396 downloads
patrolman123
Baltimore, Maryland
I currently have version 1.09.00 in my 396. Its been a while since I updated my scanner. What downloads do I need to put in my scanner. I ve been to the Uniden download section but Im not sure which ones I need.
rdale
Lansing, MI
Only download you can "put" in your scanner is the firmware - grab the latest.
patrolman123
Baltimore, Maryland
which ones
So I see on the website downloads with a lower version number but a newer date. Then I see versions with a higher number but an older date. So exactly which downloads do I need if I have version 1.09.00?
irmolars
This is the latest firmware update.
It is version number 1.11.03
BCD396T_V1_11_03.zip
UPMan
In Memoriam
Arlington, TX
I had to check our site after your post...I can only see one firmware update there. Where are you seeing the other firmware updates? (Sometimes "orphans" do get loose where they aren't supposed to be...)
cristisphoto
Uniden.com
Just go to Uniden.com
Find thier scanner pages LOOK UNDER DIGITAL SCANNERs, NOT HANDHELDs'
then navgate to support under your particular model find support etc downloads are near their....
you gots brains, use it :lol:
