246 T
luckyshew13
I dont seen to be doing something right for the rebanding in Wichita. Any help
Redneck0410
Hutchinson, KS
You may not be able to pick anything up, as they are in the process of migrating to a P25 system.
Sent from my SCH-R740C using Tapatalk
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
...which your 246T won't handle. It's not a digital trunktracker
However just to answer your question about rebanding, you need 2 things - upgraded firmware, and either entering the rebanding tables manually (which is explained at the very bottom of the link) or software (FreeScan is freeware and can do this). If you use an app to download from the database, the custom tables will be set up for you
The 246T firmware upgrade is here...be sure to follow all the instructions precisely
BC246TFirmwareUpdate < UnidenMan4 < TWiki
Mike
luckyshew13
Thanks, The software is up to date i didn't know the 246 T would not work on the rebanded system
dgruver911
Newton, KS
clarification to avoid confusion here....
Rebanded and P25 upgrade are 2 entirely different things.
Rebanding is what all 800 systems did to move frequencies around at the FCC's manadate , and that is what Sedgwick County did 2-3 years ago when they dropped all their 859.xxxx frequencies for frequencies in the 854-855 range to get away from the Sprint/Nextel channels. What they are in the process of doing right now is migrating to a P25 digital system. Has nothing to do with rebanding.
luckyshew13
So what I need to do on the 246t ? I downloaded the new system from RR and loaded into the scanner and I got nothing
Redneck0410
Hutchinson, KS
Your scanner will not track the digital system Sedgwick County has switched to. You need a different scanner.
