Has anyone experienced a problem with the volume control on the 396? When I push it in, the display goes back & forth between where I had it at and 3. Any solutions or suggestions? Thank you.
Mike
Mike
Instead of just reinstalling the new version, you might try re-downloading first. Sometimes you can get bit errors on a download. I haven't noticed any problems with my new version.
Is this happening with the radio completely disconnected from the PC interface? Just curious if you have software perhaps simultaneously trying to control the radio as you change it directly. I'm using V3.0.1 and ARC396 release 6 and don't see that problem at all, even with it all running at once.
Four PMs reported the same issue? Did any of those four say that they resolved it? If not, what were they planning to do about it?
Did you notice anything you had in common with them - like all of you having d/l and installed in the past few days? Or, all of you had the volume set at 5?
