396 speaker audio cuts out....gone
Jlidstrom
Seattle
I purchased my 396 in May. Last month the speaker stopped working. Headset still works fine. I've since tried cleaning the headphone plug, and got a little (very nasty indeed) audio from the speaker, but it soon went quiet again. Uniden hasn't responded to two emails. I'm fairly steamed. anyone have an idea?
John
RolnCode3
Sacramento/Bay Area, CA
If you can get it repaired under warranty, do so.
If not, sounds like a loose connection or something. Would require a voltmeter and an understanding of electronics if it's not an obvious problem...would require opening the scanner up.
You might be able to check continuity/resistance through the headphone jack, but can't guarantee it.
bubbz
Bellevue,Ohio
396 audio
When you use an external spaeker or haedphones, as I have; I've experienced the same problem. For some reason I think there is an "static electricity" build-up somehow. I took the batteries out and rearranged them and this "stiffled" the problem.
Jlidstrom
Seattle
tried the battery thing....still no audio
I tried removing and reorienting the battery...no luck. I opened the case, imagining that the speaker had somehow become unplugged....well, the speaker is soldered in place, and everything looks good.....really good, in fact. I tried to clean out the headphone socket, with a number of devices, eventually used a paper clip bent 90 degree on the end to try and dislodge any goo or foil that might have gotten into the opening...voila...audio from the speaker..for about four minutes, then gone again. Where do I send this expensive brick for repair or refund? John
linuxwrangler
Contra Costa County, CA
If it is under warranty (which if you bought it new, I think it is), call Uniden's tech support phone number. Probably faster than email. (And while Uniden *might* not be responding to your email, consider also that they may have not received it or you may not have received their reply. Recent tests of email at a variety of ISPs show that many are just silently losing up to 50% or more of messages. Overzealous spam-filters on either end can cause problems, too. I work in high-tech but I'm generally inclined to pick up the phone.)
I had a similar problem and they repaired mine quickly though they erased the programming back to factory settings so do a back-up first. They did offer to reprogram it for me but I didn't have a current list of settings.
If it is not under warranty then go ahead and try to fix it yourself before sending it in. Here's what I found when repairing the same symptom on my 396. The earphone jack is a surface-mount component at the top of the printed-circuit board. For low-cost and small size, this is good. For mechanical isolation it is bad as it is pretty much mounted in place by the solder connections. Get the earphone cord hung on a doorknob, yanked by your toddler, etc. enough times and you will crack the solder joints. This seems consistent with your description of it working for a while after you fiddle with it. The 396t isn't mil-spec or "industrial-grade" (but it doesn't cost a few grand, either).
Pull the unit apart and look carefully with a magnifier (I use a jeweler's loupe) and bright light. The cracks can be difficult to see. Alternately, just assume they are cracked and reheat all the joints with a small soldering tip. I was, after some searching, able to see the cracks. After resoldering, everything worked fine, again.
After repairing the solder-joints, I wiretied the earpiece to the base of the antenna leaving about a 1cm loop for strain relief and to be able to unplug the earpiece when necessary. The cord has been snagged and yanked many times since but no more problems.
The batteries are in series and rearranging them will have no electrical effect. The act of opening the battery compartment and removing/replacing the batteries could physically twist/shake or jostle things causing a weak joint to shift. On dry days I can definitely hear static buzz and hiss in the earpiece when I pull on a coat but that is the sound of the static disappating through the earpiece wire - it doesn't build-up somewhere.
slicerwizard
Toronto, Ontario
That's to be expected. bubbz's "static electricity" theory is way out in left field.
Clearly, your problem lies with the headphone jack. As noted above, resoldering its connections is indicated, as is spraying some contact cleaner in to the jack's opening.
chas3
How about a bad speaker???
Mine was new this year and had speaker problems, and I have read that many other people experienced the same issues. If it's under warranty send it in, otherwise gamble on $5 for a speaker and give it a try.
Chas
DickH
C'mon now, you're giving REAL fixes. I was hoping for some more exotic "repairs". Some years ago in a Boston suburb, one Sergeant who was obviously an electronics genius, when told by a cruiser that the radio was coming in poorly, responded, "Just wiggle the Squelch".
slicerwizard
Toronto, Ontario
Well, one should always try the standard fixes, like remove the batteries for 24 hours to clear the CMOS settings and then store the scanner in the freezer for another 24 hours to "freeze" the correct settings in place. Almost forgot FDISK /MBR - never skip that step.
You could also call Uniden tech support and ask for the full reset button combo. It's not the 2/9/Hold that's in the manual. They'll probably tell you that there is no other combo, but the techs at the authorized repair centers use it all the time, so don't fall for that one. I would've just listed it here, but I can't find the scrap of paper I wrote it on. When I find it, I'll post it here. Last time I used it, the digital decoding sounded almost as good as a GRE, but Uniden doesn't want that getting out in the wild, as it would hurt sales of their next model.
BTW, don't get the contact cleaner on the LCD; you don't want streaks (or worse) on the display. Hold the scanner so that gravity will pull the fluid away from the LCD and don't overspray.
800crazy1
CHICOPEE
probably on back order due to the fact i bought two speakers last month from uniden for 8.34 this included the shipping. my speaker just sounded popped or cracked and i had my 396 for at least a yr and a half . i bought two so i wouldnt have to wait again for shipping in case the first replacement craps out on me again , i replaced it my self and many helped answer my questions including slicer wizard. anyways , glad i have one spare speaker now put away just incase , so far , no problems with the first speaker i replaced.
Jlidstrom
Seattle
well, here's what happened...just like you said
my 396 is on the way back from repair land at uniden, about three weeks gone. It's still not here, but they indicate they have replaced the speaker, and all is well. So, if I paid half a thousand dollars for this, why does it have a .12 speaker that is known to fail repeatedly . It's a wonderful scanner, but if it fails in another six months, it's out of warranty. Is the repair warrented for a year?
By the way, the freezing it didn't work work poop
