380 MHz Trunk system in NJ
ion_op
Chemtrails
Hi,
Can I program my Pro-106 to receive the TRS control channels I'm hearing around 380MHz? I searched for Federal 380 NJ on RR and only found stuff for other areas?
Tnx,
Mike
MtnBiker2005
San Diego County, California
Yes your Pro-106 is able to track a 380MHz P25 system. You should start off with programming it for P25 Trunked.
All you should need is the control channel freq. Since it should get the rest of the freqs from the control channel data stream..
Can you get a System ID from that control channel. So everyone knows what system on RR or New System we are talking about.
Naval Air Station Lakehurst ?
http://www.radioreference.com/apps/db/?sid=5444
With your Pro-106 You can run Pro96Com or Unitrunker Decoding/logging software to view the control channel on the your computer screen.
ion_op
Chemtrails
I'm on the south side of the Watchung mountains so I do hear the CC alot so I want to give it a shot.
I saw the UniTrunker software mentioned in another thread. Will give it a shot.
Tnx,
mike
