Dillionbushman
- Joined
- Jan 26, 2023
- Messages
- 6
Any one have any numbers for 321 MTO Highway maintenance Parry Sound?
Thanks for the reply. I was look for a frequency to plug in a scanner. I run a snow plow in Parry Sound on the 400.I would like to listen at home. But I'm guessing it is trunked, digital and unscannable. My knowledge for this is very limited. This system is used all over Ontario. The Dispatch answers to " 321" . I could try a frequency scanner.Not sure what you mean by numbers but the MTO can be found here: Bell FleetNet Ontario Provincial Government Zone 2 Trunking System, Southeast Zone, Ontario (radioreference.com)
You are most likely on the system I posted. The MTO are trunked, analog and definitely scannable.I run a snow plow in Parry Sound on the 400. And I would like to listen at home. But I'm guessing it is trunked, digital and unscannable.
Parry Sound District | 141.300 | 141.435 | 141.690 | 142.320c | 142.515c | 142.650c | 142.980 | |
143.310 |
What scanner do you have?
You could program in the frequencies but unfortunately, you'll hear only digital noise when the OPP talk.
That looks like a DMR Motorola mobile radio. That won't work on Fleetnet.
Thanks. Those are the correct frequencies. I have heard the communications I was looking for. I put those frequencies in a analog scanner. But obviously it does not work correctly. Saving for a P25.Yes, it will work but every time you key the mic, you'll get a different input frequency since it's on this trunking system: Bell FleetNet Ontario Provincial Government Zone 2 Trunking System, Southeast Zone, Ontario (radioreference.com)
You'll need a trunking capable scanner. Once you've got that program in this site:
Parry Sound District 141.300 141.435 141.690 142.320c 142.515c 142.650c 142.980 143.310
and then you'll want to program in this talkgroup:
