3 digit number 800 mhz search
bravo14
Polk County FL
I did a 800 mhz search and it stop on a freq and 3 digit pop up. For example 317 will show up when they talk. I do not know what that is.
bravo14
Polk County FL
I'm in Search when the numbers show up on the right hand side of the screen. It will show P25 and the 317 at the same time.
DonS
Franktown, CO
It's the P25 NAC ("Network Access Code"). Can be used on Project25 digital frequencies like CTCSS and DCS are used on analog frequencies.
bravo14
Polk County FL
I try to search for the P25NAC see the numbers like the pl/dpl tones. I do not see 317 on the list I see 31D on there.
wlmr
317 (decimal) = 13D (Hex). Could there have been a typo?
(Unless the scanner shows the NAC in Hex to start with, then I'm out of ideals.)
mikey60
Oakland County Michigan
The scanner does show the NAC in hex. On trunked systems, the site's NAC is usually a subset of the SystemID. In Michigan, on the MPSCS, the System ID is 796 (Hex). NAC values always start with 79, and vary from site to site on the third character (Local towers are 79D,79A, 79B, etc..)
The frequency found may be from a trunked system with a system ID starting with 13?
Mike
