396T not scanning local trunked system after reband & upgrade to 3.02.02
whooey
Gainesville, FL
I am scanning the Alachua County Smartzone system after Rebanding. I have all my other digital scanners up and running, but my 396T's arent scanning right.
I have upgraded to 3.02.02 and have put all the new reband control channel's in the 396T as well.
When I try to scan the Alachua County system, the display shows frequency 853.7875. Therefore the scanner does not pick up on any coms whatsoever. That is NOT one of my control channel's, nor do I have 853.7875 programmed in the 396T as a CC. It seems hung on that freq for some reason...
Now here is the weird part. When I do a CC custom search in the 853 range it picks up the system fine, with the P25 audio and all.
I would appreciate if someone could maybe give me a tip on how to fix this minor problem.
Thanks! :)
wise871
N.W. Florida
According to the RR database, 853 is not even part of the database. I show 868.81250 as the control channel. It may be interferance from a nearby tower. According to the database, NEXTEL LICENSE HOLDINGS 1, INC. uses 853.7875 in your area.
the 868.?? may have been rebanded?.. try 853.8125??? -15MHZ) just a guess
whooey
Gainesville, FL
I'm sorry, they have rebanded. I submitted the data but they havent changed it yet in the database, 853.8125 is the CC. :cool:
Thanks for the replies guys.
Anyone else?
whooey
Gainesville, FL
I got it figured out and after about 2000 button presses, I am up and running again.
Thanks!
buttaik
Thanks!
hey Brandon, what did you do to get your 396 up and running for the Gainesville trunking changes?
Jim
awasser1
Apache Jct, AZ
UPMAN,
When I tested the last firmware with you 396t. The screen got stuck 1-2 times. audio changing channels but screen wouldnt move. had to disc power and battery to reset. Well its still doing this about once a week. Its just annoying because before the 3.xx firmware it never did this. Any Suggestions
Alec Wasserman
See the instructions included with the firmware update. (BCD396TFirmwareUpdate < UnidenMan4 < TWiki
whooey
Gainesville, FL
Jim
The new firmware, then program the system under Custom 800, enter the band plan UPman laid out, then drop the control channels by 15Mhz. Voila. :eek:
buttaik
ok, my firmware is the latest and has been for some time now. Did you have to create a new system vs. being able to set a custom plan under the exisitng system?
mrjoed40
Gainesville, FL
Hi all,
I have the same issue as whooey - Alachau County FL 800 System. Kind of a novice , can I use any software package to reband my 396, ARC 396 ect.
Thanks !
ladygator
I'm sorry. I'm having the same problem as Whooey. I have all the frequencies that RR lists for Gainesville/Alachua County programmed but, it still just keeps showing that 853.7875 that's not even in the RR list. Help!
851.08750 851.13750 851.18750 851.41250 851.63750 851.66250 851.77500 851.91250
852.05000 852.18750 852.27500 852.30000 852.41250 852.56250 852.68750 852.77500
852.81250 853.06250 853.11250 853.18750 853.31250 853.36250 853.52500 853.56250a
853.67500a 853.77500a 853.81250c 853.86250
UPMan
In Memoriam
Arlington, TX
I didn't catch from your other thread that the system had recently rebanded (no notes to that effect in the DB). So, follow my advice to the OP:
See the instructions included with the firmware update to create an 800 Custom system with the correct band plan. (BCD396TFirmwareUpdate < UnidenMan4 < TWiki)
buttaik
ok, what I have learned by trial and error with the GRU/Alachua County TRS.
You cannot use the UASD software to make changes to an existing Alachua County (this probably holds true for any rebanded system) system in the 396 nor can you edit a current system (that has rebanded) already in your 396/996 by way of the scanner's keypad.
You either have to 1.) Create a new custom system for Alachua County by using the scanner's keypad (yes this means entering all talkgroups/frequencies/everything as you did the first time) or 2.) You have to use software that has been updated to allow a custom bandplan. The Uniden UASD software will NOT allow you to update or enter a custom band plan for a rebanded system. I used "FreeSCAN" to recreate my Alachua County systems and am back up and running.
If I am wrong or there is an easier way to do this, please, let me/the readers know.
And finally, the only strange thing I have happening is that my 396 will sometimes hang after a conversation has ended with what can only be described as an open carrier on select talkgroups. If I hit scan, the problem will go away until it finds the urge to hang again after a transmission is over and the scanner should move on to the next transmission. Any ideas as to what I have incorrectly set up?
Jim
