cbrookhart
- Joined
- Oct 23, 2002
- Messages
- 75
It's been some time since I have turned on the scanner and used it. The last time it was used, I don't believe that the battery ran completely out. I turned it on recently, only to discover it was completely dead. I put it on the charger for a few hours and when I took it off the charger and turned it on, it stayed on for only about a second before the low battery indicator beeped and the scanner turned off. I think I'm using the right charger, so I am wondering why the battery didn't charge.
Another thing I noticed is that when I had the scanner on the charger and turned it on, depending on what angle it was being held at, the front display would seem to turn off and then reset. I'm wondering if there is a problem with the scanner, given the fact that the battery won't charge and when the scanner is plugged in and the scanner is then rotated up and down, the front display resets everytime the scanner is moved.
