- Joined
- Dec 19, 2002
- Messages
- 560
- Reaction score
- 2
1. While trunktracking, it looks like there's enough room to the right of the frequency to also show the talk group ID, that way you can see the frequency, the talk group ID, and your alpha tag all at the same time which would be nice. There's also room to move the frequency 1 digit to the left. I realize that room to the right of the frequency is used for messages like 'LNK', 'ENC', or 'P25', so maybe the talk group ID and the message could flicker or alternate. Maybe the extra room to the right of the enabled system and group list could be used for those messages. Either way, there's enough overall room on the screen to add the TG ID.
2. Same thing with conventional scanning. If you move all the 'FM' and 'C100.0" stuff all the way over to left or right, then there's enough room to show the frequency along with the alpha tag. Then you can get rid of the whole FUNC + 5 thing.
3.During an emergency call (when a subscriber hits the emergency button on their radio) It would be kinda cool if the radio display could scroll or alternate something like 'EMERGENCY' on the screen until the talk group is no longer in emergency status.
4. Rather than setting the emergency alert volume independent of normal audio volume, make it with respect to the current volume. When I'm listening to a talk group and the volume is 9 for example, the emergency alert comes through kind of quiet. Granted, I could set the emergency alert to 14 or something, but then when I listen to the scanner at a lower volume (say 3 or 4) it'll seem too loud. If there was someway to make the alert volume +3 or +4 louder than the regular volume it would be nice! I know this is picky, but it's just my 2 cents. Perhaps the emergency alert volume settings could be something like: NONE, AUTO, -3,-2,-1,0,+1,+2,+3, etc.
5. When you get a hit during close call operation, make it so that the frequency is displayed right away without having to press a button.
6. Allow the user to enable or disable a low battery alert regardless of whether or not the keypad beep is enabled or disabled. Personally, I don't like the keypad beep, but I would like an audible low battery alert.
Welp, that's my $.02 for what it's worth. This is a great scanner! I shouldn't have waited as long as I did.
Perhaps others could post their firmware upgrade wish lists here?
