396 Screen protector
HoDo
Baltimore, Maryland
I didnt want to make my scanner bulky and add a case, but I was wondering if anyone experimented with a PDA style screen protector to put on your 396's screen so it wont get scratched?
Screen Protector
I use the PDA screen protector on all my scanners and have had no problems.
HoDo
Baltimore, Maryland
What do you do just lay it on the screen and then take a exacto knife and cut along the edges? I dont want to cut or scratch the screen when fitting it, but I want it to be perfect.
LEH
Yorktown, Virginia
you could take a piece of paper, lay it over the screen area and trace the screen onto the paper, then use the tracing to cut the PDA overlay. You can also just measure the area and cut to size.
lots of options, but as you say, using an exacto knife on the scanner is a potential risk.
safetyobc
South Arkansas
I use the screen protectors on mine as well. I lay it on per the instructions in the package. Then take a small hobby knife and lay in the groove around the screen and trim the excess. Looks abosolutely perfect. Can't even tell anything is on the screen. When I first put it on, there were some small bubbles that just wouldn't come out but I gave it a couple hours and they all went away. Just start on one side and apply the protector sticking it to the 396 screen as you go rubbing the bubbles out. There may be a few left when finished, but if it is like mine a couple house and they are gone. I used the same ones on my 246 and have the same results.
918Dave
Glendale, Arizona
I use the PDA protectors made by 'Fellowes.' www.Fellowes.com Each protector is lined out on a grid and numbered both verically & horizontally. Simply line a protector up against any screen, then observe the numbers that match your screen. Then cut along those numbers. Even comes with a small squeegee-card. Dave
mmartinfan
Banned
In a house in Ohio
Exca-o knife ohhhhhh those are kids toys try cutting it with this
Overall length of 8.5” with blade length of 3.34”.
I highly suggest using PDA covers on all my screens
HoDo
Baltimore, Maryland
Has anyone else used the Apple Ipod screen protectors? What model number did you buy of the fellows, or does it not matter as long as they are larger than the screen so it can be trimmed down?
Al42
Long Island, NY, USA
If they're at least twice the size you can get two out of each one. The Belkin for the PPC are - I don't know about the Fellows.
918Dave
Glendale, Arizona
I tried the Ipod screen protectors and thought they sucked. I think they degraded the visibility, . . (but that's just my opinion), YMMV. The WriteRIGHT screen protectors, model # 90002 and made by Fellowes work great. No need to worry about using an Xacto knife? Count the lines on the grid, . . cut with scissors. Looks to me like each protector could make at least 4.
Dave, kk7re
HoDo
Baltimore, Maryland
When you say it has lines of a grid do they give you a template to trace onto the screen protector and then you cut it out, because the screen protector itself doesn't have lines or else that would be on your screen that you lay it on, correct?
bonus1331
Newnan, Ga
That's correct. I use the same protectors. It even comes with grid numbers, so you can line the protector up to the face of the scanner, note the height and width numbers and then use an Exacto knife. The grid lines are on the backing only.
