Well..., let's see; If I'm figuring this out correctly, the ONLY way to enter a freq. other than the computer is using hold - Freq - hold to do so with a frequency you have scanned upon then - but soon as the 246T is turned off it would be lost then since you can't store it in memory?
In other words the 246T does NOT allow you to enter something from the keypad like, say,
1 - 5 - 1 - . - 4 - 6 - 0
then give an Enter command, and store it in memory, and the Group you want, then??
Tried Directly entering a frequency into Group 2 by going Hold > 1-5-1-.-4 - 6 - 0
When I key in 1 the words Direct Entry appear, then when I get the entire freq. keyed in, and press NO, the words Direct Entry are at top of readout, with a __ on next line are only onscreen. Nothing at all about what system do I want to put it in.
