396T ant.jack
ArgoGirb67
London Ontario Canada
having an issue with the ant. jack of my 396T.Its had a hard life mounted to the dash of a dump truck for several years,with several different antennae on it,one a telescopic(old RS bnc),or the mag mount connector.I opened the scanner to see if a solder joint problem,all looked good .Do the connectors fail internally?where to get fixed on this side of the border?Ive done some electronic work before but this is just to little room for error!
tmbstn
ON Canada
lazer root page
I am not sure where you are located but I know this guy from Baden, he is now just off the 401 @ Ceadercreek. He can fix anything and the price is good. Check the link above & good Luck!!
Freebase
Alliston, Ontario
I second the recommendation for Lectron. I had my BC296D repaired by them a couple of years ago, the final cost was even less than the repair estimate. They replaced the antenna mount and the volume/squelch pot, have had no issues since then. The turnaround time was probably less than a week.
