3 element UHF yagi--home brew
mainetrunk
York county Me.
Hey builder's, I've been searching for the UHF yagi formula for a long time. Bottom line, I re-fined my search, and came up with a design that is VERY similar to the 1 I've been staring at for 3 years... So, I just got done putting the finishing touches on the bnc, and BINGO.. I just got done with a VHF, and works perfect, now this.. The answer was HERE in R-R all the time, so here it is. Good luck builder's..
http://www.nt1k.com/files/n1bmx-gmrs-yagi.pdf
P.S-- Home Depot DID NOT have the correst spacer. I am using a black rubber fuel line, nore does ANYONE know what a shoulder washer is.. Had to buy big rubber washer's.. $5.00 total, I had the bolts,bnc, and tape...
majoco
Stirrer
New Zealand
There's a picture of a shoulder washer on the construction drawings. Obviously available from McMaster-Carr.
mainetrunk
York county Me.
I don't see it's use, I glued the elements in place. This this is the BULL'S @&%%'s... It is already in place doing well.
majoco
Stirrer
New Zealand
They're to insulate the elements from the boom, the reflector and the director. It works better if the boom is not part of the antenna. The small shoulder washers go under the driven element cable screws.
mainetrunk
York county Me.
oooops
Oh, WOW... I just saw the diagram again. Well, that may explain the good vhf reception.... Hmmmm. O.K, back to the drawing board--and PAY ATTENTION to detail. Glad I don't do this for a living, I'd be in debt... Thanks majoco--cheers to ya.
mainetrunk
York county Me.
I type in the search bar -- where to buy shoulder washers in N.H, and there's nothing near by. I'm thinking about using the leftover hose. That will separate them
KevinC
32D2T/957.282
Super Moderator
I'm everywhere Focker!
Not trying to get off-topic, but it's always amazing how well a random piece of metal works as an antenna. :D
And how much better a resonant one works...
mainetrunk
York county Me.
You are correct, look at satelite dishes, wires pointing at a peice of metal.
Back to it--- a DRILL PRESS is reccomended. Straight holes are a pain to make.
mainetrunk
York county Me.
Well, it is done. I used rubber hoses to be the insulator on all 3 elements. I see no difference between the 2. Well, I got what I wanted..
majoco
Stirrer
New Zealand
It would appear that the driven element is about 6" long, this would make it a quarter wave at about 500MHz. Why are you trying it at VHF? It says it is a GMRS antenna, I don't know what band that is on. Any other frequency would give it a high loss and a weird radiation pattern.
mainetrunk
York county Me.
GMRS band? That is uhf I beleive. And yes, I have to use the ATTENUATOR when doing vhf...
The next 1, I want to aim for 470 mhz thru 485. That's where the -action- is...
majoco
Stirrer
New Zealand
GMRS band repeater inputs 462.550 to 462.725, repeater outputs 467.550 to 467.725MHz.
mainetrunk
York county Me.
That's the formula i was taught 15 years ago, 465---469.9875 is input. Unless someone rewrote tx and rx . Any way, antenna's are done.. Next project-- cw
majoco
Stirrer
New Zealand
My apologies - I read it wrong. We don't have/need GMRS here, just a non-licence band around the same frequencies.
mainetrunk
York county Me.
I jusy wanna say- I built 2 of them, slightly modified, and works just as good.. I'm not doubting measurments to freqs, just saying-you can be off by a milimeter and still get good reception. I just built a 5 element yagi making hole where I -want-- It works better than the other 2, maybe better than the 1 I sold to MaineRadioMan. Dont tell him, lol
