396 Group Settings
don333
I should know the answer to this, but I don't! When creating groups the scanner shows from 1 - 10, but when using the ARC396 program it appears you can create more than 10 under a system. Is this true, and if so, what keys do you use to activate them in the radio.
Thanks.
pro92b
Mutated Member
According to the PDF manual, page 85, groups for a system are 0-9. Not sure why your software indicates more.
UPMan
In Memoriam
Arlington, TX
You can have up to 20 channel groups per system. There are only 10 GQK (group quick keys) available per system, but multiple channel groups can share the same GQK.
