I have a question, when scanning Phoenix PD which is P25 I sometimes come across ENC tgs if I hit lock out will it only lock out that enc tg or does it lock out the freq that the enc tg is on? How would I lock out only certain TGs? Thanks
When scanning a trunk system, lockout will ONLY lock out TGID's. It will not lock out frequencies. You can even review all the TGID's that you have locked out, and "unlock" them. You can lock out frequencies, but you have to manually select them, or much better, do it with software.I have a question, when scanning Phoenix PD which is P25 I sometimes come across ENC tgs if I hit lock out will it only lock out that enc tg or does it lock out the freq that the enc tg is on? How would I lock out only certain TGs? Thanks
Menu / Program System / Edit Sys Option / Rvw ID:Srch L/OHow do i see the TGs I have locked out?
PG 81 just shows how to unlock all TGs that are locked, how do I see what TGs are locked and unlock them 1 by 1? BC Tools dont even show this?
I believe the answer is the same: In Edit System Options Menu http://myweb.cableone.net/marksscanners/330/330test.html#review LO IDs Try it and compare list to those programmed vs not programmed.Ok im sorry! These are not talk groups that I had prog in the scanner. These are TGs that come up while scanning and they just show the ID # of the TG because its not in the scanner.
