2096 monitor LTR?
Signal3and2
WY
Im only familiar with motorola type2 systems. Will a 2096 listen to a 'LTR' system, whatever that is? This is the system I want to listen to: http://radioreference.com/modules.php?name=TRSDB&sid=2581
If it does, any tips on programming these bad boys, or what I should reference in the manual? As far as I see in the manual, the 2096 listens to motorola and EDACS. Not sure what LTR is.
tspainiv
Shelby Co DB Admin
Collierville, TN
The Pro-96/2096 does not track LTR. The Pro-97 on the other hand, is a great scanner that does!!!
Ohio
Sorry, it does NOT. On the other hand if the LTR system that you want to Monitor is NOT too busy then you could monitor it in Conventional Mode.
DaveIN
Founders Curmudgen
West Michigan
Or the base/mobile version of the 97, the PRO-2055.
