004,15:05
163a,7,0,"?",41084728,1,0,5690,22-058 163A,07/28/2004,20:39
1642,7,0,"?",4106a57c,1,0,5698,22-066 1642,07/27/2004,14:57
1645,7,0,"?",4107d162,1,0,5701,22-069 1645,07/28/2004,12:16
1649,7,0,"?",40ff1f8d,1,0,5705,22-073 1649,07/21/2004,21:59
1656,7,0,"?",41019e1c,1,0,5718,22-086 1656,07/23/2004,19:24
165d,7,0,"?",40fe0970,1,0,5725,22-093 165D,07/21/2004,02:13
1661,7,0,"?",40fedacc,1,0,5729,22-097 1661,07/21/2004,17:06
1693,7,0,"?",410680cd,1,0,5779,22-147 1693,07/27/2004,12:20
16a1,7,0,"?",4103a708,1,0,5793,22-161 16A1,07/25/2004,08:26
16a7,7,0,"?",41058e2d,1,0,5799,22-167 16A7,07/26/2004,19:05
16a8,7,0,"?",41024d26,1,0,5800,22-168 16A8,07/24/2004,07:51
16a9,7,0,"?",41028314,1,0,5801,22-169 16A9,07/24/2004,11:41
16ab,7,0,"?",410197b5,1,0,5803,22-171 16AB,07/23/2004,18:56
16ac,7,0,"?",410649ad,1,0,5804,22-172 16AC,07/27/2004,08:25
16af,7,0,"?",40fe40a7,1,0,5807,22-175 16AF,07/21/2004,06:08
16b4,7,0,"?",410639e9,1,0,5812,22-180 16B4,07/27/2004,07:18
16b8,7,0,"?",41061ac0,1,0,5816,22-184 16B8,07/27/2004,05:05
16bf,7,0,"?",41021310,1,0,5823,22-191 16BF,07/24/2004,03:43
16d5,7,0,"?",4105bfa8,1,0,5845,22-213 16D5,07/26/2004,22:36
16e1,7,0,"?",410775a5,1,0,5857,22-225 16E1,07/28/2004,05:45
16e2,7,0,"?",4102e772,1,0,5858,22-226 16E2,07/24/2004,18:49
16ef,7,0,"?",41083690,1,0,5871,22-239 16EF,07/28/2004,19:28
16f6,7,0,"?",40febb4c,1,0,5878,22-246 16F6,07/21/2004,14:51
170e,7,0,"?",41080d21,1,0,5902,23-014 170E,07/28/2004,16:31
1720,7,0,"?",40fff847,1,0,5920,23-032 1720,07/22/2004,13:24
1724,7,0,"?",40ff49dd,1,0,5924,23-036 1724,07/22/2004,01:00
1737,7,0,"?",41087e19,1,0,5943,23-055 1737,07/29/2004,00:33
1752,7,0,"?",4107df3a,1,0,5970,23-082 1752,07/28/2004,13:15
176f,7,0,"?",40ffe457,1,0,5999,23-111 176F,07/22/2004,11:59
1780,7,0,"?",410056dc,1,0,6016,23-128 1780,07/22/2004,20:07
17a1,7,0,"?",40ff057f,1,0,6049,23-161 17A1,07/21/2004,20:08
17b6,7,0,"?",4100f258,1,0,6070,23-182 17B6,07/23/2004,07:11
17c4,7,0,"?",410890a9,1,0,6084,23-196 17C4,07/29/2004,01:52
17e2,7,0,"?",410353e7,1,0,6114,23-226 17E2,07/25/2004,02:32
17e7,7,0,"?",4101be61,1,0,6119,23-231 17E7,07/23/2004,21:41
1805,7,0,"?",40ffd06a,1,0,6149,24-005 1805,07/22/2004,10:34
1811,7,0,"?",4102884b,2,0,6161,24-017 1811,07/24/2004,12:03
1845,7,0,"?",41083e52,1,0,6213,24-069 1845,07/28/2004,20:01
1849,7,0,"?",4101ae08,1,0,6217,24-073 1849,07/23/2004,20:32
187d,7,0,"?",41061482,1,0,6269,24-125 187D,07/27/2004,04:38
1880,7,0,"?",4108afe6,1,0,6272,24-128 1880,07/29/2004,04:05
1886,7,0,"?",40ffede6,1,0,6278,24-134 1886,07/22/2004,12:40
1888,7,0,"?",41064883,1,0,6280,24-136 1888,07/27/2004,08:20
1899,7,0,"?",41086ab7,1,0,6297,24-153 1899,07/28/2004,23:10
18a3,7,0,"?",410716a9,1,0,6307,24-163 18A3,07/27/2004,22:59
18b8,7,0,"?",4102c889,1,0,6328,24-184 18B8,07/24/2004,16:37
18ba,7,0,"?",40ffae5b,1,0,6330,24-186 18BA,07/22/2004,08:08
18bc,7,0,"?",4103b9bb,1,0,6332,24-188 18BC,07/25/2004,09:46
18c8,7,0,"?",40fe84fe,1,0,6344,24-200 18C8,07/21/2004,11:00
18cb,7,0,"?",40ff9c10,2,0,6347,24-203 18CB,07/22/2004,06:50
18e0,7,0,"?",41035daf,1,0,6368,24-224 18E0,07/25/2004,03:13
18ea,7,0,"?",41082b15,1,0,6378,24-234 18EA,07/28/2004,18:39
1900,7,0,"?",40ff3685,1,0,6400,25-000 1900,07/21/2004,23:37
1902,7,0,"?",4101859c,2,0,6402,25-002 1902,07/23/2004,17:39
1908,7,0,"?",40ff74d8,1,0,6408,25-008 1908,07/22/2004,04:03
1918,7,0,"?",41020f59,1,0,6424,25-024 1918,07/24/2004,03:27
191c,7,0,"?",40fe7655,1,0,6428,25-028 191C,07/21/2004,09:57
191d,7,0,"?",41083e1e,1,0,6429,25-029 191D,07/28/2004,20:00
192c,7,0,"?",40ff3fe9,1,0,6444,25-044 192C,07/22/2004,00:17
1931,7,0,"?",4103360b,2,0,6449,25-049 1931,07/25/2004,00:24
194b,7,0,"?",40fdc57f,1,0,6475,25-075 194B,07/20/2004,21:23
1969,7,0,"?",40ffc9fd,1,0,6505,25-105 1969,07/22/2004,10:06
1977,7,0,"?",4100849f,1,0,6519,25-119 1977,07/22/2004,23:23
1982,7,0,"?",4105e186,1,0,6530,25-130 1982,07/27/2004,01:00
1984,7,0,"?",4102143e,1,0,6532,25-132 1984,07/24/2004,03:48
198c,7,0,"?",40fef5a9,1,0,6540,25-140 198C,07/21/2004,19:00
1997,7,0,"?",410823ba,1,0,6551,25-151 1997,07/28/2004,18:07
19aa,7,0,"?",41080df6,1,0,6570,25-170 19AA,07/28/2004,16:35
19c5,7,0,"?",41074d32,1,0,6597,25-197 19C5,07/28/2004,02:52
19e4,7,0,"?",40fe01cc,1,0,6628,25-228 19E4,07/21/2004,01:40
1a09,7,0,"?",410899be,1,0,6665,26-009 1A09,07/29/2004,02:31
1a10,7,0,"?",4107d8a4,1,0,6672,26-016 1A10,07/28/2004,12:47
1a11,7,0,"?",40feb51f,1,0,6673,26-017 1A11,07/21/2004,14:25
1a16,7,0,"?",40ffb0d9,1,0,6678,26-022 1A16,07/22/2004,08:19
1a2b,7,0,"?",410241e5,1,0,6699,26-043 1A2B,07/24/2004,07:03
1a2c,7,0,"?",40fe7c81,1,0,6700,26-044 1A2C,07/21/2004,10:24
1a2d,7,0,"?",40febc8f,1,0,6701,26-045 1A2D,07/21/2004,14:57
1a2e,7,0,"?",40fe8cb8,1,0,6702,26-046 1A2E,07/21/2004,11:33
1a31,7,0,"?",4107f146,3,0,6705,26-049 1A31,07/28/2004,14:32
1a39,7,0,"?",4106b0c3,1,0,6713,26-057 1A39,07/27/2004,15:45
1a49,7,0,"?",4100e7a1,1,0,6729,26-073 1A49,07/23/2004,06:25
1a52,7,0,"?",4106bc66,2,0,6738,26-082 1A52,07/27/2004,16:34
1a55,7,0,"?",40feb19a,1,0,6741,26-085 1A55,07/21/2004,14:10
1a59,7,0,"?",41069198,1,0,6745,26-089 1A59,07/27/2004,13:32
1a5b,7,0,"?",4107f97e,1,0,6747,26-091 1A5B,07/28/2004,15:07
1a5e,7,0,"?",410802fc,1,0,6750,26-094 1A5E,07/28/2004,15:48
1a62,7,0,"?",41076bd2,1,0,6754,26-098 1A62,07/28/2004,05:03
1a71,7,0,"?",41080612,1,0,6769,26-113 1A71,07/28/2004,16:01
1a75,7,0,"?",4108408e,1,0,6773,26-117 1A75,07/28/2004,20:10
1a82,7,0,"?",4106498b,1,0,6786,26-130 1A82,07/27/2004,08:24
1a83,7,0,"?",40ff898a,1,0,6787,26-131 1A83,07/22/2004,05:31
1a90,7,0,"?",40ff3fc9,1,0,6800,26-144 1A90,07/22/2004,00:17
1a9c,7,0,"?",4105fb1b,1,0,6812,26-156 1A9C,07/27/2004,02:50
1aa1,7,0,"?",4107cc78,2,0,6817,26-161 1AA1,07/28/2004,11:55
1ab4,7,0,"?",40fe55c2,1,0,6836,26-180 1AB4,07/21/2004,07:38
1acd,7,0,"?",4108bb70,1,0,6861,26-205 1ACD,07/29/2004,04:55
1acf,7,0,"?",4103b06c,1,0,6863,26-207 1ACF,07/25/2004,09:06
1af1,7,0,"?",41082760,3,0,6897,26-241 1AF1,07/28/2004,18:23
1af9,7,0,"?",41080bf3,1,0,6905,26-249 1AF9,07/28/2004,16:26
1b00,7,0,"?",40ff24c6,1,0,6912,27-000 1B00,07/21/2004,22:21
1b0a,7,0,"?",4108bcb6,1,0,6922,27-010 1B0A,07/29/2004,05:00
1b0d,7,0,"?",4100980b,1,0,6925,27-013 1B0D,07/23/2004,00:46
1b23,7,0,"?",4105eade,1,0,6947,27-035 1B23,07/27/2004,01:40
1b31,7,0,"?",41019979,1,0,6961,27-049 1B31,07/23/2004,19:04
1b38,7,0,"?",41001f74,1,0,6968,27-056 1B38,07/22/2004,16:11
1b56,7,0,"?",40fdcaa5,1,0,6998,27-086 1B56,07/20/2004,21:45
1b67,7,0,"?",4107855f,1,0,7015,27-103 1B67,07/28/2004,06:52
1b90,7,0,"?",4101f7d0,1,0,7056,27-144 1B90,07/24/2004,01:46
1bad,7,0,"?",410076a2,1,0,7085,27-173 1BAD,07/22/2004,22:23
1bb4,7,0,"?",4102337d,1,0,7092,27-180 1BB4,07/24/2004,06:01
1c02,7,0,"?",4100eb71,1,0,7170,28-002 1C02,07/23/2004,06:41
1c07,7,0,"?",410397a5,1,0,7175,28-007 1C07,07/25/2004,07:21
1c0c,7,0,"?",40ff7d24,1,0,7180,28-012 1C0C,07/22/2004,04:39
1c14,7,0,"?",4101159a,1,0,7188,28-020 1C14,07/23/2004,09:41
1c2d,7,0,"?",4107fb49,1,0,7213,28-045 1C2D,07/28/2004,15:15
1c4c,7,0,"?",41063d5f,1,0,7244,28-076 1C4C,07/27/2004,07:32
1c4e,7,0,"?",40fe6454,1,0,7246,28-078 1C4E,07/21/2004,08:40
1c5b,7,0,"?",41086306,1,0,7259,28-091 1C5B,07/28/2004,22:37
1c66,7,0,"?",41080691,1,0,7270,28-102 1C66,07/28/2004,16:03
1c8a,7,0,"?",41075e7d,1,0,7306,28-138 1C8A,07/28/2004,04:06
1c8f,7,0,"?",40ff2e87,1,0,7311,28-143 1C8F,07/21/2004,23:03
1cad,7,0,"?",41031faf,1,0,7341,28-173 1CAD,07/24/2004,22:49
1caf,7,0,"?",40fe8d9e,1,0,7343,28-175 1CAF,07/21/2004,11:37
1cb5,7,0,"?",4106f58f,2,0,7349,28-181 1CB5,07/27/2004,20:38
1cc6,7,0,"?",4107a795,1,0,7366,28-198 1CC6,07/28/2004,09:18
1ccb,7,0,"?",40ff9be9,1,0,7371,28-203 1CCB,07/22/2004,06:50
1cd7,7,0,"?",41081da5,1,0,7383,28-215 1CD7,07/28/2004,17:41
1cdd,7,0,"?",41011879,1,0,7389,28-221 1CDD,07/23/2004,09:54
1d01,7,0,"?",4106b231,1,0,7425,29-001 1D01,07/27/2004,15:51
1d15,7,0,"?",410377e7,1,0,7445,29-021 1D15,07/25/2004,05:05
1d2a,7,0,"?",410632ea,1,0,7466,29-042 1D2A,07/27/2004,06:48
1d40,7,0,"?",4106a9fc,1,0,7488,29-064 1D40,07/27/2004,15:16
1d4c,7,0,"?",4102555d,1,0,7500,29-076 1D4C,07/24/2004,08:26
1d58,7,0,"?",410259c1,1,0,7512,29-088 1D58,07/24/2004,08:44
1d59,7,0,"?",4105e151,1,0,7513,29-089 1D59,07/27/2004,01:00
1d68,7,0,"?",40ffde18,1,0,7528,29-104 1D68,07/22/2004,11:32
1d9e,7,0,"?",41067f9b,1,0,7582,29-158 1D9E,07/27/2004,12:15
1da4,7,0,"?",40ff7252,1,0,7588,29-164 1DA4,07/22/2004,03:52
1dbc,7,0,"?",41062113,1,0,7612,29-188 1DBC,07/27/2004,05:32
1dc0,7,0,"?",41074e2e,1,0,7616,29-192 1DC0,07/28/2004,02:56
1dd4,7,0,"?",4103aca2,1,0,7636,29-212 1DD4,07/25/2004,08:50
1e00,7,0,"?",4106bbc4,2,0,7680,30-000 1E00,07/27/2004,16:32
1e01,7,0,"?",4106501d,1,0,7681,30-001 1E01,07/27/2004,08:52
1e05,7,0,"?",40fe7e9f,1,0,7685,30-005 1E05,07/21/2004,10:33
1e0d,7,0,"?",40fead58,1,0,7693,30-013 1E0D,07/21/2004,13:52
1e14,7,0,"?",410844a5,1,0,7700,30-020 1E14,07/28/2004,20:28
1e21,7,0,"?",40fffe71,1,0,7713,30-033 1E21,07/22/2004,13:50
1e24,7,0,"?",41022416,2,0,7716,30-036 1E24,07/24/2004,04:55
1e25,7,0,"?",410813d3,3,0,7717,30-037 1E25,07/28/2004,17:00
1e28,7,0,"?",4106f0a8,1,0,7720,30-040 1E28,07/27/2004,20:17
1e2d,7,0,"?",40fecca3,1,0,7725,30-045 1E2D,07/21/2004,16:05
1e30,7,0,"?",410372de,2,0,7728,30-048 1E30,07/25/2004,04:44
1e3d,7,0,"?",40ffcebb,1,0,7741,30-061 1E3D,07/22/2004,10:27
1e40,7,0,"?",4100b522,1,0,7744,30-064 1E40,07/23/2004,02:50
1e4c,7,0,"?",40ffc0fa,1,0,7756,30-076 1E4C,07/22/2004,09:28
1e50,7,0,"?",40ffcf63,1,0,7760,30-080 1E50,07/22/2004,10:29
1e56,7,0,"?",4101489f,2,0,7766,30-086 1E56,07/23/2004,13:19
1e5e,7,0,"?",4107e93a,2,0,7774,30-094 1E5E,07/28/2004,13:58
1e76,7,0,"?",4107c126,1,0,7798,30-118 1E76,07/28/2004,11:07
1e7d,7,0,"?",410804bb,1,0,7805,30-125 1E7D,07/28/2004,15:55
1e7f,7,0,"?",410633d3,1,0,7807,30-127 1E7F,07/27/2004,06:52
1e84,7,0,"?",410230c2,1,0,7812,30-132 1E84,07/24/2004,05:49
1eac,7,0,"?",410595f6,1,0,7852,30-172 1EAC,07/26/2004,19:38
1eaf,7,0,"?",41039be1,1,0,7855,30-175 1EAF,07/25/2004,07:39
1ed9,7,0,"?",41073a51,1,0,7897,30-217 1ED9,07/28/2004,01:32
1efa,7,0,"?",41003f5e,1,0,7930,30-250 1EFA,07/22/2004,18:27
1efb,7,0,"?",410385b9,1,0,7931,30-251 1EFB,07/25/2004,06:04
1f1e,7,0,"?",40fe66ff,1,0,7966,31-030 1F1E,07/21/2004,08:52
1f2a,7,0,"?",4108a7ca,1,0,7978,31-042 1F2A,07/29/2004,03:31
1f2f,7,0,"?",4106b40c,1,0,7983,31-047 1F2F,07/27/2004,15:59
1f33,7,0,"?",4103b6f7,1,0,7987,31-051 1F33,07/25/2004,09:34
1f44,7,0,"?",4107652f,1,0,8004,31-068 1F44,07/28/2004,04:34
1f64,7,0,"?",40fea872,1,0,8036,31-100 1F64,07/21/2004,13:31
1f6f,7,0,"?",410122a6,1,0,8047,31-111 1F6F,07/23/2004,10:37
1f87,7,0,"?",41069fb2,1,0,8071,31-135 1F87,07/27/2004,14:32
1f8a,7,0,"?",41008ea8,1,0,8074,31-138 1F8A,07/23/2004,00:06
1fa1,7,0,"?",40ff40e6,1,0,8097,31-161 1FA1,07/22/2004,00:21
DaveIN
Founders Curmudgen
West Michigan
So what are the talkgroups that are not connected to a home repeater? i.e. 0-0-013, 0-31-161, or 0-1-000.
pro92b
Mutated Member
Bad data. The checksum in LTR is not foolproof by a long shot. Id's beginning with 0 and those beginning with numbers above 20 are always invalid. Id's that do not match any of the system LCN's are also invalid. Bad talkgroups tend to only show one or two hits. Those that are valid will show multiple hits over time. Much of the list you posted shows invalid talkgroups.
This is what remains of your list once invalid LCN groups and those with fewer than three hits are removed.
Code:
DaveIN
Founders Curmudgen
West Michigan
I suspected that :idea: , but wanted to hear that from someone who had experience with LTR systems. I am only attempting to monitor the talkgroups that you pointed out with actual LCN association.
Identifying talkgroups will be the fun part :? . It is hard to figure out some of the businesses using the talkgroups when the system is licensed to only one owner. Interesting too is that there are interconnect calls on this system. When the connection is completed it beeps three times, then a two tone beep three times before disconnect.
At least you can see the activity and get a better understanding of what is going on with LTRTrunk.
With the PRO-92 version 1.0 I can also see the repeaters cycle through in patterns, but not all frequencies are doing this. The pattern did change after a few cycles. What is the purpose for the cycle :?:
I also have a UHf regular LTR system in the area to try out, but it is not real active and only five frequencies.
pro92b
Mutated Member
Repeater patterns can be configured to give near-exclusive access to busy users for a given repeater, normally their home repeater. Non-home repeaters used for overflow traffic sometimes are put into a rotation to even out transmitter wear.
On one system here a busy taxi company is homed on repeater number two. Other system users almost never transmit on repeater number two.
If you don't have a squelch gate and a subaudible filter on your data slicer there will be a ton of false ID hits.
DaveIN
Founders Curmudgen
West Michigan
Now that I know LTRTrunk is functional, I think I'll build a sub-audible slicer and see what I get.
Thanks.
