3 NC Firefighter Killed LODD
bigdoggg
North Carolina
SALISBURY - Two Salisbury firefighters were killed battling a massive blaze. At least five other firefighters were injured.
Firefighter Justin Monroe, 19, and Firefighter Victor Isler, 40, both assigned to Quint 2, were among some of the first firefighters to respond to Salisbury Millwork on South Martin Luther King, Jr. Avenue this morning.
.An employee of Salisbury Millwork reported the fire upon arriving at the building this morning around 7am. Crews initially found fire conditions in the basement portion of the building. Operations were originally offensive on the structure. Crews had to shut down rail lines to lay additional supply lines across tracks.
A Mayday was transmitted well into the incident and at least one Rapid Intervention Team was activated. Early reports indicated that some of the other injured firefighters were part of the rescue teams.
As the gravity of the situation became known, Salisbury firefighters were relieved on scene by mutual aid companies and taken to Station One for debriefing and CSID.
All Rowan County fire companies responded to the scene to assist in controlling the large fire. Additional assistance was received from Mecklenburg, Cabarrus, Forsyth and Iredell counties.
RedPenguin
Is it 3 or 2?
Is it actually 3 or just two? The subject says 3 yet the report says 2.
