Ias it possible to program my Icom 2730 to only repeat in one direction?
I used to do this with Yaesu FT-8800R models.Ias it possible to program my Icom 2730 to only repeat in one direction?
That's almost what I did when I had a IC-2720. Instead of using the VFO offset for the odd split you can program TX/RX frequencies separately in a memory channel program a random DCS code on the fake RX frequency to make 99.9% sure it will never receive anything even if somebody (or noise) shows up on your "unused" RX frequency.I used to do this with Yaesu FT-8800R models.
For your local side, use a simplex channel, no big deal.
But for the distant side, do an odd-split so that crossband rig xmits to correct freq, but when it stops transmitting, it will only Rx on a freq that has no traffic. (It's not the distant repeater's normal freq config, as the Rx side is now proframmed for a fake channel.)
I have never touched an IC-2730. I just assmed it was similar to the IC-2710 and IC-2720. I had both of those decades ago. I don't even remember if the 2710 had crossband repeat or not. The 2720 did and I never had an issue with PL or DCS.ND5Y
You seem pretty knowledgeable about using the 2730 as a x-band repeater. I have not been able to get the output of the UHF channel when in repeater mode to transmit the tone code. When I take it off the repeater function the UHF channel transmits the DCS code but not when it is in repeater mode. Any ideas why?
So the old “It’s working as designed” answer. No matter how stupid the design is.I called Icom. When I first asked why it would not transmit the PL tone he was confused and had me on hold for 6 minutes while he talked to someone in the room and finally told me nope the 2730 will not transmit a PL tone when in the repeater mode. The only alternative he offered was to buy there $1000+ repeater.
