30-1300 Mhz NMO Mount Antenna?
BlueMoon2
Midlothian, VA
Hello Everyone,
I recently found out that one of the police departments in my area uses 39.440 mhz as a side tac channel off of the 800 mhz trunked radio system we have. I currently have both an 150/450/800 mhz antenex NMO Mount antenna and a Laird 806-896 mhz nmo mount antenna that I primarily used for monitoring the 150/450/800 frequencies. I am wondering if there is a 30-1300 mhz NMO mount antenna to be had out there? I have a Radioshack 25-1300 mhz antenna but it is just a magnet mount NON-NMO mount antenna that terminates to a BNC coupler. Any suggestions?
I can tell you that low band is really picky about antennas. You might find that using two antennas will get you the best results. Use the 150-450-860 for those bands, and have a second low band specific antenna for that band. The Larsen NMO antennas are available for that range and should give you good results.
N5TWB
Sand Springs OK
I have used this approach before and can verify it's a valid, no-compromise method. I would also note that I've received Oklahoma Highway Patrol low-band transmissions on a quarter-wave VHF-Hi antenna feeding a Radio Shack Pro95 scanner. Antennas are one of the interesting and fun areas for experimentation and learning in the radio hobby.
fineshot1
NJ USA (Republic of NJ)
Hello Everyone,
I can assure you that there is NO SUCH THING as a 30-1300 Mhz NMO Mount Quality Antenna.
Close enough to a strong signal a piece wire will pick up just about anything and that
Super M is a POS antenna so save your $ and listen to mmkenna, he has the much
better approach.
prcguy
Austin spectra is the only currently made NMO antenna that is designed for all the public service bands including VHF-lo. You must tune it to the low band freq since performance drops off rapidly from the sweet spot.
The older A/S MON series works a little better on VHF lo and is slightly wider band but it may give up some on 800. I've tested the Austin Spectra and A/S MON series side by side on 30-500MHz and prefer the A/S but I have no data comparing 800MHz.
prcguy
awattam
Nashua NH
Austin Spectra
Austin spectra is a pretty good antenna all around
I second that. Mine outperforms anything I have ever used in the past and I keep mine INSIDE the car (mag mounted on a metal pie dish) and I can stil pick up systems over 20 miles away. I havent tried it outside the car yet but I can only imagine how good it would be.
