I currently run 3 feeds using 3 computers want to know if there is an EASY way to use 1 computer.
Sounds like an expensive way to crack the nut.Running 3 feeds, one computer with three SDS200. Easy setup.
VBcable is a great tool for "virtual" audio cables using multiple RTL's on one computer.Sounds like an expensive way to crack the nut.
There's plenty of free software out there to do the same thing using inexpensive RTL dongles.
I run three feeds from two different P25 Ph2 systems using one instance of op25 on a NUC7i5. In my case I am now doing it with a single Airspy Mini @ 6Mhz, but in the past it worked equally well with three RTL dongles.You don't even need a powerhouse of a single computer to do that.
Frank --- this looks really viable to do. Reach out to me.VBcable is a great tool for "virtual" audio cables using multiple RTL's on one computer.
