That's fine. But, I never intended for my results to dictate the entire charge life of the batteries, only the charge that is necessary to power the scanner -- and only to represent the days rest from charging that yaesumofo gives them. The rest does not matter. So, no -- there are no problems with my calculations. They were entened to represent the first 24 hours only.linuxwrangler said:I agree that letting them sit is wasting valuable electrons, but I think you might find some problems with your other calculations.
First, voltage and remaining charge are not linear - especially in NiCd and NiMH cells which have a bit of a peak at full-charge, stay fairly flat over most of their discharge and have a sharp dropoff at the end.
Second, the literature suggests a large initial loss (pretty close to your estimate) of around 10% in the first day but then perhaps 1%/day afterward.
When the 396 repeatedly shuts down at approximately 3.623 volts remaining, what do those two things matter? It doesn't matter if the discharge remains "fairly flat" at 1% per day for the remainder, because they still don't have enough charge to run the scanner.
At nearly 11% loss in the first 24 hours (which is slightly less than I found), only 3.66057 volts remain. The scanner shuts down at 3.623...
(BTW, the total volt reading after full charge should have been 1.371 each, not 1.361. But, this has little affect on the results.)
