396T firware help
jcanupp
Atlanta GA
Does anyone know where I can download the zip file for firmware 1.20.13, or have it they can PM me...please?
jcanupp
Atlanta GA
I'm sorry UPMAN, when I click on 396T firmware, it goes to the page for 3.0.2...any advice? When I loaded 3.0.2, I had good signal strenght on the meter, but no reception, virtually at all.
jcanupp
Atlanta GA
I did once before...and it worked fine. How come I can't hear anything with 3.0.2? It this common or unique? I was in downtown atlanta, on their P-25..doing ID search..and nada??? I really want to listen to rebanding. I did thice once before, reverted to 1.20.13 and it fixed it. I thought I had the file, but I can't find it. Is there a fix coming? I can't afford a new radio right now. I sent it to Uniden and they said nothing was wrong with it.
W6KRU
Vista, CA
There is a problem with the setup of your scanner. I suggest you try to solve the real problem instead of going back and forth with firmware. It sounds like you quite possibly have an issue with rebanding and should ask for help with that.
jcanupp
Atlanta GA
A reader suggested that 3.0.2 worked great..it must be in my radio set-up..would you be willing to offer suggestions? I was in downtown Atlanta today with their P-25..Had full signal from control channels and doing an ID search..it should have been screaming. The radio does not have the reception it ove did..but when it works, the P-25 is crystal clear. I am a novice at this. I can never repay the favor, but your advice would be appreciated? How abaoy 3.0.0, or 3.0.01? did folks have trouble with that version?
n4yek
Cosby, Tennessee
jcanupp
Atlanta GA
I am trying to listen to Rockdale County, and Fayette County. I'm ok with 3.0.2, and I'm ok with the radio being set wrong..I can goof. I've got it set on Man, 8, and FM. Does 3.0.0, or .1 have reception issues?
