396T PL tone display
k2ns
Putnam Valley, N.Y.
396T PL tone frequency detection
hi all,
I have a 396T, and I listen to a couple of police departments that have other PD's on the same frequency. I know that i can program my 396T to only respond to the proper PD by programming in their PL tone, but the tone is not listed here in the R/R database. How do I set up the radio to detect what the PL tone is ??? I know it can be done, as I read about people doing it right here on R/R, but I can't figure this one out. HELP !!!
RON
Saint
Fort Erie Ontario Canada
Tone Search
Prees Menu button on side of scanner, go down to (Srch/close call opt), press enter button and turn on tone search so it will show the tones on the frequencies it finds.
Steve
KB3KBR
(ಠ_ಠ) (◣_◢) (。◕‿◕。)
Oil City, Venango County, PA
you have to change the setting in the channel itself. when it stops on your desired channel press enter, rotate down to Set CTCSS/DCS press enter , then select search. what was described by Saint is the procedure to put the search/close call in search for tone. one other thing, if you have a channel set to search it will NOT decode p25.
