jfr454
I listen to Waterbury on a 996T, programmed with Freescan including the custom band plan and have never experienced a problem.
Audio is very clear.
This "seems" to be isolated to EFJ infrastructure. I bet the scanner is interpreting something on the CC incorrectly as a "bandplan", which causes you radios to rewrite the internal bandplan.
Reference: http://forums.radioreference.com/co...aterbury-new-p25-system-line.html#post1970090cg said:Waterbury's new P25 system is online with most departments going over to it by the end of the day. PD may be delayed until a future date.
Band plan is: BASE 851.0625, STEP 6.25KHz
"00-0044","av",851.33750,"00-0044",806.33750,0,45
"00-0084","v",851.58750,"00-0084",806.58750,0,3
"00-0168","c",852.11250,"00-0168",807.11250,0,0
"00-0294","v",852.90000,"00-0294",807.90000,0,7
"00-0414","v",853.65000,"00-0414",808.65000,1,40
I'm glad you chimed in, what I found is the T-series radios let you manually set a bandplan and apparently ignore any OTA bandplan information. As opposed to the XT-series which will let you manually enter bandplan info but it will be overwritten if it sees any OTA bandplan info.
Oh joy! The radio out thinks the owner!!!! Made a number of attempts to upload Waterbury. Funny thing the 'reception bars' show something is active but no audio. When I scroll through the info uploaded it is all the same as what I have found in the various posts regarding the band plans, TGID etc.
Jeff
I notice that Waterbury's control channel changed from 851.9000 to 851.3375 and I have lost the band plan about six times in the last three or four days (on two separate scanners, thought not at the same time). The scanner also takes a longer time picking up transmissions on this new control channel.
I've been listening on the computer, the WTBY transmission leaves a lot to be desired. Many times
unreadable, to the point the dispatch is asking for repeats of the transmission. Lot of action though.
Have to high jack the thread, I am very disappointed in the 996xt and the complexity of the unit and that Uniden is not going to support the scanner with upgrades! Want you to plunk down another $600 for the new release!!!!!!!!!!!!!!!!
Jeff
