396 XT Pre-programming List Error
Citywide74
MARYLAND
Friend just bought a 396 xt. It had no preprogrammed systems in it like mine did. When you turn the unit on, I get the error message Pre-programming list error. I have programmed the scanner and it works fine. Any idea how to make this go away?
Viper43
Check the manual and do a hard reset, that should restore original programing
KE4ZNR
Radio Geek
did not work
It will if you do it exactly as described below:
BCD396XT - The RadioReference Wiki
Preloaded Systems and their System Quick Keys
Press and hold 2,9, and Hold, power on the scanner to re-initialize the Memory and restore the Preloaded systems. When it asks do you wish to restore the preloaded systems press the E/Yes key. WARNING This will erase any personal programming you may have done to your DMA.
The preloaded system list for the BCD396XT:
SQK System
  • 21 Alaska ALMR
  • 22 Arkansas AWIN
  • 23 Colorado DTRS
  • 24 Connecticut State
  • 25 Delaware
  • 26 Georgia GEWIN
  • 27 Idaho IIMARS
  • 28 Ill StarCom21
  • 29 Indiana SAFE-T
  • 30 Kansas KSICS
  • 31 Louisiana LATIE
  • 32 Mass State Sys
  • 33 Michigan MPSCS
  • 34 Mississippi MWIN
  • 35 Montana StateSys
  • 36 NC VIPER
  • 37 Nevada SRS
  • 38 Ohio MARCS
  • 39 Rhode Isl RISCON
  • 40 SC Palmetto 800
  • 41 SDakotaState
  • 42 TX DPS
  • 43 Utah UCAN
  • 44 Virginia STARS
  • 45 WVirginia WVIRP
  • 46 WyoLink
Note: it will wipe out any other programming in the scanner.
Marshall KE4ZNR
