Go to the menu and select 'program system'
select the system that is 'messing up'
go to the 'edit sys option' and select it
go to the EDCS ID format and select
Your choices are AFS or Decimal. The AFS gives the ID in ###-# while decimal uses the #####.
Go into program, then the system, the options, then fleet map...
go to custom, set or change
block 0 =0
Block 1 = 0
Block 2 = 0
Block 3 =0
all the way to Block 7 set them all as zero, and that will solve your problem.
block 0 =0
Block 1 = 0
Block 2 = 0
Block 3 =0
