350-390MHz???
Thunderbolt5
Can anyone tell me what this chunk of freqs are allocated for? I can't seem to find anything other that an obscure reference to aircraft....
Thunderbolt
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Some, but not all, trunk systems in this area are encrypted. Someone from your neck of the woods could tell you better about such trunks in your area. 73 Mike
fineshot1
NJ USA (Republic of NJ)
Thunderbolt
I think its like this - correct me if I am wrong someone
225 - 380 Mhz Military UHF Aircraft - mostly AM mode 25 Khz steps
380 - 406 Mhz Military UHF Trunking - FM Narrow Band 12.5 Khz steps
Thunderbolt5
Great, thanks all.
Ok, since we're here...
How would I find the .mil freqs in my area?
Thunderbolt5
ecps92
Taxachusetts
Not trying to be funny, but SEARCH.
1.) Put your radio into SEARCH mode for those bands.
2.) Expand out on those bands, not all MIL are there
try 137-144, 148-150.8, 162-174 and 406-420 as well.
3.) Where do you live, is there even a MIL Base or Presence? [Update your Profile !]
a.) If not, then you will likely only get the Planes when Airborne.
Spend some time Scanning and make a list and post it back.
Great, thanks all.
Thunderbolt5
nd5y
Wichita Falls, TX
That should be 380-400 trunked or conventional and not strictly FM. There are still a few AM aircraft freqs too.
There is no trunking or land mobile use from 400.0-406.1
ampulman
South Jersey
Tried to program a Motorola system in the 380 mhz range, but error message says, 'out of range' or some such (on my 396T).
Will the XT accept frequencies in this range?
Amp
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
The 396T accepts these frequencies; I have several in mine, and they work fine. How are you programming them? Software, by hand...? 73 Mike
N1BHH
Jackson Square, East Weymouth, MA.
It's anything but obscure. The range from 225-400 is primarily military aircraft and there are some military land mobile users above 380, primarily trunked systems. Plus there are the new Intra Squad radios that have been introduced. The ISR's are actually reconfigured rugged FRS radios for use by the armed forces.
BMT
IIRC there are something like 80 or 90 MILAIR freq in the 380.0-399.9.
But don't quote me, some know it all will say I'm wrong!! ;-))
BMT
ChrisP
Portland, OR
Amp
Make sure you program it as "Motorola"-"P-25". The 396 will accept the 380 MHz channels only if you are doing a P-25 system.
- Chris
