385.3125 Newark
RadioDitch
Dual Citizen Member
Labrador West, Labrador
385.3125 active around Newark. NAC293. Discussions of POTUS motorcade. In the clear.
Update: 386.2250, 386.8000 also active in the clear regards same traffic. NAC582. Possible mobile trunked MILAIR site?
nd5y
Wichita Falls, TX
Did you get the WACN and system ID? For identifying trunked systems that can be more useful than just the frequencies and NAC.
Analogrules
260.900 MHz AM analog has also been very active. I believe it is being used by Mil-Air POTUS protection crews. (Probably CAP) They only speak in codes, but still fun to monitor.
The 380 MHz system currently active in NJ is actually discussed in another thread, under the Military forum.
ecps92
Taxachusetts
dlwtrunked
260.9 AM is a standard NORAD frequency used for exercise, interceptions, and combat air patrols. I would not label it POTUS protection crews though sometimes it may be protecting an area with a CAP where he is.
Analogrules
I only label as such, because it ONLY seems active when Trump is in the area. Therefore, the current useage is directly related to the POTUS.
richee2000
basking ridge nj
has anyone monitored this as a trunk system? with talk groups? and if so, what are the control channels? or are you just listening as conventional???
RadioDitch
Dual Citizen Member
Agreed, I noticed it also. Hence why I suspect/suspected it to be a mobile site. I haven't been able to get the ID for the "system". Someone did point out that those voice frequencies also match the West Point site. Thing is, the traffic was about POTUS, not USMA.
Analogrules
Despite what it may be alocated for, 260.900 has been active when POTUS is in the area. I also have been hearing a lot of warnings by the FAA and US Air Force on 121.500 regarding planes entering restricted air space. So far, these are the only ones in the clear that I found to be active, but there may be others.
Tech792
Central NJ
In addition to 260.9, the AR boom frequency 228.9 has been active during AR. The southern AR track is right over my house. The tanker comes over about every 15 minutes. Pretty cool to walk outside and look up and catch aerial refueling in progress.
richee2000
basking ridge nj
can you actually see the tanker? about what altitude? I am near the middle of the CAP (bernards twp) i cannot see any aircraft with the naked eye. listening on 260.9 to the activity.
