DSDPlus 380 Meg CC band plan change breaks decode of DSD+
devicelab
Whacker Extraordinaire
Nowhere in WA
Bear with me there's a lot of info to digest here... So my local DoD P25 system changed their band plan from this:
Code:
Network: BEE00.14C  ; DoD
  Bandplan #0:   Base=851.00625   Offset=-45     Spacing=6.25  BW=12.5
  Bandplan #1:   Base=762.00625   Offset=+30     Spacing=6.25  BW=12.5
  Bandplan #2:   Base=380.        Offset=+10     Spacing=6.25  BW=12.5
  Bandplan #3:   Base=406.        Offset=+9      Spacing=6.25  BW=12.5
  Bandplan #4:   Base=380.        Offset=+10     Spacing=6.25  BW=12.5  Slots=2
  Bandplan #5:   Base=406.        Offset=+9      Spacing=6.25  BW=12.5  Slots=2
  Bandplan #6:   Base=136.        Offset=-8.6    Spacing=6.25  BW=12.5  Slots=2
  Bandplan #7:   Base=380.        Offset=+10     Spacing=12.5  BW=12.5
  Bandplan #8:   Base=136.        Offset=-8.6    Spacing=12.5  BW=12.5
  Bandplan #9:   Base=136.        Offset=+4.6    Spacing=12.5  BW=12.5
  Bandplan #10:  Base=380.        Offset=+9      Spacing=12.5  BW=12.5
to this:
Code:
  Bandplan #2:   Base=380.0125    Offset=+9.95   Spacing=25    BW=12.5
  Bandplan #3:   Base=380.        Offset=+10     Spacing=12.5  BW=12.5
Prior to realizing this change, I tried loading up DSD+ to monitor the trunk system via my usual scripts. It started out fine but then the CC changed to an obviously incorrect frequency. Here's the DSD live output:
Code:
2022.12.31 12:59:57  Initiating FMPx link using link ID 20001...
2022.12.31 12:59:57  FMPx link established; link ID = 20001
2022.12.31 12:59:58  Sync:+P25p1         TSDU CRC FAIL
2022.12.31 12:59:59  Sync:+P25p1         TSDU ERR6   IDEN_UP              ID=0 Base=851.00625 Offset=-45 Spacing=6.25 BW=12.5
2022.12.31 12:59:59                           ERR17  IDEN_UP              ID=1 Base=762.00625 Offset=+30 Spacing=6.25 BW=12.5
2022.12.31 12:59:59                           ERR8   Opcode= 9 MFID=90    89 90 0F 00 00 00 00 00 00 00
2022.12.31 12:59:59  Sync:+P25p1 NAC:140 TSDU ERR2   SYNC_BCST            US=0 IST=0 MMU=0 MC=0 VL=1  LTO=-5h  2022/12/31 20:58 uSlot=7460
2022.12.31 12:59:59                           ERR6   NET_STS_BCST         WACN ID=BEE00 SysID=14C LRA=0 CC=3-17 SC=70
2022.12.31 12:59:59                           ERR6   SCCB                 RFSS=1 Site=2 [ch=3-44 SSC=04] [ch=3-44 SSC=04]
2022.12.31 12:59:59  Sync:+P25p1         TSDU ERR4   RFSS_STS_BCST        SysID=14C LRA=0 RFSS=1 Site=2 CC=3-17 SC=70
2022.12.31 12:59:59                           ERR6   SN-DATA_CHN_ANN_EXP  DSO=00 TXch=none RXch=none DAC=0001
2022.12.31 12:59:59                           ERR4   Opcode= 5 MFID=90    85 90 00 00 00 00 00 00 00 00
2022.12.31 12:59:59  Sync: no sync
2022.12.31 12:59:59  Sync:+P25p1         TSDU ERR5   NET_STS_BCST         WACN ID=BEE00 SysID=14C LRA=0 CC=3-17 SC=70
2022.12.31 12:59:59                           ERR6   SCCB                 RFSS=1 Site=2 [ch=406.275 SSC=04] [ch=406.275 SSC=04]
2022.12.31 12:59:59                           ERR3   RFSS_STS_BCST        SysID=14C LRA=0 RFSS=1 Site=2 CC=406.10625 SC=70
2022.12.31 12:59:59  Sync:+P25p1         TSDU ERR7   SN-DATA_CHN_ANN_EXP  DSO=00 TXch=none RXch=none DAC=0001
2022.12.31 12:59:59                           ERR9   Opcode= 5 MFID=90    05 90 00 00 00 00 00 00 00 00
2022.12.31 12:59:59                           ERR12  ADJ_STS_BCST         SysID=14C LRA=0 RFSS=1 Site=9 CC=409.1125 SC=70 CFVA=3: Networked
2022.12.31 13:00:00  Sync:+P25p1         TSDU CRC FAIL
2022.12.31 13:00:00                           CRC FAIL
2022.12.31 13:00:00  Sync:+P25p1         TSDU ERR8   ADJ_STS_BCST         SysID=14C LRA=0 RFSS=1 Site=1 CC=406.0375 SC=70 CFVA=3: Networked
2022.12.31 13:00:00                           ERR8   IDEN_UP              ID=0 Base=851.00625 Offset=-45 Spacing=6.25 BW=12.5
2022.12.31 13:00:00                           ERR10  IDEN_UP              ID=1 Base=762.00625 Offset=+30 Spacing=6.25 BW=12.5
2022.12.31 13:00:00  Sync:+P25p1         TSDU ERR8   SCCB                 RFSS=1 Site=2 [ch=406.275 SSC=04] [ch=406.275 SSC=04]
2022.12.31 13:00:00                           ERR6   RFSS_STS_BCST        SysID=14C LRA=0 RFSS=1 Site=2 CC=406.10625 SC=70
2022.12.31 13:00:00  Sync: no sync
So I just wanted to make sure this wasn't a bug. Shouldn't DSD+ be able to update the band plan (or at least verify if it has changed) so the end user doesn't have to figure this out manually..?
FWIW, I've seen this happen with other P25 systems and I always have to create a new P25data file. I don't mind doing this but this has to be fixable in code, no..?
devicelab
Nowhere in WA
Update: so after clearing out my old P25data file and launching DSD+ to monitor this system, DSD+ keeps losing the control channel. It finds it again but within 30 seconds it loses it again. Weird.
maus92
The OP
Looks like ratty data to me. Prob a signal issue. The two local 380 systems that I can receive both have base frequencies of 380.000 and spacing of 12.5. Only two entries, one for FDMA and the other for TDMA. No 700 or 800 band entries.
devicelab
Nowhere in WA
Well that means nothing for these parts. This area has always had interesting band plan arrangements. FWIW, I'm pretty sure the data is valid. I tried it twice on different setups and both gave me the same data.
devicelab
Nowhere in WA
Just to clarify, only the JBLM side has changed. The Navy ELMR sites are still using the old band plan and they are not compatible. Why these two systems share the same SYSID is another story.
devicelab
Nowhere in WA
@devicelab I don't see the iden_up for ID 2. Does it appear at all? Note that spacing=25 does not look normal.
Yes I completely agree. So that last snippet was the 'original' band plan -- so it DSD+ choked because it wasn't matching the new band plan.
Here's DSD+ output when I lock on to the control channel with the 'new' band plan -- of course this is just a small sample:
Code:
Sync:+P25p1         TSDU ERR9   RFSS_STS_BCST        SysID=14C LRA=0 RFSS=1 Site=2 CC=3-17 SC=70
                         ERR5   SN-DATA_CHN_ANN_EXP  DSO=00 TXch=none RXch=none DAC=0001
                         CRC FAIL
Sync:+P25p1 NAC:140 TSDU        ADJ_STS_BCST         SysID=14C LRA=0 RFSS=1 Site=3 CC=3-58 SC=70 CFVA=3: Networked
Sync:+P25p1         TSDU        Opcode= 9 MFID=90    09 90 0C 80 00 00 00 00 00 00
                                SYNC_BCST            US=0 IST=0 MMU=0 MC=0 VL=1  LTO=-5h  2023/01/02 07:44 uSlot=4230
Sync:+P25p1 NAC:140 TSDU        SCCB                 RFSS=1 Site=2 [ch=380.55 SSC=04] [ch=380.55 SSC=04]
                         ERR1   RFSS_STS_BCST        SysID=14C LRA=0 RFSS=1 Site=2 CC=380.2125 SC=70
Sync:+P25p1 NAC:140 TSDU        Opcode= 5 MFID=90    05 90 00 00 00 00 00 00 00 00
                         ERR1   ADJ_STS_BCST         SysID=14C LRA=0 RFSS=1 Site=9 CC=386.225 SC=70 CFVA=3: Networked
                         ERR3   IDEN_UP_VU           ID=2 Base=380.0125 Offset=+9.95 Spacing=25 BW=12.5
Sync:+P25p1 NAC:140 TSDU        IDEN_UP_VU           ID=3 Base=380. Offset=+10 Spacing=12.5 BW=12.5
                         ERR1   Opcode= 9 MFID=90    09 90 0C 80 00 00 00 00 00 00
                                SYNC_BCST            US=0 IST=0 MMU=0 MC=0 VL=1  LTO=-5h  2023/01/02 07:44 uSlot=4260
Sync:+P25p1 NAC:140 TSDU        NET_STS_BCST         WACN ID=BEE00 SysID=14C LRA=0 CC=380.2125 SC=70
Sync:+P25p1 NAC:140 TSDU        SN-DATA_CHN_ANN_EXP  DSO=00 TXch=none RXch=none DAC=0001
                         ERR1   ADJ_STS_BCST         SysID=14C LRA=0 RFSS=1 Site=1 CC=380.075 SC=70 CFVA=3: Networked
Sync:+P25p1 NAC:140 TSDU        IDEN_UP              ID=0 Base=851.00625 Offset=-45 Spacing=6.25 BW=12.5
                                Opcode= 9 MFID=90    89 90 0C 80 00 00 00 00 00 00
Sync:+P25p1 NAC:140 TSDU ERR1   SYNC_BCST            US=0 IST=0 MMU=0 MC=0 VL=1  LTO=-5h  2023/01/02 07:44 uSlot=4300
Sync:+P25p1 NAC:140 TSDU        RFSS_STS_BCST        SysID=14C LRA=0 RFSS=1 Site=2 CC=380.2125 SC=70
Sync:+P25p1 NAC:140 TSDU ERR1   ADJ_STS_BCST         SysID=14C LRA=0 RFSS=1 Site=3 CC=380.725 SC=70 CFVA=3: Networked
                         ERR1   IDEN_UP_VU           ID=2 Base=380.0125 Offset=+9.95 Spacing=25 BW=12.5
Sync:+P25p1 NAC:140 TSDU        Opcode= 9 MFID=90    09 90 0C 80 00 00 00 00 00 00
                         ERR1   SYNC_BCST            US=0 IST=0 MMU=0 MC=0 VL=1  LTO=-5h  2023/01/02 07:44 uSlot=4330
Sync:+P25p1 NAC:140 TSDU ERR1   Opcode= 5 MFID=90    05 90 00 00 00 00 00 00 00 00
                         ERR2   ADJ_STS_BCST         SysID=14C LRA=0 RFSS=1 Site=9 CC=386.225 SC=70 CFVA=3: Networked
Sync:+P25p1 NAC:140 TSDU ERR1   IDEN_UP              ID=1 Base=762.00625 Offset=+30 Spacing=6.25 BW=12.5
                                SYNC_BCST            US=0 IST=0 MMU=0 MC=0 VL=1  LTO=-5h  2023/01/02 07:44 uSlot=4360
Sync:+P25p1 NAC:140 TSDU ERR1   NET_STS_BCST         WACN ID=BEE00 SysID=14C LRA=0 CC=380.2125 SC=70
                         ERR2   ADJ_STS_BCST         SysID=14C LRA=0 RFSS=1 Site=1 CC=380.075 SC=70 CFVA=3: Networked
Sync:+P25p1 NAC:140 TSDU ERR1   IDEN_UP_VU           ID=2 Base=380.0125 Offset=+9.95 Spacing=25 BW=12.5
Sync:+P25p1 NAC:140 TSDU        SYNC_BCST            US=0 IST=0 MMU=0 MC=0 VL=1  LTO=-5h  2023/01/02 07:44 uSlot=4400
                         ERR1   SCCB                 RFSS=1 Site=2 [ch=380.55 SSC=04] [ch=380.55 SSC=04]
Sync:+P25p1 NAC:140 TSDU ERR1   RFSS_STS_BCST        SysID=14C LRA=0 RFSS=1 Site=2 CC=380.2125 SC=70
Sync:+P25p1 NAC:140 TSDU        ADJ_STS_BCST         SysID=14C LRA=0 RFSS=1 Site=3 CC=380.725 SC=70 CFVA=3: Networked
                         ERR1   SYNC_BCST            US=0 IST=0 MMU=0 MC=0 VL=1  LTO=-5h  2023/01/02 07:44 uSlot=4430
                                SYNC_BCST            US=0 IST=0 MMU=0 MC=0 VL=1  LTO=-5h  2023/01/02 07:44 uSlot=4460
Sync:+P25p1 NAC:140 TSDU ERR1   SYNC_BCST            US=0 IST=0 MMU=0 MC=0 VL=1  LTO=-5h  2023/01/02 07:44 uSlot=4500
                         ERR1   IDEN_UP_VU           ID=3 Base=380. Offset=+10 Spacing=12.5 BW=12.5
Sync:+P25p1 NAC:140 TSDU ERR1   Opcode= 9 MFID=90    09 90 0C 80 00 00 00 00 00 00
                         ERR1   SYNC_BCST            US=0 IST=0 MMU=0 MC=0 VL=1  LTO=-5h  2023/01/02 07:44 uSlot=4530
Sync:+P25p1 NAC:140 TSDU        IDEN_UP              ID=1 Base=762.00625 Offset=+30 Spacing=6.25 BW=12.5
                         ERR1   SYNC_BCST            US=0 IST=0 MMU=0 MC=0 VL=1  LTO=-5h  2023/01/02 07:44 uSlot=4560
                         ERR1   Opcode= 9 MFID=90    89 90 0C 80 00 00 00 00 00 00
Sync:+P25p1 NAC:140 TSDU        SYNC_BCST            US=0 IST=0 MMU=0 MC=0 VL=1  LTO=-5h  2023/01/02 07:44 uSlot=4600
                                SYNC_BCST            US=0 IST=0 MMU=0 MC=0 VL=1  LTO=-5h  2023/01/02 07:44 uSlot=4630
devicelab
Nowhere in WA
And just to be clear, DSD+ is working fine as long as the new band plan is used.
PS. Unitrunker v2.140 shows the new band plan as well.
cg
Connecticut
Out of curiosity, can you switch back and forth without deleting the bandplan?
cg
Connecticut
Does the Control tab option "Rebuild Neighbor List and P25 Band Plan" after changing sites work to allow correctly following the system?
devicelab
Nowhere in WA
Interesting, I didn't see that command before.
Okay so I had the new band plan and went to CONTROL -> Discard Sys Info and switched to an ELMR site. It did seem to rebuild the band plan but the problem is the Channel Activity window shows the incorrect frequencies for the CC/SCC frequencies and even one of the voice channels.
I then tried the command mentioned above and nothing seem to change. The channel activity window still shows incorrect data.
If I simply close DSD+ and relaunch then it's all good. (Since it's working with the original plan.)
For grins, I went back to the JBLM site and just did the Rebuild command and that seemed to fix the band plan but again, I had to relaunch DSD+ to correct the channel activity window.
It's a messy solution.
devicelab
Nowhere in WA
The latest release is 2.1.0.104, not 2.140. Nitpicky? Maybe, but small details matter when you're asking for help/support. ;)
I wasn't asking for Unitrunker support. While I didn't have the precise version number it's not a hard reach to equate 2.140 to 2.1.140...
