chcfirefighter44
Recently picked up a 346XT, I have gotten everything programmed seems to work OK. Will say that, I have had difficulty picking up somethings lately that with my old scanner were once a cake walk. There is a repeater for our local fire service about 6.5 miles from my house. This repeater has now disappeared as far as listening goes. I was wondering if the scanner is too sensitive and is over loaded or some type of interference in the area causing the difficulty. What are the beginning steps on isolating these problems? Note: was using the stock rubber ducky and had the problem, jumped up to a Diamond SRH77CA and still have the problem. Thinking now about switching on the attenuator to try and see if that helps?
These are the freqs that I generally have the trouble with.
154.3400 - Cheswold
151.4000 - County
154.4450 - Dover
Otherwise, this scanner has been a joy to own and program.
154.3400 - Cheswold
151.4000 - County
154.4450 - Dover
