276.500 AM/255.400 AM, Unknown/audio files)
Saint
Fort Erie Ontario Canada
Just checked my audio files and found these two frequencies in them, can anyone provide any information on them.
Saint
Listening from Fort Erie Ontario Canada
276.500 = 9/16/2024, 11:45 AM
255.400 = 9/16/2024, 1:15 PM
  • 276.500000 - - Unknown Aircraft - - Aircraft Unknown - Unknown Aircraft.zip
AirScan
Barkeater is a Fort Drum Range Control callsign, I'm guessing FEAR 11 is a B-52. 255.400 is a USAF common frequency used for Flight Service nationwide or also used to announce intentions when entering IR/VR routes, I've never heard Barkeater use it. Barkeater normally uses 244.500 to coordinate entry/exit at the Fort Drum Range and 226.900 is usually used once on the Range. Did you get anything on 244.500 or 226.900 by any chance ?
This is the AR609 (Viper South area) AR prime frequency. The Tanker heard was DECEE 11.
Saint
Barkeater is a Fort Drum JTAC callsign, I'm guessing FEAR 11 is a B-52 or heavy bomber. 255.400 is a
Barkeater is a Fort Drum Range Control callsign, I'm guessing FEAR 11 is a B-52 or heavy bomber. 255.400 is a USAF common frequency used for Flight Service nationwide or also used to announce intentions when entering IR/VR routes. Barkeater normally uses 244.500 to coordinate entry/exit at the Fort Drum Range and 226.900 is usually used once on the Range. Did you get anything on 244.500 or 226.900 by any chance ?
Thanks AirScan for all the info, I'll update my list.
Saint
or also used to announce intentions when entering IR/VR routes. Barkeater normally uses 244.500 to coordinate entry/exit at the Fort Drum Range. Did you get anything on 244.500 by any chance ?
Did not pick up anything on 244.500
Saint
AirScan
I seem to recall something about 255.400 being phased out as a Flight Service frequency but they were still using it as a sort of USAF common advisory frequency ?
AirScan
Saint, another Minot Buff CHILL 22 working the Range today, looks like heading your way. Do you monitor UHF ATC frequencies ?
Saint
No, I don't monitor the ATC frequencies, but I should start doing it, I'll have to make a list of the ATC frequencies I should listen to in my area and get a lot more information on the aircraft.
Saint
