devicelab
Whacker Extraordinaire
Just in case anyone doesn't know this already but the Retevis RT-10 supports the 33cm amateur band with no modifications, etc. You just need to program it up and it's good to go out of the box. The hardware is nothing special but this unit does support DMR. It also has a dual-slot DMR mode which is interesting. The stock antenna is not good -- it's acceptable though. Antenex made a rubber duck that has a green stripe around the top. They can be found on E-Bay for < $15 or cheaper. (I think it's SFU902 or something similar.) The battery life is crap -- it lasts about 3 hours of receiving and 1.5 hours of transmit time.
The audio quality is decent. I'd recommend just making sure you speak into the microphone port directly. I haven't tried a speaker/mic but that might be the better way to go.
They're being sold directly or you can buy two radios for $140 off of Amazon: https://a.co/d/hXJ1hSU
(Note you'll need the $13 programming cable or I believe it can use the Baofeng 2-pin cable as well -- but I haven't verified that personally.)
Cheers!
Cheers!
