2Meter and Scanner Antenna
Northern Nevada/Sierra Front
Hello all, forgot to ask this when i asked my question about where to mount a antenna on my jeep. But is there a antenna that will work for both operating on 2M and VHF-Hi scanning?
Thanks Scott
Are you using a scanner and a separate 2 meter radio? If you are try Ham Radio Outlet, or one of the other ham radio vendors, and check the specs on a duplexer for what you want to do. If you're planning on using both radios at the same time this might be a viable option. If you're not going to use both radios at the same time you could try an antenna switch, which will be cheaper.
If your ham radio has enough memory you could use it for scanning as well. I've had good luck with a Larsen 5/8 wave 2 meter antenna before. Has very low SWR on 2 meters and does good with VHF public safetey monitoring too. If you mount it on a Jeep make sure you have a good counterpoise for it. If not, you could try a half wave antenna as they're not too dependent on a good counterpoise.
Ontario
Hey dude, check this out. http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=40979&item=5724475966&rd=1 I also bought one of these also http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=4672&item=5724372452&rd=1
I use this with a ICOM Portable 144/440 dual band antenna. Pictured here btw, this dude is a great seller http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=4672&item=5724980562&rd=1
Like I said, it works like a charm.
Thanks Scott
