396T group Keys
ajpritch
Westerville, Ohio
ALright I have figured out how to use the quick keys to turn on and off the systems but how to I use the group keys to turn on and off groups quickley without having to go into the menu and edit the groups?
Voyager
FUNC [0-9] while holding on that system.
Joe M.
Voyager
kjfswkr said:
How do you select a quick key? This scanner is going to take a while to get used to.
Kevin
Group Quick Key? As described above.
System Quick Key? For SQK 0-9, press the corresponding number on the keypad while on SCAN mode. For SQK 10-99, press the decimal point followed by the two-digit SQK number.
If you mean how you assign a SQK or GQK, that is done in the system or group options in the programming menu.
Joe M.
